Question about Pentair Challenger High Head 1.5 Hp Pump Up Rated
Challenger 1 hp will not pump.
I have a challenger 1 hp pump. It will only pump very little water. What could be the problem?
  • bryanesr Jun 25, 2009
    Thanks for the help. It was a clogged impeller.
    Problem Solver:
  • 7 Answers
Most common problems...dirty filter and/or clogged impeller
Posted on Jun 25, 2009
My pentair 2 hp challenger pump turns off after 4 second
since it's a new install is voltage set correct on motor ? this seems possible due to short run time you report
May 04, 2014 | Pentair 2 hp Challenger Pump
Pentair challenger hums but does not spin
check wiring see side of motor 120 volt vs 240 volt if 120 volt have to move some wires
Oct 02, 2012 | Pentair 2 hp Challenger Pump
Challenger pump leaking at the band
You may need a seal plate o-ring or you may have a shaft seal leak. See if you can determine if there is water running down the outside of the seal plate from where the motor mates to the seal plate.
Feb 15, 2012 | Pentair 1 HP Challenger Pump
Pentair challenger 1 horse pump; motor running ok, sounds a bit noisy, now does not pump at full force, water does not fill the pot even after primed start, pressure guage reads 0 psi before read 20...
check the impeller for debris. you will have to take the metal band off that connects the wet end to the seal plate. inspect the impeller for debris. lube all o-rings and reassemble. if that does not work, investigate a blockage in the suction side plumbing.
Aug 12, 2011 | Pentair 1 HP Challenger Pump
We have a Pentair Challenger 1 1/2 switchless motor. While running it is very loud...is this normal?
check amount of water pumping if pot is not full you could have somthing in the impeller like small leaves
Aug 21, 2010 | Pentair Challenger High Head 1.5 Hp Pump...
Why do front bearings go out on Challenger pool pump moters?
A leaking pump seal will let water migrate into the bearing which displaces lubricant and leads to bearing failure.
John
May 08, 2010 | Pentair Challenger High Head 1.5 Hp Pump...
I have a challenger pool pump that has a very high pitch sound
The motor bearings are probably starting to fail. If you winterize the pool I would take the motor portion off the pump and have a local electric motor repair shop look at it. A simple bearing change and new pump seal would run $50 or less at most places. If not, shock the pool and run the pump overnight to balance the water and then pull the motor for the repair. It will probably only take a day or so for it to be completed.
Aug 30, 2009 | Pentair Challenger 1 1/2 Hp In Ground Pool...
Our 1.5 HP pentair challenger pump isn't holding its prime
Usually, if a pump will not hold its prime, there is an air leak somewhere in the system. Things to look for are small leaks around the equipment-could be a bad o-ring. If you do not see any leaks, turn off the pump, remove the lid from the basket, check it for a hairline crack and check the o-ring under the lid to see if it is the cause of the loss of pressure.
Apr 26, 2009 | Pentair Challenger High Head 1.5 Hp Pump...
Our Pentair Challenger 1.5 hp self priming pump is squealing.
Where is the water leaking from and does the noise start only when the pump starts or the entire time its running..
Feb 09, 2009 | Pentair Challenger High Head 1.5 Hp Pump...
Pentair Challenger High Head 1.5 Hp Pump Up Rated Logo
317 people viewed this question
Top Pentair Garden Experts
Charles T Nevin
Charles T Nevin
David Burbee
David Burbee
Electro Med Services...
Are you a Pentair Garden Expert? Answer questions, earn points and help others
