Question about Envision G22LWK 22" LCD Monitor
I cannot get my computer to recognize my dvi monitor
My system is new no os or anything it turns on and everything but it does not recognize my monitor so I never even see boot screens or bios.
how can I install an os without a vga and no adapter?
  • Jim Thurston May 11, 2010
    I had a simular problem recently. What MOBO and video card are you using??
  • 86 Answers
That is very weired, chose another type of conection with you videocard and monitor ex: hdmi cable if you have a hdmi output.
If not check the options of your monitor slow down the frequency to 60hz. I advise you to get another smal tft monitor from one of your friends to test may be thers a problem with your video card.
Hope this help
Posted on Jun 24, 2009
I would like to hook up my old monitor, product LT782s, model 700P, to my new monitor so I can have duel monitors. The cord has 2 screws to attach. The new monitor does not have any place for a "scr
You need to connect both monitors to a computer. Monitors do not daisy-chain (in general). The exception are some SCART-enabled monitors.
What is your source (desktop)? What is the make/model of your new monitor? Please add a comment with the video outputs/inputs for your source and second monitor.
Many newer desktops have two or three outputs. (Some video cards have display port outputs which with active adapters can support 2 monitors each.)
If your computer has two or more outputs and your new monitor has an input compatible with the extra output, get the appropriate DVI, DVI-HDMI or HDMI cable for your new monitor. See the next section if both monitors have VGA input.
If you have a desktop with only one video output, you may be able add a video card to support two monitors. (Depending on your computer, you may need to upgrade the power supply to support a video card.) Then get the appropriate adapter or cables to add the second monitor. (Note: if both of your monitors have only VGA inputs, check the specs for video cards carefully. Not all modern cards support analog outputs on their DVI, HDMI or Display Port connections. These digital outputs would require a digital to analog converter to give the VGA out.) However, if one of your monitors will accept DVI digital signals and the other VGA, add a card with one of each of these connections and a DVI cable to match. (This is an if needed extra; many monitors still ship with only a VGA cable.)
Then turn off your computer, open it and add the video card. Install the drivers with only one monitor attached. Then power down the computer and connect the second monitor. Turn on both monitors before turning on the computer again. Most of the time, the second monitor should be recognized (by Windows) and the appropriate refresh rate and resolution chosen. If not, you may need to enter the Display settings to set the monitor up.
I have seen some computers/video cards where only one output is initially enabled. You may have to go into the device settings to enable it. (Laptops often need their external video ports enabled in the BIOS.) Bad video ports/cards/cables do happen so RMA if needed.
The USB video adapter, http://www.newegg.com/Product/Product.aspx?Item=N82E16812225007 , can be added to a desktop to give a second VGA output but it isn't the best solution. USB bandwidth limits are significantly lower than those for a PCIe x16 slot or an old AGP slot.
I hope this helps. Please add more information about your system if you want more assistance with this problem.
(who has done dual monitors with older and newer computers. My old Pentium 4 with a Radeon x1350 video card was fine for driving a VGA monitor and an HDMI monitor (using a DVI to HDMI cable). My second generation i5 and P8Z68 motherboard system is also fine using the on-CPU video graphics for those same monitors. A video card would improve gaming but isn't required.)
Dec 13, 2012 | Computers & Internet
What cord do I need to connect my 1810 gateway monitor to my tower
Your either going to need VGA or DVI. You need to check the back of your computer and monitor to see which type of connection you have. Then plug in the appropriate cable.
Pic of VGA cable: http://www.ccrzone.com/attachments/Image/VGA_M-M_6_.jpg
Pic of DVI cable: http://farm4.static.flickr.com/3216/2995518986_9deb622bff_o.jpg
Jul 19, 2011 | Gateway FPD1810 18.1" LCD Monitor
My hp w2007 monitor keeps going to sleep mode when turned on with the computer on
I'VE BEEN HAVING THE SAME PROBLEM FOR MONTHS - SOMETIMES THE MONITOR WILL BE FINE FOR A FEW DAYS AND OTHERS IT WILL NOT COME BACK ON NO MATTER WHAT I DO. HOWEVER, I FINALLY FIGURED OUT THE PROBLEM AND THUS A SOLUTION AND IT ACTUALLY DIDN'T COST ME ANYTHING.
