Question about Epson Computers & Internet
When copying the printer works but when work is
Work600. when copying the printer works but when work is finished the list is clean;
a scanner does not work also.
Thank you
Konstantin
I just turned  the printer off for a few seconds and turned it on again. Everything is OK now. K.
Posted on Jun 25, 2009
Printer works, scanner/copy does not
The problem could be because of ONE out of TWO problems listed below. Try the steps recommended and it should fix the problem.
Thanks,
Abhishek
Jan 24, 2010 | Dell 924 All-in-One InkJet Printer
Scanner has stopped functioning
ou need clean install . disconnect scanner remove all software in the add/remove area and go to device manger and remove scanner form list. then install software first,rebot, before installing scanner.should work then and for technical support contact us at http://tinyurl.com/mtgjzz
Jun 22, 2009 | HP Photosmart C5180 All-In-One InkJet...
I need a scanner that will scan 10X14 pictures
I found some scanners for you listed below but,
You can also scan large pictures in sections, and then use a program like STITCHES. Basically you scan it in quarter sections and then create a working board in your photo program and then you copy and paste each section into that board and line up the edges.
This is what most people do rather than buy a very expensive large format scanner.
Some large companies also have large scanners for maps etc. If you know someone who works for a very large company or one that does surveying etc. They may do this favor for you.
Though copy stores may have the size you need, copywrite issues will be asked about.
Here is the list.
large format scanners http://www.microtekusa.com/lf.html
Microtek ScanMaker 9800XL Scanner
Price: $1,038.31, 12-by-17-inch tabloid size bed
Mustek Scan Express A3 1200 Pro USB Large Format Scanner
$154.69media_size_maximum: A3 (11.7 in x 16.5 in)
http://www.contex.com/english/scanners/sd_series_scanners.aspx
Maximum Scan Width 44in.
http://www.xerox.com/digital-printing/large-format-printers/large-format-scanners/enus.html
Input Size:Min: 4.5" x 5.5" Max: 42" x 100'
Thank you and good luck.
Oct 25, 2008 | HP Computers & Internet
Brother DCP-110C multi-function, printed image has shadow/double image. scanner seems to work ok. not really use copier. i need to correct printer to print regular text/image. thank you.
Press Ink.
Press up or down arrow buttons to select Cleaning.
Press Set.
Press up or down arrow buttons to select Black, Color or All.
Press Set.
The DCP will clean the print head. When cleaning is finished,
the DCP will go back to standby mode automatically.
If you clean the print head at least five times and the print has
not improved, call Brother Customer Service
Aug 21, 2008 | Office Equipment & Supplies
Black line along page in copy and scan modes,not in print mode
Your scanner lamp is dirty. Take apart the scanner glass and clean the lamp. (Look for contaminated spots on the scanner lamp).
May 23, 2008 | HP Photosmart 2575 All-In-One InkJet...
Dark strip
LIFT THE COVER UP AND CHECK FOR A SOMETHING ON THE NARROW GLASS IN FRONT OF WHERE THE FLAT BED SCANNER SCANS .
COULD BE WHITEOUT OR GREASE MARKER OR EVEN A DIRTY PEACE OF PAPER
May 08, 2008 | Xerox Phaser 3200MFP/N Laser Printer
R40 Scanner Failure
Hello I have a little problem my printer print well for scanning it is not tell me what I have to do and the copy too doesn't work properly.
thank you for your help. May God bless you in everything that you udertake in life. keep on
Apr 16, 2008 | HP OfficeJet r40 InkJet Printer
Brother MFC 8440D
Look where you put the paper in. See if you can see inside there and see the roller that turns and picks up the paper. If you can, make a mixture of alcohol and a little dish soap. Damp a rag with it, and reach in there to clean the rollers.  See if the rollers will turn manually, but be careful not to force anything.  Another way to get to the whole roller, would be to start making a print, while watching the rollers.  As soon as the rollers have turned half way, unplug the printer.  Now you can reach the other side and clean that.
There is another way to clean the rollers.  Using the alcohol mix, take a single sheet of paper, and damp one half of it with the solution.  Stick the single sheet in the paper tray, and make a print, but hold on to the paper so that it doesn't feed through the machine.  Do this several times, and the rollers turning against the wet paper should clean them.
Try to print again. It might take a few tries. The rollers have to turn against the paper and dry themselves off again.
If this works, then you need new rollers (cleaning them will only make them work temporarily and the problem will come more frequently until you change them).
Thankyou,
Oct 29, 2007 | Brother MFC-8840D All-In-One Laser Printer
Scanner Error Turn printer off & back on
i m italian my inglish is not good... i solve the problem clean the guide of the carrel of the light... so i can run more easy...
Oct 23, 2007 | HP OfficeJet 7110 All-In-One Thermal...
Printing - using the 'copy' mode of the scanner
This suggests the the 'copy' element of the software is not VISTA compatible. In VISTA help in my computer - check out the 'compatibility' options and select an operating system that the copy function did work under
Aug 31, 2007 | Canon CanoScan N640P Flatbed Scanner
Computers & Internet Logo
54 people viewed this question
Top Epson Computers & Internet Experts
teamtech
teamtech
Are you an Epson Computer and Internet Expert? Answer questions, earn points and help others
