Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
"limited connectivity" message
I have a belkin F5D9231 v.1 wireless router and when i try to connect to the internet using it a message saying that i have limited or no connectivity to the internet but if i connect it with a ethernet cable it will work ive tried reseting it and rebooting and creating a new network didnt work eather i need help so help!!
    Genius:
  • 1,269 Answers
If it's limited or no connectivity, you might have typed the wireless network key incorrectly. It's case sensitive. If you don't have wireless security enabled, you can simply delete the preferred networks on your wireless connection window then disable any firewall you have like windows firewall, norton, mcaffe, zone alarm and the likes. Also try to change the channel on your router to 11 and that will solve your issue. Restart the computer after that.
Posted on Jun 25, 2009
My Belkin G Wireless Router (F5D7234-4 v5000) will not stay connected to wireless internet, I have had this problem since we first installed it. Help?
We wish a very Happy New Year.
What are the lights which would come up on the router when there is no wireless connection? Does it say "Limited or no connectivity"? call your Internet service provider and ask if your connection is under stabilization Period? Make sure that there are no other Wireless devices kept between Router and the computer.
Hope this helps. Cheers!!!!!
Jan 02, 2011 | Belkin (F5D8231-4) Wireless Router...
Router not working right
When there is limited connectivity check if the laptop gets an IP address from the router. ELse try configuring it manually. Restart the laptop if necessary.
Please rate if helpful.
Thanks
Apr 14, 2010 | Gateway 802.11g Wireless DSL/Cable Router...
Cant get my new laptop to connect to wireless - comes up with limited or no connectivity message. good signal strenght and laptop connects to other networks (eg at work) am worried that I have messed about...
Ok, the problem is that you can't connect to YOUR network right? Here's some things that could help you out:
  1. Make sure you reset your modem, simply unplug it for a few seconds. Then connect it again, select your network automatically.
  2. Make sure your internet provider's servers aren't down.
  3. Make sure modem is connected to your router properly.
Hope this helped. Good Luck!
Jan 03, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
My netgear usb connects to my wireless belkin..but no internet ?
this message comes when your computer is not getting the IP address from the router.
There are possible reasons for that.
1. DHCP on the router may be disabled.
2. If your network is secured , then you might not be typing the correct network key.
In both the cases , you will need to check the settings of the router.
You will need to access the router set up.
Click Here for more info about router settings
Nov 24, 2009 | Computers & Internet
I can't use my router
On internet explore type 192.168.2.1 into the web address bar and click enter. If it says not connected in the top right corner then run through the setup again.
Sep 24, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Belkin Wireless Router F5D8633-4 does not connect to the internet
Try first to connect to the internet using wired connection. If it connects, try to connect on wireless make sure the router is broadcasting signal.
Mar 16, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Connected with limited access
This actually sounds like the device is not getting proper DHCP settings.
First of all, power cycle the router, and reboot the computer to make sure a fresh connection from both devices is achieved.
If the issue persists, check to make sure the computer does not have any static IP settings stored in the adapter.
The following steps will tell you how to do so:
-Start
-Control Panel
-In Classic View, select network connections
or
-In Category View, select Network and Internet connections, then select network connections
- Right click the appropiate network adapter (Local Area Connection, for cabled connections, wireless for wireless connections)
- Select Properties
- in the "This connection uses the following items:" Box select the "Internet Protocol (TCP/IP)" (making sure to keep the checkbox selected (selecting the name helps) then click properties.
- If obtain an IP address automatically is selected (and the boxes below are grey), and Obtain DNS Server address automatically (again grey boxes below) are selected then something else may be happening, which will require more advanced steps.
If the boxes are not grey, then you may have incorrect settings, select the appropriate radio boxes (listed above) to make the boxes greyed out, and that may resolve your issue.
Feb 26, 2009 | Belkin (F5D7230-4) Router (587009)
Wireless Router use with Wildblue Satelite Modem
You should be aware of a class action lawsuit that Belkin and the complaintent settled recently. The lawsuit was filed complaining that certain Belkin routers did not obtain optimal speeds as advertised.
Belkin has agreed to provide affected customers a discount program to purchase a new router. You will need to search elsewheres for the details.
Sep 28, 2008 | Belkin (F5D5231-4) Router
Connecting belkin router
Hi!
How far are you away from the router to the bedroom?
What do you mean by "bedroom system"? Is it a wireless computer?
Apr 13, 2008 | Belkin (F5D5231-4) Router
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
289 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
