Question about Kenmore 44102 Front Load Washer
I still have water in my washer after drain and spin cycle. Checked the drains and all I can see is clear. Wondering if I too need a new pump. No error codes.
  • myaurelia Jun 30, 2009
    I already tried that. Nothing found. I also used a shop vac to make sure drain pipes were clear and did a visual inspection. Nothing found.
  • 999 Answers
There is a cleanout on the pump. Remove the front lower panel for access.
Eric
Posted on Jun 24, 2009
  • Eric Duda
    Eric Duda Jun 30, 2009
    There is/was a tech sheet near the pump with diagnostic sequence. You can run through that and see if the pump is working properly. It is either a pump problem or a slow drain problem. If the pump is running the water has to go out if nothing is slowing it down. I don't know if you checked the line from the tub to the pump or not.
    Eric
LG washer WM2501HWA quit mid cycle and had an OE error message. The drain filter was checked and was clear. I drained out all the water through the drain hose. For a time, the drum would not spin. When...
i believe if the water outlet is still good,,,,,u will have to loose out the pump from its cup , mayce something hooked its propeller inside the i cup or replace the water pump
Jan 25, 2015 | LG Washing Machines
Washing machine will not drain
Since you've already checked the pump, hoses and motor, here are some additional issues to look at:
1. Faulty timer: Does your machine fill with water and begin agitating, but the cycle never advances far enough to allow the water to drain? The timer that controls the cycles may be broken. Arrange for washing machine repair service.
2. Worn or loose belts: Are clothes still soaked at the end of a wash, even though the washing machine appears to go through the spin and drain cycles? The timer that controls the cycles may be broken. This is a job for the pros.
3. Faulty or jammed internal impeller on pump: When the spin cycle starts, do you hear a humming noise? The internal impeller that moves the water through the drain pump may be faulty or jammed. A grinding or grating sound is almost always an indication of a coin, button or other object colliding with the impeller. Have a washing machine repair expert determine if the impeller is jammed and can be cleared, or if the pump needs to be replaced.
For more troubleshooting steps, see Washing machine won't drain. I hope this helps!
Oct 08, 2012 | Washing Machines
Water doesn't drain
you could have a bad drain pump.
have you checked the hoses that come from the bottom of the tub to the drain pump for anything that might be stuck in there,also check the hose that comes off the drain pump to the wall and look for an obstruction.
Jan 31, 2010 | Asko W6021 Front Load Washer
Washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
Oct 17, 2009 | Tecnik TKL9260 Front Load Washer
Washer will not pump out water.
drain pump restricted with debree or drain pump bad. if you can hear drain pump humming during drain function then clean out and see what happens
Jun 22, 2009 | Washing Machines
No drain or spin cycle
Check the following to address the issue--
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 03, 2009 | Kenmore 22422 Top Load Washer
Won't spin after wash cycle or rinse cycle
CHECK THE FOLLOWING---
2. Water Pump
May 31, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer won't spin and drain
Sounds like your drain poump is failing. It's spinning lighter loads but not able to take a full load. I woule definately replace the drain pump,
Feb 28, 2009 | Frigidaire Washing Machines
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Dec 13, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Kenmore top loader washer
check the pump is not obstructed and can turn freely. if it is free then a new pump may be reqd...after you have drained the water out try to put it in the spin mode if it spins ok then there is a good chance it is the pump if it does not spin out then the pipe work to the limit switch may be blocked at the base that is the clear small plastic pipe if this is blocked the machine thinks it is still full of water so it wont spin out if this is clear then your card may be damaged.its a question of elimination hope this helps.
Dec 01, 2007 | Washing Machines
Kenmore 44102 Front Load Washer Logo
118 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
