Tablets & eReaders Logo
D
DIANNE GRANADE Posted on May 28, 2014
Coby not working
Has power - won't boot
Marco
Level 1:
New Friend:
  • Contributor 21 Answers
  • Posted on Jun 03, 2014
Marco
Contributor
Level 1:
New Friend:
Answers
21
Questions
Helped
3570
Points
54
1. Turnn completly off the tablet.
2. With the tablet turned off, holding the return button while turning on the tablet-pressing power button. Keep holding the return button until you see the Hard Factory reset screen.
3. Confirm the hard reset procedure. Once done, simply wait until process has finished-the tablet will restart. This process can take up to 30 minutes, so it's very important that the battery of the tablet is completly charged before attempting the hard reset. If you can connect it to the charger while resetting, even better.
1helpful
How do i factory reset a coby kyros mid8024?
There are two methods of reset Coby Kyros MID8024:
1. Soft Reset
2. Hard Reset
Steps for Soft Reset:
  • Take out the battery.
  • Reinsert the battery.
  • Press and hold the power button for 10 seconds.
That's soft reset. If your device doesn't load after this, try hard reset.
Steps for Hard Reset:
  • Switch off the device.
  • Press and hold Volume Up + Home Button + Power Key.
  • After 2-3 seconds, release the Power Key.
  • You will enter boot screen, Select Wipe Data / Factory Reset.
  • Select Yes.
This will delete all the files including apps, personal data stored in phone memory. Don't worry it doesn't wipe off the SD Card so you should make a backup of your files stored in phone memory.
Coby mid7048 won't boot past Android screen and won't turn off
Press and hold the power button for about 20 seconds. It should hard reset. If it still get stuck. Power it off. Press the power button then press and hold the power + silver back button for about 8 seconds. You should get a menu that will allow you to factory reset the tablet.
My coby MID7012 isn't going to the home screen after I charged it. Its flashing coby over and over. But its not turning on. What do I do?
Sounds like you are in a "Boot Loop". Let's try to break the Boot Loop. Plug the device into the charger, then press and hold the power button for 60 seconds - make sure the device is OFF after the 60 seconds. Let change overnight. Next Day, unplug the device from the charger, then press and hold the power button for 30 seconds, wait 30 seconds, press and release the power button normally, the device should be out of the Bootloop.
My coby kyros won't turn on please help me. I really need to solve this.
sometimes it get over heating soo give it some time to cool of !!
Stuck on and won't shut off
Hold the power button down for at least 10 seconds..
2answers
Tablet crashed won't do anything
coby has recently had major tablet problems,call manufacturer.send 15.00 money order.
My kyros coby mid1024 4g cannot boot?
i have the same problem,did you find something?
Coby mid 1125 wont boot up
did you buy it from a reliable source? lots of bad tabs and "pads" being sold online lately. might be bad internal power source. suggest take it to local dealer and let them troubleshoot, take the advice then fix yourself if you are good with electronics, or let them fix it or trade it in.
21helpful
3answers
My coby kyros won't turn on, won't charge, no lights are coming on
Mine does that to but all I ever do it just hit the reset button on the back and it turns back on.
Top Coby Tablets & eReaders Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Kolbrun...
Are you a Coby Tablet and eReader Expert? Answer questions, earn points and help others
