SOURCE: I have a saeco Talea Giro machine. When I press
Check the screen on the brew unit, it might be blocked. If the brew unit is cleaned and the problem is still happening then the steam valve needs to be rebuilt because the pins are allowing the water pressure to pass through.
SOURCE: Saeco Talea Ring Plus
Grinder motor is not working.When the machine do the self test on startup, it senses the grinder motor is in open circuit(error 1).
Have to replace the grinder motor.
Remove the coff beans hopper.then..front spout by pulling the knob off and undo the screws...lift the top cover up from the back to unclick then pull the front part towards you from the center then slide over the spout area. You will see the grinder is covered with rubber cover with 4 screws holding it...remove the screws and then push down the rubber protrution through hole to detach from the grinder.The grinder is yours.
SOURCE: out of service [4] out of service [87]
Hi...itis not self testing..in otherword the motor in the gearbox is not working, either itis jammed with rust cuz' of leakage or motor is bad.
SOURCE: My Saeco Talea Giro have the wave like symbol with
It is saying..it's time to descale the machine. If you want to get rid of it, just press the water button and hold it for 5 secs.
