Question about HP PSC 1610 All-In-One InkJet Printer
I have had the same print jam for 3 weeks!!! I keep trying to deal with it. I have cleared it, but everytime I print again, even test prints, it jams again, in exactly the same way. From what I can understand, the jam seems to be at the fusion/delivery stage. I have cleared it completely each time. I am wondering if I need to repair it, or just get a new printer as this one is a few years old and may be just worn out. Is there a special way to check the fusion/delivery portion?
    Scholar:
  • 169 Answers
Well you can try cleaning the rollers at the bck of the printer with a wet cloth and then try aligning the cartridges again..this should help.
Posted on Jun 24, 2009
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Paper keeps jamming
dear friend this printer is brand new/ old. if old how much old?
Jun 27, 2013 | Brother MFC 7840W Printer
Paper jam always.
Helo have you tried to check on the driving gears it but try to call your technician to check on it otherwise you may spoil your printer
Jun 16, 2017 | HP PSC 1610 All-In-One InkJet Printer
My printer comes up with a clear paper jam and press checked key. I have cleared all paper from machine and yet the light flashes and will not allow me to print and the same error code comes up. What...
Solution one: Turn the All-in-One off and on again Follow these steps to turn the product on, and then off again, to reset the print mechanism.
  1. Press the Power button (c01602202.gif ) to turn off the product.
  2. Wait 15 seconds.
  3. Press the Power button (c01602202.gif ) to turn the product on again.
    NOTE: The product might go through a warm-up period of up to two minutes. The product lights might flash and the carriage might move. Wait until the warm-up period is complete before proceeding.
  4. Try to print a self-test report. See the steps on how to print a self-test report at the top of this document.
  • If these steps resolved the issue , and the self-test report prints , there is no need to continue troubleshooting. Reconnect the USB cable, and then try to print again.
  • If the issue persists , continue with the next solution.
  • If the self-test report does not print , continue with the next solution.
Solution two: Clear any paper jam Jammed paper can cause the carriage to stall. Follow these steps to clear any jammed paper. Step one: Remove any loose paper Remove any loose paper from the input tray and output tray. CAUTION: Do not remove jammed paper at this stage. Trying to clear a paper jam from the front of the product can damage the print mechanism. Step two: Clear the paper jam from the back of the All-in-One Use the following steps to check for and remove jammed paper from the back of the product.
  2. Disconnect the USB or Ethernet cable from the back of the product.
  3. Disconnect the power cord from the back of the product.
  4. Remove the rear door. Push the door latches toward each other, and then pull the door away from the product. Figure 1: Remove the rear door c00244379.gif Illustration of removing the rear door
  5. Gently pull the paper out of the rollers. CAUTION: If the paper tears when removing it from the rollers, check the rollers for torn pieces of paper that might remain inside the product. If any torn pieces of paper remain inside the product, more paper jams are likely to occur.
  6. If you are printing labels, see if any are missing from the label sheet. If any labels are missing, find them inside the product, and then remove them carefully.
  7. Reattach the rear door. Gently push the door forward until it snaps into place.
Step three: Clear the paper jam from the front of the product Follow these steps to remove the paper jam from the front of the product.
  1. Open the cartridge access door. Figure 2: Open the cartridge access door c01913998.gif Illustration of opening the cartridge access door
  2. If you find paper jammed in the product that cannot be removed through the rear door, gently remove the paper through the front of the product.
    NOTE: Remove paper from the front of the product as carefully as possible. If any torn pieces of paper remain inside the product, more paper jams are likely to occur, and this could damage the print mechanism.
  3. Close the cartridge access door. Figure 3: Close the cartridge access door c01913999.gif Illustration of closing the cartridge access door
  4. Reconnect the power cord to the back of the product.
  5. Press the Power button (c01602202.gif ) to turn on the product.
  6. Try to print a self-test report. See the steps on how to print a self-test report at the top of this document.
Keep in this LINK.
Oct 26, 2010 | Dell 948 All-In-One InkJet Printer
Hp printers continue to jam
Print a self-test report Use the following steps to print a self-test report.
  1. Load plain white paper in the input tray.
  2. Press Setup , and then press 2 . The Print Report menu displays.
  3. Press 1 to select and print a Self-Test Report .
IMPORTANT! Try to print a self-test report after every solution even if the solution resolves the issue. Solution one: Clear the paper jam Follow these steps in the order presented to resolve the paper jam. Step one: Remove loose paper from the tray Remove any loose sheets of paper from the input tray and the output tray. CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism
Sep 08, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Machine won't print in black when colour cartridges empty
it is possible to print with only one cartridge that has ink as long as you take a piece of black tape and cover the front center of the empty cartridge and placing it back into the machine .you need to cover the clear plastic in center. Also to take off the power from on the machine press and hold power button for a few sec
Jun 17, 2009 | Brother MFC 240C All-In-One InkJet Printer
Ricoh printer prints nonstop when plugged up& is in code
clear you print files in your print  que
http://www.websitetoolbox.com/mb/copierquestions
Jan 15, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Re: Paper Jam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 02, 2009 | Lexmark X3650 Printer
Print factory 2 Paper/CD jam fault
My e-mail is jounikontulainen@gmail.com.I could mail You technical document that might help.
Jouni
Apr 05, 2008 | MicroBoards PF-2 InkJet Printer
Paper jam cleared - but still won't work
turn off the printer for a while then back on again, if it still refuse to print, try printing a test page.
Feb 13, 2007 | Canon LBP 800 Laser Printer
HP PSC 1610 All-In-One InkJet Printer Logo
53 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
