Water Inlet Valve
If the dishwasher is leaking water the water
inlet valve might be defective. If the water inlet valve sticks open, it
will allow water to fill the dishwasher continuously. Some customers
report that they see clean water filling the bottom of the dishwasher
after it's been sitting all night or for a couple of days. If this
happens, turn off the water that is supplying the dishwasher. This is
normally a valve under the kitchen sink. Then, replace the water inlet
valve, it cannot be repaired. The water valve needs at least 20 lbs
pressure to shut off properly. If your water pressure is to low
replacing the valve may not solve the problem.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Center Wash Arm Assembly
If the dishwasher is leaking water, the
center wash arm assembly might be cracked or split. This can allow a jet
of water to spray toward the door seal, causing a leak. If a crack or
split in the center wash arm assembly is found, replace it. There isn't
any glue that will hold the part together inside the dishwasher.
Lower Wash Arm Assembly
If the dishwasher is leaking water the lower
wash arm assembly might be defective. If the lower wash arm has a crack
or split on the end, it can force water to spray directly toward the
lower part of the dishwasher door. Then, the water can be forced under
the door and onto the floor. Check the lower wash arm for any cracks or
splits and replace it if necessary. Also make sure the screws are tight
in the wash arm support. If the screws are loose, water can spray out
the side of the pump and cause a leak.
Upper Wash Arm Assembly
If the upper wash arm assembly is broken or
cracked it can cause water to spray very forcefully toward the seams of
the door, causing a leak.
Door Seal
Every dishwasher door has a door seal. If the
dishwasher is leaking water, it might be that the door seal is
defective or worn out. Try closing the dishwasher door on a dollar bill
and see if the door seal is making good contact all the way around the
door. If not, replace the door seal. If the door seal is good or has
been replaced and there is still a leak check the door hinges. If the
hinges are bent the door will not close properly and the hinges will
need to be replaced.
Dishwasher Door Gasket
God bless you
