Question about LG 37LC2RR 37 in. LCD TV
Is this TV equipped for digital signal
I need to retune my TV as I am in an area for digital TV , how do I do this
    Sergeant:
  • 470 Answers
If it's old enought to still be analog you need an air hd converter.
Posted on May 27, 2014
    Top Expert:
  • LG Master
  • 76,100 Answers
Try this link to download the user manual to this set. It has all details, in its specification page. LG 37LC2RR USERMANUAL HUN Service Manual free download schematics...
Electro help
SOURCE:
How do you tune TV
A full retune should only takes a few minutes and can be done with your remote control. Here are some guidelines for how to do it, but bear in mind every model of digital TV or box will be a little bit different.
  • Make sure your Freeview TV or box is on and in digital mode, usually by pressing the DTV or digital button on your remote. Then press 'menu'.
  • Select the 'set up' or 'installation' option. If you see picture icons, select the tool box, satellite dish or spanner. If you are prompted for a code, try 0000 or 1234.
  • Select the full retune option. This is sometimes called 'first time installation', 'factory reset', 'default settings' or 'shipping conditions'. Do not select 'channel update' or 'add channels'.
  • Press 'OK' if your equipment asks if you want to delete all your channels. Don't worry this is normal
  • Channels will automatically be installed. This may take a few minutes and your equipment may shut down and restart
  • In some cases, where transmitter signals overlap, it may be necessary to carry out a manual retune.
Note: Depending on your TV equipment, you may need to update your favourites list following a retune. Some digital recorders may require scheduled recordings to be reset.
Jun 10, 2016 | Televison & Video
Why do I get no signal on my auria tv set
Was it working recently and then gone wrong. Is there a good aerial with it. Is it analogue, most places broadcast only digital signals now, (at least here in Europe.) If everything is fine in these areas it might be that the receiver has gone. Check as much as you can, try a retune, if it works all well and good. If not then a technician might be needed.
Good Luck
May 27, 2015 | Televison & Video
Matsui helpline
Just go to your TV settings and just do a full reinstall ,like the day you brought your TV ,below is from the web site your tv will work hope this will help.
The Freeview TV guide is being updated on Wednesday, 3 September 2014 to create extra capacity for new services. As a result, Children's and News channels will move to new channel numbers.
• The Children's genre will move from channel numbers in the 70s to start at 120
• The News genre will move from channel numbers in the 80s to start at 130
To update their guide viewers simply need to retune their Freeview TVs and digital recorders or boxes where equipment does not pick up the changes automatically. On-screen messages will prompt viewers to retune late afternoon 3 September 2014 onwards.
Viewers who don't retune will not lose channels - services will remain accessible at their old numbers. However, Digital UK and Freeview recommend viewers retune from time-to-time to ensure they have access to all available services in their area.
Aug 29, 2014 | Televison & Video
How to retrieve lost channels on digital tv
To restore missing channels, you need to retune your digital receiver (box or TV).
The retuning process runs a scan and finds all the available channels. Your box may have an Add New Channels option that you can use, but this may not pick up other changes such as channels being moved to a different multiplex or removed altogether.
How to retune
  1. Switch on your digital box and/or TV.
  2. Press Menu on the remote control.
  3. Select the Setup or Installation option.
  4. Select the 'First time installation' option (sometimes called 'Factory reset', 'Full retune' or 'Default settings').
  5. Press OK if your equipment asks if you want to delete all your channels. Don't worry, this is normal.
  6. If you are prompted for a code, try 0000 or 1234.
  7. Channels will be automatically installed. This may take a few minutes and your equipment may shut down and restart.
  8. After retuning, you will have to redo your Favourites list and other settings. If you retune a digital TV recorder, you also should reset future recordings.
Feb 27, 2012 | Toshiba Televison & Video
I have built in Freeview in my Hannspree television. The picture has completely gone, and I have tried retuning, but to no avail. The message is 'database empty', but according to the operator at...
This tv is a flat LCD tv wright?Not a big bulge back CRT tube tv,If this is CRT tv is analoge design tv dosen't have freeview Digital Tuner inside of the tv.If it is a flat LCD tv.Make sure ur setting for retuning not on CALBE SETTING.Make sure ur tv setting are AIR SETTING and have good Digtial antena will get a stronger signal get all the free AIR broadcasting stantoins channels,a good strong Digital antenna design does make big a different.
Aug 04, 2011 | Hannspree (K206-10U1-005) Television
Cannot tune all digital cahnnels on Sharp aquos
Start by doing a factory settings/ defaults on the Sharp rather than a normal automatic retune.This should then be ok. You need to empty the existing presets first so it will find the new type of signal BBC is now using.
If still not working for BBC1 +2 then look at whether you have too much aerial signal strength. (ie a booster/splitter that you could bypass)
Nov 07, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
No programme info ona Sony TV after the Freeview retune
Unfortunately you haven't said which exact model of Sony tv you have, but there were a lot of their models which didn't behave correctly after the digital retune. In most cases this led to a digital tv freeze.
