Just had to pair for a friend few days ago, Toyou press setupota will pair to audio, but not hands free talk. Not sure exactly what buttons to push on your particular, so I would suggest read your car manual for "Hands Free Bluetooth" Pairing, not just audio pairing. On Toyota that I paired, after you press setup Bluetooth you will have to press "Phone Off" button on your steering wheel to get into hands free pairing, but check your manual to be sure.
you should be able to press one of the buttons under the word unlock to unlock it then to program it you will need to pair it the phone the phone has a bluetooth menu which will say discoverable or something to that effect visible press it then put the hands free in pairing mode by pressing the button under pair or sometimes holding down the button til it says to pair or gives a strange series of beeps depending on the model then on phone hit serach for devices and thenit will ask for a password on both type 0000 and then its set up you can toggle on and off through the hands free option in your phones menu or if by any chance it gives a dial pad dial *228
hello switch the bluetooth on your phone go hands free if it has it click on hands free the press the button on the earpeice the phone should start searching for devices when it's found it it might say passcode enter
four 0000 thats it your connected good luck
In the instructions it says, "Loudness Control -- Press HANDS-FREE once, and then VOL button to select the loudness level from hi to lo. Press HANDS-FREE to confirm setting. Press VOL button to exit and to return to the main display screen.
The 3750 won't let you control the telephone record jack. The only way you can get a mic to work using the Tel Rec jack is by pressing and holding the 'Tel Rec' button for about 1 second. But this isn't compatible with the hands-free operation.
If you're looking to do hands-free recording, it uses the built-in conference mic. Press and hold the 'Conf Rec' button for about a second and it should start recording. This built-in mic is located on the right-hand side of the machine near the front by the headset jack.
If you want to control the machine via a foot control while in Conference Record mode, you'll have to change the 'Foot Control Dictate' setting in the menu. Here's how:
1) Press and hold the 'Erase' & 'Search' buttons for about 5 seconds until the menu appears.
2) Scroll through the options until you get to 'Foot Control Dictate' and set this to 'Yes'.
3) Press 'Stop' to exit the menu.
4) Press the 'Conf Rec' button to enter record mode.
Now you should be able to control the start/stop of the record function via the foot control.
PRSS HANDS FREE ONCE, AND THEN VOL BUTTON TO SELECT LOUDNESS LEVEL FROM HIGH TO LOW, THEN PRESS HANDS FREE AGAIN TO CONFIRM SETTING.....PRESS VOL BUTTON TO EXIT AND RETURN TO MAIN DISPLAY SCREEN. HOPE THIS HELPS - SHERRY
What model Panasonic phone?
