Question about HP PhotoSmart C4480 All-in-One Printer InkJet
HP Photosmart C4490 won't print
I have a HP Photosmart C4490 printer. I used it a few months ago on my Macbook and it printed some photos fine. It has been in my closet for awhile. I took it out today and tried to print some basic black text, but the page comes out practically blank. (There is just a faint gray line where an
was).
The black and color ink cartridges have plenty in them and have hardly been used. The copy feature does not work on the printer either, same result.
I have tried the function that cleans the nozzles and it prints out some purple text, but that does not seem right. Any ideas? Thanks in advance!
Teps on how to change jet ink cartridge where do i pull on the printer.
Posted on Jun 25, 2009
My printer is printing dark black at first then the bottom of the page is light black. I have tried shaking the ink cartridge and I don't believe it is old enough to be out already. I just replaced it a...
The amount of time is not a factor, it depends on how much printing you have done. If you have printed a lot of photos the ink get used very very quickly.
The way to improve the print quality is to use the maintenance option to clean the print heads, but it sounds like low ink.
Jan 19, 2011 | HP Photosmart C3100
Failure of Printer to Print Color
Try using a new HP ink cartridge. I had the same problem with a printer I purchased off of CraigsList even though the ink level was good. I installed a new color HP ink cartridge and it printed without a problem.
Jul 29, 2010 | HP Photosmart C3180 All-In-One InkJet...
New Cartridges - not all color ink printing!
It sounds that the ink inside the cartridge has partly dried up.
This can happen to my printer when I don't use it for a couple of months too.
Hope this helps!
Feb 04, 2010 | HP PhotoSmart C4180 All-in-One Color...
Cannot print 5x7 photo on Photosmart D7360,
if you dont hvae 5x7 option you can creat your won setting open printer adn faxes ...>goto file ..>server properties there you can creat it......
Oct 30, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
I am trying to print from the photo tray of my HP
Hello Michelle,
You have to go into your print settings of the application in use and select "Paper Type/Quality", then from the drop down menu you will see "Source" as an option, from there select "PHOTO TRAY".
Oct 13, 2009 | HP Photosmart Premium C309A All-In-One...
HP C7250 AIO won't print wirelessly from my laptop
Do Add Port in Printer Properties Ports tab and choose Standard TCP/IP. Enter IP address of the printer and follow steps to finish configuration.
Hope this helps!
-michan-
Jul 20, 2009 | HP Photosmart C7250 All-In-One Thermal...
HP Photosmart C4480 won't print
I had almost the same exact problem. Left the printer unused for a month or so, came back, no black ink being printed, even though the level was still sufficient.
What I did, was boiled a small pot of water, and held the black ink cartridge over the steam, about 3-4 inches above the boiling water, for 2 increments of about a minute. Try not to burn your hand or cook the cartridge lol. I wiped the cartridge head with a piece of paper periodically until I noticed a good bit of dark ink on the paper, then gently wiped the condensation off of the cartridge with a paper towel so as not to put a wet cartridge back in my printer. Put it back in the printer and voila!
Works great so far, although I can't vouch for the long term effects of this solution. I did look at the cartridge a bit later to make sure it wasn't leaking, and it wasn't. You have to steam it the right amount of time. I would guess that the printer cartridge head will inevitably dry out again with limited use. I'm hoping that it will keep working though haha. Hope this helps anyone else with this problem.
Jun 24, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Vertical and horizontal lines when printing photos - HP Photosmar
it sounds as if you may have the picture quality set to draft, its worth a check, especially if printing is ok. Does it print colour writing well too or just black, one of the colour inks may have a block or be low, go into printer settings menu and check what print quality its set for.
Apr 25, 2009 | Canon PIXMA MP780 All-In-One InkJet...
My hp photosmart c3180 is very slow printing photos
It is just normal, printing photos required more detail/refine and for best result it should be print slower than normal printing.
Apr 11, 2009 | HP Photosmart C3180 All-In-One InkJet...
HP Photosmart C5081 All-In-One Printer will not print in colors
i have hp c4180 all in one. new ink a month ago, have not used for a month, now it will not print????
Jan 03, 2009 | HP Photosmart C5180 All-In-One InkJet...
HP PhotoSmart C4480 All-in-One Printer  InkJet Logo
317 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
