Question about RCA HD52W59 HDTV Projection Television
Bulb type? I am trying to help a friend find a raplacement bulb, but I can't even find out the specific part #. ??? JMB
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 140 Answers
This TV is a CRT rear projection - It uses 3 picture tubes - not a DLP lamp.....
Posted on Nov 05, 2007
I have a Montgomery Signature Sewing Machine. I need a new bulb. How do I get one since Montgomery went out of business and where can I purchase one.
will be a 10 watt or a bit more and is available from most sewing machine shops ( don't get a bulb with too high wattage as it heats the end cover of the machine and burns the socket
bulbs are not manufacturer specific but are generic so take the old bulb along to get the same wattage and glass size as some globes are bigger in dimensions than others and will not fit in the end of the machine
Jan 02, 2017 | Sewing Machines
Honda accord keep burning low beam headlights
Sounds to me like you need to reset the headlight housings... maybe they are vibrating very badly. ... OR, easy fix, get NEW headlight housings on EBay and install.
Nov 28, 2011 | 2004 Honda Accord
What type of light bulb to use in oven?
According to the parts breakdown it uses a standard 40 watt appliance bulb,it say for the part# to buy locally so its a standard bulb since ge never even issued a specific part# for it
Aug 01, 2011 | GE Profile JTP18 Electric Single Oven
When failed trun signal bulb, Jeep turning signal is fastly blinking. I changed rear turn signal bulb with LED bulb, but turn signal blinking speed doesn't go to normal, At first couple of seconds it is...
Try replacing with the same bulb type as was failed. Flasher unit isusually reliant on resistence from the bulbs to what speed that side will flash at when powered.Some of these led type have less resistence and that equates to a faster flash speed.That is why when one bulb blows that side will flash faster or may even stay on without flashing.You could even swap the led to the other side( to confirm.Check with the bulb retailer to whether they have those bulbs with a higher rated resistence in led.If this vehicle has leds as standard,you may need to get the correct type from dealer. Hope this helps or get back with findings if it still has fault after replacing bulb.
Mar 29, 2011 | 2009 Jeep Patriot
How do I change the light bulb on the Harbor Breeze 52" Avian Brushed Nickel? specific directions please
I'm trying to change mine too. I can't figure out how to get the glass off it even.
Nov 29, 2010 | Heating & Cooling
Buzzing when dimmed
Hello
There are a few different reasons that can cause this issue, I'll try to be succinct.
1) Meeting or exceeding the switch load capacity - the switch's capacity should be embossed on the back of the switch. Total the bulb wattage on that switch and see how close you are. Even 375-425W on a 500Wmay buzz, a higher capacity dimmer may be required. 2) Is it actually the dimmer? Some switches actually cause the bulbs to buzz. These may be resistor-based dimmers, you will need a dimmer with an auto transformer component. 3) Is the dimmer rated for the bulb type on the circuit? A fluorescent rated dimmer may buzz with an incandescent bulb and vice-versa. 4) Some track lighting is low-voltage" rated, there are specific dimmers for this application.
Hope this helps.
Nov 27, 2010 | Leviton Decora Light Dimmer Switch
I have a five D cell Maglite. Seems to always
There are diffferent mag lite bulbs made for different amounts of batteries. Be sure that you have the 5 cell light bulb. Also try to keep your fingers off the glass. if you get any oils on it, wipe it off before turning it on.
Also you can get mag lite specific bulbs...they cost more but they're worth it.
Feb 03, 2010 | MagLite Flashlight Type: Black D Cell 5:...
Where do you begin raplacing a 93 4runner headlight?
if this has the old style bulbs you're on the right track--just havent found all the retaining screws however if this is the newer style with the small bulb it goes in from behind, some times the battery is in the way, but on this type there is a cap over the wires and a retainer which have to be removed
Oct 26, 2009 | 1993 Toyota 4Runner
I HAVE A GE MICROWAVE MODEL#JES1136WL01 I HAVE SEARCHED THE MANUAL OVER AND OVER AND FOUND NO WAY OF REPLACING THE LIGHT BULB. PLEASE ADVISE THANK YOU ...
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
The outer cover (wrapper) will need to be removed.
The screws you need to remove should be pretty obvious, and a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 26, 2008 | GE Microwave Ovens
RCA HD52W59 HDTV Projection Television Logo
65 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
