Question about Panasonic TX-28CK1 28" TV
Toshiba CF3254j I have an older Toshiba cf3254j tv for which I recently replaced the C301 and C305 "red" capacitors to resolve a vertical rollup problem. Now the set will not power on and keeps blowing resistor R303 (1k ohms). Where should I look next? Thanks.
    Genius:
  • 1,694 Answers
You may have one or both caps in backwards =
Observe polarity and re-check............
Posted on Nov 05, 2007
  • Vista Electronics Apr 24, 2008
    Solder splash ?.....................T.
How to repair Vertical Foldover on Toshiba 20AF43 old crt TV
Check and replace all the electrolytic capacitors [about 5 or 6 of it] at its vertical scan output section circuit..
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 30, 2014 | Toshiba Televison & Video
Vertical linearity problem
Check and replace all the electrolytic capacitors at its vertical scan output section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
May 17, 2014 | Toshiba Televison & Video
I have an older 12 year old 37" Toshiba tv. When I
A capacitor in the vertical circuit is taking time to build up a charge, and allow the vertical circuit to function properly. If you can get a schematic, you might be able to find it and change it out. It will be an electrolytic capacitor, shaped like a round barrel, and they are inexpensive, but you have to disassemble the whole unit to get them changed out.
I would live with it, unless you're very adept at electronics.
I could work for years like this, until it finally gives out.
Good luck, and hope this helps.
May 25, 2011 | Toshiba 27A42 27" TV
Vertical Distortion fix for Toshiba 32 inch TV
You have bad capacitors and possibly a vertical IC that is going bad. And check for bad grounds in and around the IC and caps!
Dec 10, 2009 | Televison & Video
Older JVC 36" with a line about a third of the way down screen
you have leaky capacitors in the vertical circuit, you probably need a tv repairman to troubleshoot, but if you want to take the back off, find the vertical chip, and change the 4 or 5 capacitors around the vertical chip then good luck, also once in a blue moon, you can fix this by resoldering the vertical chip.
Sep 15, 2009 | Televison & Video
No image on a toshiba Cf27g50
If it is a vertical line, change the horizontal output transistor + capacitors. If it is a horizontal line, replace vertical output transistor + capacitors. Both cost around $10-20.
May 21, 2009 | Toshiba CF27G50 27" TV
Toshiba CF3062A
check capacitors location# C305-values 2.2mfd@50v,C342,2.2mfd@50v....
Jan 10, 2009 | Televison & Video
TV Toshiba CF32G50
I think you have a vertical problem. Turn up screen voltage to see if there is a tin horizontal line across screen. If so replace vertical output IC and the 100uf/35v capacitor in the vertical circuit.
Oct 31, 2008 | Toshiba CF32G50 32" TV
Model CF1926A TV with insufficient vertical height. I replaced c308, c305, c301, c315. voltage was missing from ic501, pin 29; restored with replacement of c301. no help to vertical. voltage was missing...
I think you missed one cap. Look for another 1ufd cap close to the jungle chip. It will have the circuit designation in the 300's like the others in the vertical circuit. It is just not located close by. I think that one will fix it.I don't have the service data with me so I can't give you the exact designation.
Dan
Jun 04, 2008 | Toshiba Televison & Video
Panasonic TX-28CK1 28" TV Logo
57 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
