Question about NetGear WG602 802.11g/b Wireless Access Point
I cant get to the gatway interface
I have used Netgear WG602v3 for a long time with only minor issue (wasnt able to set WEP)
Yesterday I disconnected it for a minute and now I am not able to see it at all or connect to it.
I have a router that I connect the Netgear to but it does not show on the list of devices of the routers interface.
The wireless is not working but the ethernet symbol on the netgear is switching from orange to green. The wireless symbol light is off.
I am trying to get to the NetGear gateway interface but it seems the router doesnt think it is connected.
I hesitate to conclude that the NetGear AP is bad since it was ok until I disconnected it yesterday.
Any ideas?
Many thanks
  • 1,272 Answers
It seems to be a hardware failure with the unit. Reset the AP using step below:
At the back of the router you will find a small tiny hole (which has a small button inside it). Press the button with the help of a paper clip. and hold it down for 30 seconds. After 30 seconds, please release the button and power off the device for 5 seconds.
Check if you are able to access its configuration page using the steps below:
1. Connect the computer to the access point.
2. Click start button (extreme bottom left corner of the screen) on the computer.
3. Click Control Panel from the list.
4. Click on Network Connections.
5. Right click on 'Local Area connection' icon and click on properties.
6. Select Internet protocol TCP/IP from the list of components and click on properties.
7. Select use the following ip address.
8. Assign ip address as: 192.168.0.90 ; subnet mask as: 255.255.255.0 and Default Gateway as: 192.168.0.227
9. Press 'OK' and 'close' the properties window.
Login to the access point page using the following steps:
1. Open a browser (Internet Explorer or Mozilla Firefox).
2. Access the router (usually http://192.168.0.227).
3. Login to the AP(User Name = admin and Password = password).
Rate it, if it helps.
Posted on Jun 26, 2009
Cant find wep key
You will need to access the router (via its local web address using a suitable web browser) Once you have provided the login information, surf to the wireless security section and either document the WEP key (if not encrypted) or change it. Understand that changing the WEP key will invalidate any else's access, so be sure to share the change. The WEP key may have to be done in HEX, meaning that it must be done with the numerals 0-9 and ONLY the letters A-F. The ket must also be a specific length, usually 13 or 26 characters depending on the requirements of the router.
Aug 11, 2011 | NetGear WGR614 Wireless Router
Hi, i have the Netgear N600 Wireless USB, wich works well on several routers, BUT doesn't want to connect to the MOTOROLA SBG 900 router. It finds the MOTOROLA ROUTER and prompt me to type the WEP...
You mention "the WEP security code of my internet provider, and from this either you mean the WEB of your Router that you provided that the other devices use, or you mean something like the user name and password that you use to log into the ROUTER to set the settings for it. I'd try to help; but, it's not clear what you are really having an issue with. You should be able to check any device that uses that router and get the information needed. But, mostly devices just need to have you put in the password, in this case the same WEP used on other devices, as long as you are using the same protocol in the new device this should work.
The other issue you have is that you list the model of a Netgear Router: WNDR3400100NAS but you call it a USB, which sounds more like a NIC (network interface card). So, there's confusion over what is trying to connect to what. Are you trying to connect a device, or another router to the first router wirelessly. And that's another problem altogether. So I see three issues with your description, could you be a little more succinct?
Jul 03, 2017 | NetGear WNDR3400 N600 Wireless Dual Band...
How to enter WEP passkey for router when there are 4. using HP210
On your router set up interface you will find the wireless network key.
If it is WEP then it will show you WEP Passphrase and WEP Key.
You need to type in WEP key and not the passphrase. WEP key is 10 or 26 digit Hexadecimal number. You need to enter this 10 or 26 digit number.
open the set up page of the router and check the wireless settings of the router.
Click here for more information about the router and networking
Apr 19, 2010 | HP 2101nw Wireless G Print Server...
Netgear wg111t conection problem
  • log in to the netgear router's interface using www.routerlogin.com
  • username- admin , password : password
  • Click on wireless settings under setup . ( 3rd option from the top )
  • Under the security options .
  • U can find ur wep security passphrase to connect with netgear wireless.
In case of further assistance , do revert back
Feb 14, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
I need the netkey or webkey for my wgr614v8 netgear router. I can't connect to the internet from my laptop. It keeps asking for my netkey.
You need to connect to the web interface of the router from a PC, using a standard ethernet cable.
You then set the Wireless encryption (WEP key or WPA passphrase) in the Netgear router. Goto www.netgear.com to find the manual for your router if you don't have one.
You then have to set the same WEP key or WPA value in the laptop computer.
Oct 23, 2009 | NetGear WGR614 Router
Connecting then suddenly it disconnect.
change the channel to manual and try to change the channl to 11 or 9. disconnect the netgear and reconect it
May 25, 2009 | NetGear Wireless-G USB Adapter...
I do not know my wep key
Your WEP key is the security password that you set up when you set up your network at your home. This has to be done through your computer. When you log into your router you are able to allow certain items internet access. once you have that list created yu should have no problems.
Apr 10, 2009 | NetGear DG834G Router
I want to secure my netgear wireless router
Open the Interface of the netgear router. Go to wireless and further go to wireless security.
Select the WEP option in the same.
Do not Type anything in the PARAPHRASE
In the Number 1 feild type a 10 digit password.
Save all the settings and log out of NetGear.
Now you will have to use the same password to connect to the Wireless network,
I am sure that this would help
Please do rate the solution
All the Best
Sammy
Oct 26, 2008 | NetGear WGR614 Wireless Router
Netgear wgr614uk wep code
If you are the origional owner of the router, then you had set the WEP key, which is a password meant to prevent others from stealing your internet. If you still cant do it, Go to your routers configuration and restore it to factory settings. Then you can set your own WEP Tkip style passcode and connect the Wii wirelessly and correctly. For further help, just ask me.
Apr 14, 2008 | NetGear WGR614 Wireless Router
Netgear wirless router
Go to the web based interface, should be accessible by typing this address. 198.162.1.1 . Once there look for the security tab where it will ask you to choose wap or wep. Choose wep if available it's more secure, from there just follow the instructions to set a SSD and password .
Jun 10, 2007 | NetGear Super G WGT624SC Router...
NetGear WG602 802.11g/b Wireless Access Point Logo
262 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
