Question about Sharp XL-MP130 CD Shelf System
CD'S wouldn't play or come out
I had five of my favorite CD's in and could not get them back. I freaked! My son and I just removed the trays entirely to get back the CD's, which we did. Now my questions is can I put the trays back into the player and will they work again? The radio is working fine, but I miss playing my CD's.
  • 86 Answers
There is a small wole in the tray, you can open the tray by incerting a samal stick inthat wole and then press that causes the tray to open.
Hope this help
Posted on Jun 24, 2009
My CD tray will not close after removing a fragmented disc that got stuck
You have damaged the CD loader tray, best thing to do is just replace it, they are not repaired.
Jul 15, 2017 | Dell (0R649) CD-RW Burner
My CD rom is not working
No matter what type of laptop you own or how you use it, the CD-ROM or DVD drive is an important part of the unit. With the CD or DVD drive in place, you can play your favorite music or watch your favorite movies, so when that CD or DVD player stops working it is important to get it back in service as soon as possible.
1.Locate the bypass hole on the CD-ROM drive. There is a very small hole, generally located underneath the eject button, on every CD-ROM drive. Unbend a paper clip and insert it into the hole until the CD tray pops out.
2.Remove any CD that is in the tray and replace it with a CD laser lens cleaner. These laser lens cleaners are available at computer shops and electronics retailers.
3.Run the laser lens cleaning program, then try to play a CD again. If that CD fails to play, replace it with another CD and try again.
4.Shut the computer down and remove the AC power cord if cleaning the laser lens does not resolve the issue. Turn the laptop upside down and slide the battery release lever to the unlocked position.
5.Remove the battery and set it aside. Then locate the screws that hold the CD-ROM drive in place and remove those screws. Slide the CD-ROM drive out of the bay, then slide it back into the bay until it snaps securely into place. Replace the screws that hold the drive in place, turn the laptop back on and try to read the CD again.
6.Log on to your computer and right click on the "My Computer" icon. Select "Properties" from the menu and click on the "Hardware" tab. Click the "Device Manager" button and expand the CD-ROM section. Right click on the CD-ROM and choose "Update Driver" from the menu to download and install the latest device driver from the CD-ROM manufacturer.
I hope you find it very helpful. Thank you for using fixya
Aug 18, 2011 | Lenovo 3000 Y410 Notebook
X box cant not rid the games ask m to hopen tray in all cd
If your Xbox 360 will not play your games this is because of the sensors on the back of the drive overheating it is not normally the laser.
Luckily you can fix this yourself and get back to your games and to do this you need the proven Xbox 360 Repair guide.
Or you can send it in and they will fix it for you the repair will take about 4 weeks.
You can use the recommended guide to fix this and get back to gaming.
Mar 10, 2010 | Microsoft Xbox 360 Console
The stereo works fine but i cannot eject the cd's
I just had the same problem with the same model. Disc five was saying no disc and would not play any other discs. I opened the radio and found the the CD tray was missing a piece for disc five. You have to put the disc tray back into the holder to fix it. Make sure it locks in place and you should be able to get the rest to work.
Feb 11, 2010 | JVC HX-D77 Shelf System
The xbox 360 elites keeps on saying open tray when trying to play
1, the disc may be dirty
2. the mian reason for this your xbox drive cannot read the disc , because the power of the lens is gone(not completely) ,
solution:
1. keep your disc inside the drive and switch off the console, again swith on try this 2 to 3 time
2. keep the console in vertical position or little slanding position(180 dg) make sure it does not fall
3. its better to buy hatddisc and load the game inside it , so that u lens life increased
4. change the entire drive
Feb 09, 2010 | Microsoft Xbox 360 Console
Clarion 635
I just fixed mine and the problem was one of the cartridge trays that holds cd's had come out and was sitting outside the cartridge and over the top of the assembly that "collects" the disc to play.
If you can easily remove the entire unit from it's mounting brackets, then I have a solution. It might sound tricky, but it's actually pretty easy.
Once you've removed the entire unit, place it on a table to work on. Remove the front plate (this is the part that has the hinged door on it to protect the cartridge and inside mechanisms) by carefully sliding a thin flat screw driver along the plastic edge where it connects to the metal box. There are several tabs that just have a friction fit holding it in place. Be gentle as to not break the top plate.
Once the front plate is removed, you'll find two very small black screws on each side of the metal box/case containing the cd player. (The top half of the case.) Once you've removed the four small screws, you can lift off the top of the metal case and expose the cartride and cd player. At this point, you'll probably see that 1 or 2 of the cartride trays has come out of the cartride and are sitting over the top of the cd player. Gently push the trays back inside the cartridge.
Once the trays are back inside, you can take the entire back over to the power card, plug it in and see if when you hit the eject button if the cartridge pops out. If it does, you're almost done.
Go ahead and slide the top half of the metal box/case onto the unit. Replace the 4 small black screws on the sides. Replace the front plate carefully. Remount the unit in it's original location. Plug it in and you're done.
Feb 03, 2008 | Clarion DCZ625 6-Disc CD Changer
Mx-d402t jvc cd player - trays will not open
its close to 8 years old what do you expect i have one and its trays failed a long time ago
Jan 04, 2008 | JVC MX-D402T Shelf System
CD changer eats CDs
Sounds like its time to take the cover off (after unplugging the unit of course). Sorry to hear you are having a problem. Good luck.
Jul 13, 2007 | Kenwood CD-404 5-Disc CD Changer
Sharp XL-MP130 CD Shelf System Logo
311 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
