Hello, i have a magnavox rear projection tv, model number FP4630-W104. I tried to replace my bulb fluid without taking out my bulb first and spilled some fluid on my focus/screen distributor box no fluid got anywhere else fortunately. I learned my lessson:). The fluid made my distributor box smoke for about 10 seconds then I heard a loud single pop. I ordered and installed a new focus/screen distributor box for the tv but the bulbs still don't fire up. The green power light turns on in the front of the tv and the sound works. I checked the main fuse on the power supply board and my meter says there's 120v present. I checked everywhere for somthing burnt or another fuse with no luck. Every power reading on the main circuit board reads 58v so does the powerline going to the main board from the power supply board. Can you please help me.
  • 11 more comments
  • mwaterstreet Jun 24, 2009
    I have been checking all the components for the last couple days and the back of the boards and can't find anything that looks burnt out or bulged.
  • mwaterstreet Jun 25, 2009
    Hello, i have a magnavox rear projection tv, model number FP4630-W104. My screen/focus distributor box went up in smoke for about 10 seconds then I heard a loud single pop. I ordered and installed a new focus/screen distributor box for the tv but the bulbs still don't fire up. The green power light turns on in the front of the tv and the sound works. I checked the main fuse on the power supply board and my meter says there's 120v present. I checked everywhere for somthing burnt or another fuse with no luck. Every power reading on the main circuit board reads 58v so does the powerline going to the main board from the power supply board. Can you please help me. What could have went out? What does it look like? where is it located?
    Thanks for the reply. I checked all three section boards. Again 120v and 58v readings on main power board. 58v on all circuitd on main board A coming off of power board and 4v on convergence board. If this helps when I power on the tv all the bulbs light up but very dim. too dim to project any picture but they are turning on. ANY IDEAS. Its almost like Im not getting enough power to the bulbs but some is present
    I checked all 3 boards. Again the main power board has 120v and 58v circuits measured. The main board A connected to the main power board has 58v readings on every circuit. The convergence board has 4v readings. All the tubes dimly light up when i power the tv on but the bulbs dont power up fully enough to project an image
    Comment posted on Jun 25, 2009
  • mwaterstreet Jun 26, 2009
    I don't see anything that looks out of place. I metered all the boards. The strange thing i see is the power is 120v until right after the main power fuse which is good and then all the components thereafter turn into 58v. I read many posts and they say I am supposed to be getting 120v on the whole board?
    Yeah it is definately a voltage problem. I can see a very little bit of light in the bulbs when I turn it on. One post said to change my bridge rectifier on the main power supply board but the voltage leading up to it is 58v and coming out of it is 58v. This leads me to believe the the issue must be a component before it. There are only 4 components between the 120v fuse and the bridge rectifier. I triple checked them thoroughly and the bottom of the board for burns and nothing. Would it pay for me to replace these one by one?
    Here's the only good info I found on the internet concerning my set:
    OK, YOU NEED TO CHECK THE 120 VAC LINE FUSE'S, IT IS
    (F403) FIRST, THEN (F401) IS SECOND. IF THEY ARE GOOD,
    THEN YOU SHOULD HAVE 120 VAC ON PIN'S 1 AND 3 ON (L421).
    IT IS LOCATED RIGHT AFTER THE SECOND LINE FUSE( F401).
    IF YOU HAVE 120 VAC, THEN REPLACE THE BRIDGE RECTIFIER.
    ALSO CHECK THE LINE CORD FOR CARRYING AMPERAGE. JUST
    HOOK A LAMP ACROSS THE CORD WHERE IT IS SOLDERED TO
    CHASSIS,JUST TO MAKE SURE IT IS DEFINETILY GOOD. IT IS
    RARE BUT I HAVE SEEN CORDS GO BAD. THEY WILL READ
    VOLTAGE ON A METER BUT WILL NOT CARRY AN AMP LOAD. LET
    ME KNOW, GOOD LUCK
    On the L421 component I don't have 120v on pins 1 and 3 like he says i need but I do have 120v on pins 1 and 2. Pins 3 and 4 are 0V. Could this be the problem?
    thanks
  • 3,866 Answers
The fact you not getting power to the bulbs are these or any other cacpcitors bulging on any logic or power supply boards do you have bulging or leaking capcitors?
I would check this as this would cause the bulbs not to get full power.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Jun 26, 2009
  • Grand Canyon Tech
    Grand Canyon Tech Jun 26, 2009
    Right until it down converts to other devices with less voltages is why I though it was a capcitor issue. You may want to call manufacture for the service manual and see. Some Tv's vary and 120v whole board up until downconversion would sond feesable. I do not see how 58v can run 3 guns but if you can prove me wrong I would like to know the outcome.
  • Grand Canyon Tech
    Could very well be the issue.