MY CPU DOES NOT HAVE A VGA OUTPUT SO I WAS GOING TO GO BUY A VGA/DVI CABLE ADAPTER BUT INSTEAD I FOUND A VGA/DVI ADAPTER IN THE BOX THAT MY COMPUTER CAME IN. I ATTACHED IT TO THE DVI CABLE THAT I ALREADY HAVE AND PLUGGED THE DVI END INTO MY CPU (SINCE IT ONLY HAS A DVI AND NO VGA OUTPUT) AND THEN THE VGA ADAPTER END INTO MY MONITOR AND WA LA... IT WORKS NOW AND HAVEN'T HAD ANY PROBLEMS WITH IT GOING TO SLEEP.
WHAT I IMAGINE IS HAPPENING IS THAT THE DVI OUTPUT ON THE MONITOR IS FAULTY - EITHER FROM THE FACTORY OR THE PINS HAVE BEEN DAMAGED SO MY CABLE WAS NOT WORKING CORRECTLY. IN TRYING TO FIGURE OUT WHAT WAS WRONG, I BOUGHT A BRAND NEW DVI CABLE AND IT STILL DIDN'T WORK SO I KNEW IT WAS NOT THE CABLE. THAT NEW CABLE WAS RETURNED TO THE STORE FOR A REFUND!
May 19, 2011 | HP W2007 LCD Monitor
Nothing on the screen at startup
If you cant get into the setup menu then I would think the monitor is defective,you did not state if you hooked up the monitor to a computer that has a vga port that works.
Jul 21, 2009 | LG 22" FLATRON LCD Monitor
Is this monitor compatible with any desktop computer?
Your monitor will work with any computer.
Note, if your monitor only has a DVI cable, then you will need a VGA to DVI adapter if the new computer only has a DVI port but most new computers will have VGA.
Thanks and please take a moment to give this solution a rating of fixya.
Mar 15, 2009 | AOpen 19" LCD
No signal from computer to monitor 8/13/08!
maybe your monitor is too old to your pc.. because it can't catch up the HI frequency of Graphics that you set up in your system.. but lets check first your system.. you need to get a new monitor or an extra one taht can capture the frequency of your system.. then ill give you the step.. here it is.. in windows XP,, right click on desktop then properties.. after you click the properties a windows will appear.. display properties..go to setting, below click advance., then find monitor in general tab. then you see there the monitor setting... try to change it to 60 hertz... then restart your pc then try to use your old monitor.. ^^
Feb 04, 2009 | Computers & Internet
Replacing monitor.
What type of monitor do you have? Most monitors will come with a DVI-to-VGA adaptor.(Sometimes and some models.) Also, when you say the monitor will not power on, do you see a message like "No signal detected" or anything like that or do you get nothing what so ever?
To verify it's not your system, connect a VGA monitor to your computer to see if it works. If it does, you know it is the monitor. Good luck.
Feb 02, 2009 | HP Compaq Presario SR1265CL-B...
Computer won't recognize monitor driver
Its the usb, if u connect the monitor via the standard port, the vga port, it will work. If your monitor only have an dvi cable you can fix that by an adapter. That adapter should be an DVI to VGA.
Good luck to you
Dec 11, 2008 | Acer AL2016W 20" LCD Monitor
Monitor goes to power save mode on startup
Sounds like a bad video card (if embeded "built in") then you need a new mother board
Dec 09, 2008 | Belkin (F6C800-UNV-PL) UPS System
DVI input on monitor not working
Contacted viewsonic about this issue- they suggested- have both dvi and vga hooked up to same machine. start with poweroff on both. power on monitor, then power on computer. when you see display coming from the vga, power off pc, then disconnect vga cable, turn off power to monitor, disconnect power cord from monitor for 5 + seconds, reconnect power cord, power on monitor, then power on pc.
If this doesn't work to get the dvi working, (as happened to us) we returned our monitor for a replacement, since it was still under warranty.
Sep 17, 2007 | ViewSonic VX2025wm 20.1" LCD Monitor
Envision G22LWK 22" LCD Monitor Logo
311 people viewed this question
Top Envision Computers & Internet Experts
Steve
Martin Murray
Dimitar Todorov
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
