Question about Microsoft Xbox 360 Console
When I power on my XBOX 360 it says something about an update disk!
  • 37 Answers
What does it say fully?
Posted on Jun 27, 2009
Updates
Go to this page and download the file manually. You can then burn it to disk or transfer from USB.
http://support.xbox.com/en-US/xbox-360/system-updates/system-updates
Dec 07, 2011 | Microsoft Xbox 360 Console
335A-351F-2680-0F00-C000-0034
Your system was updating through a disk, if it has fialed then you must update manually with a USB Go to XBOX.com/support and look for the latest update
If your system is moddified then you must update your custome firmware and finish the update with the same disk.
Madden 12
Thanks
www.1RepairStop.com
We Fix Everything
Sep 03, 2011 | Microsoft Xbox 360 Console
Xbox 360 status code 3151- 335A- B800- 0F00- C000- 003A
Your system was updating through a disk, if it has failed then you must update manually with a USB Go to XBOX.com/support and look for the latest update
If your system is modified then you must update your costume firmware and finish the update with the same disk.
Madden 12
Thanks
www.1RepairStop.com
We Fix Everything
Sep 02, 2011 | Microsoft Xbox 360 Console
How to play xbox games on a new xbox360 slim 4gb
I am assuming you are referring to playing original Xbox games on your new 360. Halo was the only game from the box that you can play directly without needing to download the patch to play but supposed newer systems have the capability to play more directly out of the box.
Other backwards compatable games can be played but you will need a samll patch for each game. The game if playable will automatically attepmt to download the patch from xbox live. So you will need to have your Xbox 360 conected to live or have a patch disk. (which is available via the Xbox Magazine disk or can be downloaded online and burned to a disk)
Here is a link for Xbox games that are playable on the 360: http://en.wikipedia.org/wiki/List_of_Xbox_games_compatible_with_Xbox_360
"You can play some original Xbox games on your Xbox 360 console, if you have an Xbox 360 Hard Drive and the latest console software.
Information about how to update your console software is available on our Xbox support website:
support.xbox.com/pages/xbox-360/how-to/update-xbox-360/system-updates.aspx "
Jul 30, 2011 | Microsoft Xbox 360 Console
I put a game in the xbox 360 to let it load up at the main xbox 360 screen where you can mess with your profile and the game loaded up and when I clicked the game to load up so i could play it it said I...
Make sure the disk is clean.
Reinsert and try again.
If it does not try to update again and it tries play the game but does not work and it is not because it cannot read the disk then go to the settings, hard drive and go to "System Cache" and delete.
This will delete all temporary files. Which means all small updates for games will be deleted. I reccomend doing this as it may be an error due to the update being stopped halfway through therefore being unfinished. So the xbox may recognise that the update has been installed but because it is unfinished then it may not be able to start the game.
If this still does not work try disconnecting from the internet as it will not ask for an update and you will be able to play the game without it. If this does not work and the game does not play it may be a problem with the disk.
First I would suggest playing the disk in a friend's xbox. If it still doesn't work, take the disk back to the shop and get it replaced.
Mar 02, 2011 | Video Game Consoles & Games
XBOX 360 SOMETING DOES NOT SWITCH OFF AND PRESS THE POWER SWITCH
if your xbox 360 is one of the older ones or the first released xboxes then it could be the start of the 3rrod problem this type of error can occur when the motherboard starts warping and the solder joints are broken which can cause similar problems such as this. i would also try getting the very latest game you can and doing an update to see if this helps. you may also be able to download the update from www.xbox.com. burn the update to a dvd and then place the dvd inside your 360 and when asked if you want to update select yes and see if this helps.
Dec 11, 2008 | Microsoft Xbox 360 Console
Xbox 360 Update Failed
Does it happen when you try to play a game, or when you start up. If the updates arent working try to contact mircosoft
Oct 26, 2008 | Microsoft Xbox 360 Console
Hi, I'm still unable to update the xbox 360
your probably not doing anything Wrong.
did you boot the console then eject the draw, and put the update disk In ?
it should read the disk, then tell you it,s an update, and ask you if you want to update the console.
Make sure your hard-drives connected.
The only other thing i can suggest, is to make sure your 360 reads the disks or media your using.
if you try burning a music cd, and see if the 360 recognises it, you,ll know the media or Blank CD/DVD is good for the 360 to read. another method is to add a dummy file of about 80-100mb.
this ensures the 360 sees the disk.
try different media/disks and different methods.
if it still does,nt work for you. mail me your e-mail address and i,ll forward you 1 already made.
regards Mike @ compurepair.
Oct 06, 2008 | Microsoft Xbox 360 Console
Making an update disk
try burning on a dvd disk
May 10, 2008 | Microsoft Xbox 360 Console
Won't read disc's
theres a known problem with the hitashi dvd drive in the xbox 360.
the only solution to this is a home repair job, look up on youtube on how to do this, although this isnt recommended as it voids warranty.
so the best way is definitely just to ring microsoft and send ur console in for repair.
Dec 26, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
