Question about Kenmore Heating & Cooling
Air conditioner does not work
KENMORE CENTRAL AIR CONDITIONER MODEL CAC 024A KA1
CANNOT RESET THERMOSTAT TO START AIR CONDITIONER
  • 74 Answers
SOURCE: central air conditioner doesn't cool
A central air conditioner that runs but doesn't cool may just need to be cleaned. Plan to do this on a relatively warm day. First look for your owner's manual and, if you can find it, follow its instructions. If you can't find it, request one from the manufacturer (see Resources). To clean the filter, remove it from the furnace or air handler (it?s usually located inside or very near the air inlet side). Replace a disposable filter or clean a reusable filter according to the manufacturer?s directions. 1) Before you begin, check the thermostat to make sure it is set to "cool" rather than "heat." Then turn off the power to the unit; there is normally a shut-off or disconnect panel on the house wall next to the outdoor compressor. Otherwise, shut off the air conditioner's 240-volt circuit at the main electrical panel. 2) Rake leaves and debris away from the outdoor condenser. 3) Remove any protective grille or cover from the condenser's fins. 4) Use a soft brush to clean dirt and debris from the fins, then vacuum them with a brush attachment (be careful not to bend or damage them). If you accidentally bend fins, you can buy a comb made for straightening them at an appliance parts store. 5) Unscrew and lift the top grille off the unit, if possible. If the fan is attached to the grille, be careful not to pull any wires loose. 6) From inside the unit, hose out the fins (protect the wiring and motor with plastic). If your owner's manual calls for lubricating the motor, do that now--don't over-lubricate. 7) Then reassemble the unit. 8) To test it, turn the power on and set the thermostat to turn the unit on. Let it run for a few minutes, then feel the two pipes that connect to the condenser unit (slide any insulation back). One should feel warm, the other cool. Otherwise, call an air conditioning technician--the refrigerant may need to be recharged. NOTE: Avoid straining an air conditioner's compressor by waiting at least five minutes between turning it off at the thermostat and turning it back on. Air conditioner or heat pump still giving you trouble? To Home Problem Solver Main Page Copyright. All rights reserved. Interested in licensing this DIY Content? Related terms: what to do if, how to fix, troubleshooting, DIY, air conditioner doesn't cool, air conditioner too warm, warm air from air conditioner, air conditioner not cold enough, how to clean air conditioner, cleaning air conditioner, air conditioner cleaning
Posted on Jan 18, 2006
  • 161 Answers
Usually when a unit isn't cooling it is because one there isn't enough freon in the unit. Second there could be a compressor gone bad. Third there could be a circuit short out. It can be very simple and it can be costly. It just needs to be checked out by someone who has understanding in this area.Look for an affordable service man or company in your area whom most people may be using to come out and check it out for you. They would be glad to. They can let you know about what it might cost also. If you have understanding in this area you might do it yourself. I do most everything myself and it keeps alot of money in my wallet. But I have to take the time to do it.
Posted on Aug 08, 2007
Illeagle
  • 525 Answers
SOURCE: kenmore window air conditioner
Below is a link to the model that you describe. This link shows a parts breakdown and cost feature. From the parts description, I was unable to locate a customer replaceable fuse. I have never heard of a fuse inside of an a/c before but I just wanted to be sure. It appears that this is electronically controlled model, so
make sure you have adequate voltage and grounding to your outlet before you call for service.
http://www.retrevo.com/s/kenmore+air+conditioner+580.74124400?rt=tr&p=http%3A%2F%2Fwww.appliancefactoryparts.com%2Fairconditioners%2Fhelpcenter%2Fbreakdowns%2Fkenmore%2F
Posted on Jun 03, 2008
refritech08
  • 149 Answers
SOURCE: air conditioner won't shut off when temperature reached
suspect a stuck contactor on condenser unit or cooling relay stuck
Posted on Jun 15, 2008
  • 182 Answers
SOURCE: central air conditioner is not
check your filter....if its ok,youre prolly low on freon.
Posted on Aug 08, 2008
York Air Conditioner unit doesn't turn on
jumper red to yellow on thermostat if it kicks on problem is in the thermostat.
Apr 22, 2012 | Heating & Cooling
I have a kenmore central air unit model KAC024AK5. Fan started making noise few days ago. I'm still getting cold air. Opened the top grill and the fan is not loose. Could it be the motor and more...
Yes, the bearing go bad and for the price of the new motor I would get it new... to repair will be more then half that if they can ...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Aug 30, 2010 | Kenmore Heating & Cooling
My central air fan isn't blowing. The thermostat
Check the master circuit breaker at the power panel? Should be 2 50 amp vreakers. Turn them off rgen back on.
Jun 08, 2009 | Ruud UBHC Air Conditioner
Central air
Most thermostats have a setting for the fan called, "manual". That keeps the fan on continuously. The electronic thermostats can fail in a "fan on" condition. That would require a new thermostat. I also saw one air conditioner with a fan relay welded "on" by electrical surge. That would require a new relay.
Jul 20, 2008 | LG LWHD1800R Wall/Window Air Conditioner
Air conditioner won't shut off when temperature reached
Jun 14, 2008 | Kenmore 72055 Air Conditioner
20 year old central a/c heater not working
Check your thermostat and mode selector setting, thermostat setting should be set at warmer and mode selector setting should be at low heat or hight this is applicable for manual unit.
If it is a remote control just set the remote to heat mode.
sample only
Jan 02, 2008 | GE Quiet-Aire Ductless Split System Air...
Heating & Cooling Logo
180 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
