Question about Logitech Cordless Mouse
My Logitech mouse is uncontrollable. I changed
My Logitech mouse is uncontrollable. I changed the batteries in it but it still is not tracking properly. It jumps all over.
    President:
  • 3,278 Answers
It's probably one of two problems. Either you have spyware (install and run SpyBot, for example) or the scroll button is pressed too hard. Good luck.
Posted on Jun 24, 2009
Clicking issues on logitech wireless mouse
  • 1 Use the mouse on the same side of the computer where the Logitech USB transmitter is attached so there is a clear signal between the transmitter and the mouse.
  • 2 Check the USB transmitter that comes with the Logitech mouse to be sure it is correctly plugged into the computer. The red LED should be illuminated on the transmitter if it is connected properly. If not, the signal cannot reach the wireless mouse.
  • 3 Turn the mouse upside down to check the on/off switch. Be sure it is switched on.
  • 4 Check the battery compartment by sliding the top housing off the mouse to confirm the rechargeable batteries are installed correctly.
  • 5 Charge the batteries if the mouse LED does not illuminate. The charger cord plugs into the front end of the mouse and the other end connects to a free USB port on the computer.
  • 6 Clean the desk surface or other flat area if the mouse is not tracking. The problem could be dirt or grease interfering with the tracking ability of the device.
  • 7 Open the Logitech software called SetPoint, which manages the mouse, to troubleshoot button functions. Open the program by double-clicking SetPoint from the list of software on the computer, then click "Mouse Settings." Click the "My Mouse" tab and check (or uncheck) all the task boxes that are desired for operating different mouse functions, then click "Apply" and "OK."
  • Mar 17, 2012 | Logitech Cordless Mouse
    Mouse not working on mouse pad anymore after it showed that batteries are low, of course i changed the batteries
    I'm assuming it's an optical mouse, but a few details are lacking in your post. Is it the same mouse pad that you used before you changed your batteries? Is your mouse pad shiny? Because that will affect the performance of an optical mouse. And really, and optical mouse doesn't need a mouse pad. If it works OFF of the mouse pad, just get rid of the pad.
    Jan 31, 2010 | Logitech Cordless Desktop MX3200 Laser...
    Cordless mouse for laptop how do I open the back to change the battery
    Flip the mouse over there is a plastic cover below the track ball which if you push towards the ball itself will reveal the batteries.
    Good luck
    Nov 02, 2009 | Logitech Cordless Mouse
    Wireless mouse jumps uncontrollably. Has new batteries.
    look at the middle of the keyboard you will see an acupoint mouse try raising it up or adjust it to a suitable position.
    Aug 01, 2009 | Dell F3534 Touchpad
    Logitech v220 cordless mouse - worked fine for 6 mths - recently changed battery. worked fine. today, would not move cursor when on a white / light surface (although it has previously just fine). It...
    Most opticals do not track on smooth white surfaces. It needs textures or color. Try pressing the "CONNECT" button on the bottom of the mouse and on the remote sensor.
    Jun 17, 2009 | Logitech Cordless Mouse
    My Logitech wireless mouse is not tracking consistently.
    hello,have you tryed cleaning the bottom of your mouse any dirt of debre can cause a bad mouse curse movement also have you checked to make sure you have updated drivers for your logitech devises ?
    Mar 31, 2009 | Logitech Wireless Access Duo Optical...
    Mouse cursor jumping uncontrollably all over screen.
    Your touch pad drivers need to be installed. Power off the laptop. Install an external mouse, power back on and install drivers. When finished, power down, remove the external mouse and reboot.
    Dec 29, 2008 | Panasonic Toughbook 29 Touch (P/N...
    I cannot pan with the mouse in Autocad or Revit.
    Go to START > CONTROL PANEL > MOUSE ..... Here you will find the Logitech settings. On the BUTTONS tab, you will see a diagram that numbers the buttons on the mouse as well as a table that shows what each button is assigned to. In this table, double click the number assigned to the mouse wheel (usually button 3) and reassign the wheel to MIDDLE BUTTON. This should restore your Autocad pans.
    Dec 08, 2008 | Logitech Cordless Wireless Optical Mouse...
    Logitech Cordless Mouse Logo
    161 people viewed this question
    Top Logitech Computers & Internet Experts
    micky dee
    Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
