Question about Maytag MAH2400A Front Load Washer
Unlisted error code on MAH-24 Maytag front-loading washer
We have had previous issues with change being caught up in the pump in our washing machine. A repairman demonstrated how to remove the pump, fish out the culporate quarter blocking the flow, and return the pump. This we have done previously with success. This time, however, when my hubby removed the problem, replaced the pump and turned the washing machine back on after reloading the soaking laundry, it turns on for approximately 10 seconds, then flashes "OE" with alternating tones (kind of like a siren). Water still sounds like it's pumping to the machine, but now our clothes are still trapped inside the machine. The auto-unlock didn't occur after three minutes of the power being turned off as well. We have to try something, as this is the "week between paydays" and we can't afford a repairman to come out for six more days - by that time, the laundry will be rather ripe and we will be clean clothes-less. HELP!!
  • Anonymous Apr 26, 2008
    I can't get the door to unlock on my MAH-24 Maytag washer. Isn't there a manual unlock somewhere?
  • ebeaulieu836
    ebeaulieu836 Jan 21, 2013
    what does error code 3E mean?
  • 146 Answers
Did you connect the wires back to the pump. The neutral runs through the pump winding and to the door interlock. Check the connections on the drain pump and the harness in general. Sounds like a broken connection somewhere.
Posted on Nov 05, 2007
Hoover 800rl wont spin
sounds like an issue with the progrmmer if it does everything else, or there may be an issue which a sensor has caught that causes it to desist from spinning. Probably needs a repairman to diagnose..
Jun 03, 2015 | Hoover Washing Machines
Ou Maytag Neptune Washer MAH-3 will not drain.
This problem was answered a couple of years ago in detail. A search should produce it. Search the name Scruggs.
Sep 02, 2014 | Maytag Neptune MAH5500B Front Load Washer
The washer ran fine then stopped with water not draining. When I push the on button I get a buzz or humming noise .nothing moves. There is no error code.
Sounds as if you have something doen in the pump preventing it from draining and in doing so shutting the machine off as a safety action. I think you can actually access the pump from the rear of the machine. just unplug the machine, prepare to get wet, take the back of the machine off, take the lines off the pump and check for the blockage.
May 27, 2012 | Maytag MAH6700AWW Neptune Front-Load...
How to open front panel?
if you have somthing caught in the drum try and take off the sump hose that connects between your pump and the drum at the bottom of the machine you may be able to fish it out with a wire hook
Nov 24, 2011 | Miele Washing Machines
What is error code n d on Neptune front load?
Hello & Welcome to FixYa
ND error in your Maytag Front Load washer indicates no drain issue. To start with check the drain hose for any clogs and try cleaning it, then check restriction in drain pump assembly or loose wire at the pump. Please get back to me if you have any other questions.
Aug 01, 2011 | Maytag Neptune MAH5500B Front Load Washer
Washing machine is giving off an odd smell.
Had same issue with our unit. Tech. from sears told us some water remains in pump area &hose from previous wash cycle. PS Clened out pump removed h20 from hose two weeks later odor was
Jul 18, 2011 | Kenmore Washing Machines
Someone put some heavy things in it and it stopped mid-cycle. We removed the heavy objects, and then attempted to drain the leftover water by putting it on "rinse and spin." It never really...
The ND error code on a digital Neptune front load washer. The ND code means 'No Drain' and it is probably just something caught in the pump. Sometimes this is a early sign of the pump going out or a control board issue.
Nov 23, 2010 | Maytag Neptune MAH5500B Front Load Washer
Something loose between the drums
how did the underwire get there, you may want to remove lower panel please unplug washer before removing panel use a flash light there is a area were coins and other objects fall in to also have a bucket there well be water in the lower unit use something to fish it out lucky it did not get caught in pump
Nov 25, 2009 | Kenmore HE2 Plus Front Load Washer
ND Error code
Error code "nd" means it is not draining. Click on this link to get the user manual:
Then click on "GET THIS MANUAL" to download the manual.
Not draining can be caused by the controller, pump, solenoid valve, or clogged drain.
If this information was useful, please select YES to the first to rating questios. Good Luck and thank you!
Oct 22, 2009 | Maytag MAH2400A Front Load Washer
Maytag MAH2400A Front Load Washer Logo
424 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