    President:
  • 1,952 Answers
Check ur home electrical line......... no way contact ur service dealer
Posted on Jun 25, 2009
  • 790 Answers
Hi
Please check carefully the Un regulated power section, regulated power section, and oscillated power section. main power section is not 58 volts. please check carfully the three power sections this three sections is very important section..
Thanks.
  • 39 Answers
Double check for any burns or shorts and you may need a new bulb i know they're expensive so you might want to go to customer support on the magnavox website
  • 508 Answers
Sounds like the starter for bulbs maybe bad you may want to take to a reputable shop before it completely is rendered useless!!!
    Problem Solver:
  • 7 Answers
Pull your head out of your *** and go buy a ******* t.v
    Sergeant:
  • 353 Answers
Look thoruoghly over your printed boards for a severed connection(burn-out).
the power may have surged to another component
Posted on Jun 24, 2009
Why is my screen red when it should be black?
Search Results
    Philips Magnavox 8p6031c Crt Lens Fluid Repair Questions ...
    www.fixya.com/...philips_magnavox_8p6031c_crt_lens_fluid/page-11
    Recent Philips Magnavox 8p6031c Crt Lens Fluid Kit Dull Video Fix questions, problems & answers. Free expert ... Philips flat screen tv, Red flashing light. Light.
    Popular Philips Magnavox 8p6031c Crt Lens Fluid Repair ...
    www.fixya.com/...philips_magnavox_8p6031c_crt_lens_fluid/popular
    Popular Philips Magnavox 8p6031c Crt Lens Fluid Kit Dull Video Fix questions, problems & fixes. ... My son accidentally spilled water on our Philips tv and when i turned it on ... I need a screen replacement of philips tv 60" ... Why the tv come on but a min after the red blinking come on an it turn off by it self what the problem?
    Magnavox Projection TV problem... ' Techlore
    www.techlore.com/forum/thread/.../magnavox-projection-tv-problem
Jan 13, 2016 | Philips Magnavox 8p6031c Crt Lens Fluid...
Magnavox model # FP4630 W104 manual
GOOGLE THE MODEL NUMBER WITH MANUAL AFTER IT IF YOU NEED THAT.
In the TV menu make sure under audio speakers are switched on.
When you try to change the volume do you get a display on screen?
If the vol buttons on set work the issue is with the remote itself.
Let me know as much as you can so I can help
Mar 16, 2012 | Televison & Video
Where is the reset switch on 52 inch magnavox model #fp5210 w104
This model does not have a reset switch of any kind.
What is set doing or not doing?
Steve
Oct 03, 2011 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 9p6034c bulb is bad
If you have to replace one, they are very difficult to pull out and replace. You must do a convergence on the color of the tube you replace. You will be replacing a picture tube not a bulb. You may need to replace the fluid in the one tube. Or you may have a convergence problem. You need a TV tech to reveal that the problem is not a bad picture tube....which is rare in your case! Good Luck and thanks for asking!
Jun 12, 2010 | Philips Magnavox 9P6034C 60" Rear...
Rear projection tv screen is dark
This unit does not have bulbs it has tubes.What is happening is the coolant fluid in the picture tubes is contaminated with a fungus( blue and green).A repair shop should be able to fix this problem for about $250.I do not recomend fixing this problem youself,but when it is fixed this unit will look like new
Jan 12, 2009 | Televison & Video
Replacement Lenticular Screen for Magnavox TV
The screen is available from tritronicsinc.com for $239.44 using part number: 483536037078
Dan
Sep 01, 2008 | Philips Magnavox 51MP392H Rear Projection...
Big screen out of focus
ok you have to open the tv intill you see the 3 bulbs and the big mirror
the around each bulb is a wheel u have to turn that for the pic and focus
Jul 20, 2008 | Philips Magnavox 9P6034C 60" Rear...
Bad Picture on a Projection TV Magnavox 55P8288A magnavox
Change the coolant inside the CRT this will restore the color and clarity to 100% on your set.
May 25, 2008 | Philips Magnavox 51MP392H Rear Projection...
Color & sharpness problem
Sounds like you need Coolant fluid change, this is the fluid under the Lenses. If you have not done this before I suggest that you get some one who is qualified. Because if the coolant leaks and get to the circuit board, there goes your tv. You need new fluid in the 3 CRT's. If you look down with the back off and looking in the lense, you would see contamination in the fluid, this needs to be taken out and cleaned and replaced with new fluid. The fluid can come from places like MCM electronics corp.
Mar 19, 2008 | Philips Magnavox 9P6034C 60" Rear...
Magnavox Projection
What is model number? A magnavox 51MP392 is a CRT rear projection type and doesn't use a bulb (unless he was refering to the CRT's as bulb). And they are prohibitively expensive.
Jan 02, 2008 | Philips Magnavox 51MP392H Rear Projection...
Televison & Video Logo
273 people viewed this question
Top Televison & Video Experts