The official advice is to first try the retune again; from experience I'd add that you need to try it at least twice and to do so at different times of the day in case there is temporary unplanned signal disruption or other environmental factors.
If that does not work then you need to contact Sony directly for advice on 0870 511 1999.
Please cut and paste the following web address into your browser and you'll see a list of Freeview equipment which is known to have incompatibilities with the retune (you need to have Adobe Reader installed). Unfortunately the list has proven to be somewhat less than comprehensive.
http://news.bbc.co.uk/1/shared/bsp/hi/pdfs/01_10_09_freeview2.pdf
I hope that you have found my advice to be of assistance and in return ask only that you remember to rate my answer.
Oct 20, 2009 | Televison & Video
HAVE GOT A SWISSTEC 15 INCH TV BUILT IN FREEVIEW, BUT CA NOT GET ITV 1 OR CHANNEL 4 ON IT. HAVE TRIED RETUNNING BUT NO GOOD
The model number would usually be on the back of the TV but in this case it's immaterial as Swisstec appear to have had a very brief existence. Their website no longer works (skymediamanufacturing.com, no connection to Sky satellite tv) and the few products which have their brand name on all seem to be at outlets like ALDI and Makro which often specialise in clearance lines and bankrupt stock.
First, check that your missing channels haven't been shifted to 801, 802 etc. This is happening with some equipment and it's just how some slightly incompatible equipment handles the retune.
What you have said about your aerial system does not eliminate the possibility of an aerial fault; as you're running multiple items off one aerial I'd fully expect it to be a high gain aerial, but this does not necessarily mean that it's a wide band aerial. In addition, each time the signal from a single aerial is split there is typically up to a 10dB loss (around 60% each time). Regular analogue reception equipment can cope with this far better than Freeview receivers as the analogue signals are vastly more powerful than the digital ones. One of the most important UK transmitters puts out a 100kW (i.e. 100 000W) analogue signal along with an 800W Freeview one making the analogue signal 125x stronger at the transmitter and far weaker further away.
Realistically, you have limited options. Most Freeview receivers have an onscreen menu in the digital tuner which has a signal strength and quality meter for each channel. If most of the channels have a middling signal with good quality then your reception is most likely ok so look at the aerial cable at the back of the set to see how long the plug into the back of the tv is. If it's longer than about 2cm then it probably has an in-line suppressor fitted onto the end of the plug. Usually there's a marking of either 6dB or 10dB on the suppressor. Remove any suppressor and try retuning.
If that didn't work then check as much of your aerial system as possible paying special attention to the plugs and splitters. No plug should be showing any bare wire, and the external screening braids must not be touching the internal signal wire. You'll probably have to undo each plug to check for this and remake any shoddy work. If you have aerial splitters which are the push together variety then check the connections are tight. Also consider replacing them with the screw threaded F-terminal splitters which all professional installers use. These cost very little more than the useless things sold in most DIY stores and general retail outlets but hugely reduce signal losses. I've posted an online address of a supplier at the end of my post, but you can also get them from your local Maplin store usually at extra cost.
If you have an amplified aerial then try disconnecting the amplifier. These are often inappropriately fitted and cause digital signal meters to show the confusing message of a strong signal with poor quality. A good quality weak signal can be successfully amplified but a poor quality signal requires a better aerial installation.
If you have eliminated all doubt regarding your aerial then the fault is most likely with the receiver itself. The official advice is to try retuning but you've almost certainly done that. There is a list of equipment known to have problems with the retune (see second web address) but it's not comprehensive and misses out minor brands like Swisstec. Clearly you cannot contact Swisstec and they are in no position to rectify the problem themselves any more. Under these circumstances your only remaining option is to buy a new external receiver from around £20 and connect it to your tv as if it never had an internal receiver.
Note that the UK Sale of Goods Act was recently amended to allow purchasers up to six years protection against goods which are not of "satisfactory quality" (replacing the earlier term "merchantable quality"). You've had your tv for eighteen months and the tv itself still works, but as a super-budget unknown brand it's doubtful that you could press your rights regarding the failed Freeview receiver.
Sorry this is not the easy fix you were hoping for but I hope that it's been of some assistance.
1st web address. Supplies and excellent general aerial advice.
http://www.aerialsandtv.com/ampsandsplitters.html
2nd address. List of known incompatible equipment. Not really of use to you but at least shows you're not alone...
Oct 09, 2009 | Televison & Video
Hi, I have the dvr3006 dvd recorder, my tv is a
The dvd possibly only has an analog tuner so you would not be able to get a digi signal
Sep 22, 2009 | Televison & Video
Lost BBC channels on my SAGEM PVR6200T during a retune
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit http://tvretune.co.uk/productmanuals/
Jul 06, 2009 | Sagem PVR 6280 Freeview DTV Receiver /...
LG 37LC2RR 37 in. LCD TV Logo
112 people viewed this question
Ekse
