Problem for Samsung Microwave Ovens
Generic problem for all Samsung Microwave Ovens
Samsung SMH 8165 ST E13 Error message. Ove...
Samsung SMH 8165 ST E13 Error message. Oven stops. Restart seems to work OK. What's up?
Clarification Request
Posted by MicrowaveSvc on Jun 29, 2009
E-13 T1 Max time error (oven did not preheat properly). PCB assembly. This can be due to improper power line voltage, a failing thermistor, a bad damper seal, or possibly a bad control circuit board. I would first verify proper operation with the manual, then if it still acts up I'd contact Samsung support. But really if it's out of warranty and works okay otherwise, it may not be serious to worry about. Does this help?
Popular Solutions for Microwave Ovens
Samsung SMH7178STD 1100 Watts Microwave Oven
1 Solution
Samsung 1.8 Cu. Ft. Over-the-Range Microwave - White
1 Solution
Samsung MW1080STA 1100 Watts Microwave Oven
1 Solution
Samsung SMH7174BC 1100 Watts Microwave Oven
1 Solution
Questions and Unsolved Problems for Microwave Ovens
I have a Thermador MBBS/01 that is only 3.75 years old. If I don't repair it, what should I replace...
(More)
I have a Thermador MBBS/01 that is only 3.75 years old. If I don't repair it, what should I replace it with? The Thermador MBES ($800) is suppose to replace it; however, a tech told me he thought the MBES specs were different and that I would have to also replace the $400 trip kit. Any advice?
Looking for a microwave that has more power, at least 1100-1200 watts, but is less than 15 inches...
(More)
Looking for a microwave that has more power, at least 1100-1200 watts, but is less than 15 inches deep and no more than 21 inches wide. Height is not an issue.
Microwave stopped working when the power went out When I plug it in nothing happens, no lights or...
(More)
Microwave stopped working when the power went out When I plug it in nothing happens, no lights or anything.
I replaced the fuse the power came back but when heating a glass of water the power went off again....
(More)
I replaced the fuse the power came back but when heating a glass of water the power went off again. Unit is sharp R 1451 about 13 years old. Should I buy a new one now?
name for small thermal like screen on right interior wall
