Question about Kodak EasyShare C330 Digital Camera
I can not close the battery door the clip will not stay closes. Is this repairable.
  • ashford_6 Jun 25, 2009
    This Camera has hardly been used. Most remarks from stores of course say buy a new one. This camera is like new.
Tape
Posted on Jun 29, 2009
The clip on the door to the battery case is is broken. Where can I get this repaired?
You can visit, or contact a Fuji certified repair centre, close to you. For that use google and ask for repair centre close to or in .... your city.
Before sending the camera in, please ask what the repair will cost you, because it could be more expensive then buying a new camera, with better specs.
Dec 16, 2014 | Fujifilm Finepix S1000fd 10.0 Mp Digital...
Why will the door not lock and stay closed ?
Ithink the door clips spring is loose inside so openthedoor cover orjust move your door clips by hand it must not be too loose
Dec 08, 2014 | Amana Microwave Ovens
Battery door won't stay closed on Sony Cyber-Shot DSC-S90 Digital Camera
The battery door latch is most likely damaged/broken. Try using a piece of duct tape to keep it closed. I've done this on several cameras with battery door latch issues & the doors stayed shut just fine.
May 20, 2014 | Sony Cyber-Shot DSC-S90 Digital Camera
The door spring came off of hamilton beach 31100
The door of the Hamilton Beach Model 03008 or similar toaster oven does not stay closed when the door return spring or the hook it connects to breaks. The repair is very simple and takes just a few minutes!
The door spring is about 1 inch long and connects to a small clip on the inside of the left side panel of the unit. To see the small clip and the door spring, you simply remove the left side panel of the toaster oven which is done by removing just one screw.
The mounting clip on the side panel for the door return spring is located about half way up the side panel near its front edge.
The other end of the spring (its bottom end) connects to a metal hook. If the spring is not connected on its bottom end then the wire hook is broken. This is a simple repair that only requires a few inches of metal wire.
The other end of the metal hook (its bottom end) is connected to the bottom of the door hinge where it inserts into a small hole in the left side mounting hinge of the door.
When the steel hook breaks on either end then the spring cannot function, so the door does not stay closed.
To fix this problem, you simply get a piece of steel wire that is about 1/16 inch thick and a few inches long.
Bend the wire to make a hook at one end that the spring will connect to.
Then insert the other end of the wire into the small hole on the left side mounting hinge of the door. Then bend the wire on the inside of the hole to make a U or hook so the wire stays mounted in the hole of the door hinge.
Then adjust the position of the bend on the other end of the metal wire so the spring will have good tension when it is attached to the hook and to the clip on the side panel.
To do this you make the U shaped bend on this end of the wire to be about 1/2 inch from the end of the open end of the spring when the top end of the spring is attached to the mounting clip on the side panel.
To attach the spring to the wire hook, first remove the spring from the mounting clip. Then hook the spring onto the hook (bend) you made at the top end of the wire, then just stretch the spring to connect it to the mounting clip. The door will now stay closed.
Nov 10, 2013 | Hamilton Beach 31197 120 Watts Toaster...
Battery door will not stay closed
the little clip(s) have broken. you can take it to a camera shop for repair or find the part and instructions online and do it yourself. mine has broken twice. i'm using a piece of tape.
Jun 12, 2011 | Sony Cyber-Shot DSC-W1 Digital Camera
Lights stay on constantly even when not running; does not run aft
That clip is necessary as it tells the dryer when the door is open and when the door is closed. you will have to get a new door switch.
Jul 04, 2009 | Dryers
Nikon Cool Pix 7900 Battery door won't stay closes
There are plastic clips on the battery door and body of the camera that lock the door in place. If they are broken of the battery door the door can be changed. If the clips on the body are broken the camera as a rule is history. Replacing a camera body is not a feasible repair.
Jul 02, 2009 | Cameras
Door does not stay closed
your door clip needs to be replaced or realign
your door
Jun 11, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Gray plastic piece that holds the black clips that holds the door shut is cracked
you tape the door shut just make sure tape does not cover and vents. check web sites for parts?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 12, 2009 | Minolta Di3510f Bizhub Copier
Battery door
This happened to me just now too... Kodak wants $175 to repair it. If you look near the hinge, you'll notice a small (at least I did) metal clip-like structure that is blocking the door's ability to slide back. I believe this clip tells the camera that the door is closed. I believe the clip is bent. If you straighten it, problem should be solved, methinks. I am needing to open this camera to solve this problem.
Feb 06, 2008 | Kodak EasyShare C875 Digital Camera
Kodak EasyShare C330 Digital Camera Logo
67 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
