Question about Canon PC-795 Copier
Copies have white streaks like too much light
First thing to try is a new toner cartridge. It could be either running low, or defective.
Posted on Jun 25, 2009
Why do copies in color have multicolored streaks while black & white are fine?
There is a good chance that your color ink cartridge needs replacement. You can tray wetting a paper towel and putting in the microwave for 5 to 10 seconds then placing the cartridge on it for a few minutes. This sometimes will correct that type of problem...Be careful the paper towel will be hot (handle with care).
Aug 04, 2014 | HP Officejet Pro 8600
Hi, My Canon 3245 Imagerunner is streaking.
First, the streaks appears when copy from glass or adf, when printing or all?
Solution #1:
How many copies did you do from last drum changing? if over 80 000 copies, replace the drum unit.
-in case that streaks appears when copy and print
Solution #2:
If the streaks appears only if you copy from adf or glass, clean the glass and dry it out. Both glasses, narrow on left side beneath the adf/cover and glass for copy of original.
Solution #3:
If the streaks are wide and solid, with possible toner left overs, you need to replace fixing film.
Hope that helps!
Apr 04, 2011 | Canon ImageRunner 3245 Black and White...
Pale copies and two vertical white streaks
I'm afraid that regarding pale copies, you are better off checking your consumables (toner, fusers, etc) and then try talking to Toshiba. However, the vertical white streaks can be caused by excess ink and other contaminants on the inside of the printer. If you open the main door to both the printer and finisher (if fitted) and look at all of the visible runners, feeders and other handling devices, try to see if any of them line up with your vertical streaks on a page. If so, try manually rolling them and cleaning them thoroughly. This might help remove some of the streaking (it did on mine).
Hope this helps, Alistair
Feb 28, 2011 | Toshiba e-Studio162D Copier
Printed document has white streaks. I've replaced all toner cartridges AND replaced the toner waste unit. The streaking occurs when I print or copy but is much worse when I make a copy. Is there a printing...
If you are getting vertical white streaks or faded streaks from the top of the page to the bottom. It sounds like the developer blades in the imaging unit needs to be replaced. It cost around $120 to replace, but after a while it will happen again. This is a common problem with this printer. It can be cleaned by taking the unit apart and cleaning the developer blades, if you are handy. I have posted detail instructions in my tips section. or you can click on this link:
http://www.fixya.com/support/r4120906-clean_developer_blades_samsung_clp_300.
Hope this helps.
Jun 13, 2010 | Samsung CLX 3160fn All-In-One Printer
I have a black streak all on one side when i copy ?
If it is just when you copy and not when you print then it is a cleaning issue. Toner cartridge would cause the line to appear on copies, printouts and faxes. There is a piece of glass inside the auto document feeder that is probably dirty. Open up the document feeder as if you were clearing an original document jam. Look for a piece of glass inside the ADF, it will run the length of the document feeder. There is probably some dirt or another popular problem is white out. Clean off the glass with glass cleaner or alcohol and it should fix the problem.
Oct 04, 2009 | Brother IntelliFAX 4100 Laser Fax
Canon pc920 black and white copier white streak on copy
PULL OUT THE TONER CARTRIDGE AND SHAKE IT, IF THAT WORKED A BIT BETTER THE CARTRIDGE NEEDS REPLACED.
Apr 07, 2009 | Canon PC-920 Black and White Copier
Copies have a white streak near right side of copy canonpc920
PULL OUT THE CARTRIDGE AND SHAKE IT, IF THE COPY IMPROVES ITS OUT OF TONERAND NEEDS REPLACED
Drum has 13% life left; white paper w streak in middle when you copy
Try taking out the cartidge and given it a light shake. If the white streak moves or changes then you are out of toner.
As for sending faxes, do you get an error message an any kind? Does it try to dial?
Jan 11, 2008 | Brother MFC 8500 All-In-One Laser Printer
Canon PC-795 Copier Logo
71 people viewed this question
old marine
old marine
