Question about GoVideo Televison & Video
I now have 2 model# YGDD3817 and they both do the same thing. For an instant the picture and color are great. Then the picture, from top to bottom angles in and the color disappears.
    Sergeant:
  • 353 Answers
Sorry
these unit are plagued with problems.
hope you still have the reciept.
factory fix only
Posted on Jun 24, 2009
Samsung HLR DLP TV with white lines from top to bottom. First had no picture, bulb is 10 months new, I replaced the color wheel, and just put in a used DLP Chip. Picture came back perfect, but these w
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jul 18, 2017 | Samsung Televison & Video
JVC AV 60D501 H hold ?
What do you mean jumping, or does the picture look like it is in 3-D?
Aug 10, 2007 | JVC AV-60D501 60" Rear Projection...
Hitachi ultravision digital projection TV. The picture scrambles horizontally. The colors look fine. The picture is great for the first few minutes the TV is on, then it scrambles. I've unplugged it,
This sounds like a heating problem..Either there is something keeping the heat inside the cabinet like stuff on top of the cooling vents (also on the sides and bottom) or there is dust inside. Blow the thing clean with clean, dry compressed air inside the cabinet.
Jan 07, 2013 | Televison & Video
I just replaced the color wheel on my samsung hln5065w. Picture is great but there is a shadow on the right side of screen from top to bottom. The shadow on the top of the screen is wider across the screen...
Its a Good Possibilty that its the New Color Wheel causing this,if the colors are not complete on the color wheel then that will be why you are seeing shadow on right hand side of screen.
I know I ordered color wheel for mine and had to send it back,it did the same thing.
I compared it to the old color wheel and the new one did not have Solid colors on it.
Can you see picture behind the shadow? or is it shadow and no picture?
Mar 06, 2011 | Samsung HLN5065W 50" Rear Projection...
My samsung pcl6215r is having problems with the green screen. The red and blue colors are fine but the green wont line up with them and its making it out of focus badly. It doesn't appear to be dim or...
brent hardin,
Your description of the problem sounds like a convergence issue. You more than likely have lost the convergence ICs. They will need to be replaced and the convergence will have to be set. The green beam should not move. It is the standard which the red and green are moved to overlap. Since you have bow at the top and bottom I would replace the convergence ICs. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which explains the problem, how to replace the parts and where to get the replacement parts.
Thanks for using FixYa and for the great rating. Great ratings will keep the experts helping to solve problems. Thank you.
hardrocko
Nov 17, 2010 | Samsung PCL6215R 62" Rear Projection...
Colors have separated. and top and bottom af pictures are bowed. i have a sony kp-46s55. its about nini years old and it was free. currently the colors are separated and the top and bottom of the pict
nbad convergence ic , this need to be done by a profecional tv tech , because need to check for the pico fuse and resistor around the area
May 08, 2009 | Televison & Video
The screan is dark on the top and bottom and color is strong
This not the correct Model #, this model is a DLP set and does not have picture tubes and associated lenses. Did you remove the mirror? Does your set have a fold in back? I suspect the back is not fully out in the correct viewing position.
Dec 20, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Warping picture and color separation
The convergence chips and resistors need to be replaced. You can get a repair kit and photo instruction guide from www.TvRepairKits.com.
Sep 09, 2008 | Philips 46PP9302 46" Rear Projection...
Samsung DLP HL-P5674W Screen is stretched at the top and bottom...
did you ever find out the problem , mine is doing the same thing,
please email highltv3@aol.com if you can help
thank you so much
debi
Mar 05, 2008 | Samsung DLP HL-P5663W 56" TV
I have a Mitsubishi VS-60.. With a Picture
Vertical IC outputs , vertical Capacitors are most like the culprit on your deflection panel. good luck
Aug 16, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Televison & Video Logo
27 people viewed this question
Top GoVideo Televison & Video Experts
Marvin
Marvin
Demonic-2011
Demonic-2011
 Grubhead
Grubhead
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
