Question about Maytag MER5730 Electric Kitchen Range
Maytag Range MER5730AAQ front right burner died
I have a Maytag Range MER5730AAQ The front right heating element died. I replaced it and it still doesn't work. What other parts could I check (and how to check) that would not let the burner heat up?
  • 3,600 Answers
You need to replace the inner connetor to make it work.
Posted on Jun 24, 2009
When trying to turn on the front right burner it doesn't heat at all what do I need to replace?
Check the wiring to the element, be careful shock hazard. On my electric range the wires were broken where the element plugs in socket. Socket kits are about $9.00 us If you have a volt meter unplug the element and turn the control on if you have voltage then replace the element. Thanks Tom
Nov 29, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Where can I go and get directions on how to replace the front left element on my glass top Maytag stove model #mer5750BAW. The stove top has to be lifted and the element underneth needs to be replaced or...
Good afternoon. We are Maytag factory authorized service and parts suppliers and have all the solutions for your Maytag appliance issues.
We have the proper element for this model and can get it out to you asap.
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
from 7 AM until 7 PM CST and we will get your parts out right away.
We look forward to hearing from you. Thanks, Ella
Jan 15, 2010 | Maytag MER5750 Electric Kitchen Range
Electric burner does not heat up.
The reason for Maytag electric burner not to heat up is that the heating element had exploded and there was white powder all over the inside of the oven. Replacing the heating element will make it work.
Also would recommend having the following cross verified:
· Element terminals have loose connections? Reposition the element.
· Range element shorted out? Find out by testing; replace if needed.
· Burner switch is bad? Find out by testing; replace if needed.
· Element receptacle bad?
Thank You for using Fixya.com
Jul 28, 2009 | Maytag Gemini® MER6765BA Electric Kitchen...
Maytag Gemini Electric MER6770AAC
I originally posted this problem March 1, 2009 as Bodhi58 and recently had the problem fixed. It turned out the burner needed to be replaced as the wire was split in the burner. The part alone was $210 but the service charge.
Feb 28, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Replacing a radiant element on a maytag glass top range I'm having strange problems with the two right elements of my MER5770 The front larger dual element will only operate at high heat. When turning on...
If the burner is scorched or pitted, go ahead and replace it. New burners can cost anywhere from $10 to $40. Otherwise, check the burner's electrical connections to make sure there is solid contact. Jiggle the burner in its socket. If it is loose, then remove the burner—most just pull out of the electrical socket, although some are mounted with a screw. (Always unplug the range before removing a burner.) Slightly spread the two terminals apart for a tighter connection. If it still doesn't work, then replace the faulty burner with a functioning burner of the same size. If that burner works, then replace the bad burner with a new one. If it doesn't, then inspect the electrical socket for damage. If it's charred, replace the socket. To do so, remove the screws that secure the socket to the range and then unscrew the range wires. Attach the wire connections of the new socket to the range wires and reassemble the burner.
Aug 19, 2008 | Kitchen Ranges
yea sounds like an issue for sure, nut not with the element but hte switches instead, theres a short in one or the other( most likely the dual switch) i wouls reccomend replacing both the switches, the elemenst should be fine.
May 24, 2008 | Maytag MER5770 Electric Kitchen Range
Maytag MER5730 Electric Kitchen Range Logo
465 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
