A/C is blowing warm on a 2005 Trailblazer
I need to find the low pressure service port.
  • 434 Answers
Not for absolute sure on this, but look on the passenger side firewall. There is a round aluminum can. That is the filter/drier. The port will either be on it or on the line coming out of it running toward the front of the motor. Hope it helps.
Posted on Jun 25, 2009
Why does the compressor run only for about 5 minutes then shut off, leaving the fan still running?
It seems that you have a system short. You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset.
If this doesn't help I would recommend calling a ac service company.
AC Repair Coral Springs
Apr 24, 2015 | Heating & Cooling
Where is the low pressure port for a/c 2005 dodge magnum
The low pressure port is usually right in front of the High Pressure port closer to the front of the car. They are usually within 3inchs of each other. If you are having a problem with a/c make sure that you check the belt for the compressor. We just had this happen, started blowing just air not cold, thought it needed a charge, turned out the belt was broken, and just sitting inside the area where it goes, replaced it, and all was good. Need to say, it was not easy on the 300M. Good luck
May 27, 2014 | 2005 Dodge Magnum
2005 pt cruiser ac is full of freon but will not blow cold air
Are all the pressures correct, 28-32 PSI on the low side pressure port? check it. If they are you may need a blend door replaced, this requires the dash be removed form the car completely.
Jun 15, 2012 | 2005 Chrysler PT Cruiser
I have a 2004 Trailblazer and my rear a/c starts out blowing cold air but gets warm shortly after but the front a/c keeps blowing cold air all the time???? what could cause that ????
Just a little low on freon can make it get too cold and it freezs if you in position to check the freon level you'll find with the system on high and the engine reved up the low pressure is below 25PSI. fill it to reved up is above 25 and your problem will go away. Low on freon will make it cold enough to frezze up and then warm up as the air does'nt go though the ice. it'll work good as you start up till it frezzes and after it's stopped up with ice it blows warm (it's really too cold). the more freon in the system the warmer it'll all blow because all the pressures are higher and it's the difference in pressures that make it cold.
Aug 24, 2011 | 2004 Chevrolet TrailBlazer
1999 GMC Sierra 1500 A/C blows warm air when idling
the low pressure port is the charging port, this port is either in the low pressure line or the accumulator that the low pressure lines to to (can shaped object), the low pressure line is the larger of the two lines from the compressor.
May 27, 2009 | 1995 Chevrolet K1500
Ac is blowing warm air in my 2005 sierra 2500hd duramax. Any idea
Your system has R-134 Freon in it. the 134 is made up of smaller molecules than the old R-12. The R -134 permeates through the rubber parts of the system. If the system gets too low on Freon, the compressor will stop coming on.(low pressure cut out switch). Have the system serviced with an A.C. machine that can vacuum, measure the amount of Freon in the system, and add the right amount. The machine can also inject die. Later the die will show up under a black light.This will show any leaks you may have.
May 23, 2009 | 2005 GMC Sierra 2500HD 4WD
2005 Dodge Durango won't blow cold in front!! Rear air works fine
you are bodging it and as you dont know anything about the A/C system then leave well alone and get it done with a machine.the whole system needs to be evacuated oil drain needs to be measured then refilled with the correct grade of oil and then regassed with the correct WEIGHT of gas and possibly a leak sealer added using special equipment.If it still doesnt work properly then it needs draining again and the venturi valve removing and checking out on the front unit.This is a specialised job for highly skilled operatives with the right equipment
Feb 27, 2009 | 2005 Dodge Durango
1996 cadillac deville
You need to re-fill your Freon gas, he is finished real fast...
Jul 02, 2008 | 2005 Cadillac Deville
Heating & Cooling Logo
140 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
