The control board looks like it was on fire all the fan relays areburnt and melted
SOURCE: circuit board burnt (goodman hotel unit)
make sure everything is wired up properly. make sure that your 24 volts is correct(low voltage and your 120 volt transformer.) make sure the breaker is the right rating /amp. check nameplate so you will know proper information
SOURCE: Friedrich model ss12j10 --compressor does not go on. Any possible
the refrigerant leaks or the thermostat is not working. i also got the same same problem and have the thermostat replaced by a technician
Most times the motherboard is the
problem that causes the solder to melt from a defective relay. You will need to
inspect the compressor start relay and capacitor to insure that they did not
cause the relay on the board to overheat. Also check that you have 12 volts dc
going to the evaporator and condenser fans while running because if for some
reason the fans are defective and you change the motherboard while one of the
fan motors are defective your new motherboard again can be damaged. Here is a
link to a=> Artica/Profile Service Manual
Here is a
motherboard test photo=> Artica
Profile Tech Sheet I will be glad to help answer any
questions you may have Thanks Sea Breeze
