Question about Sony Cybershot DSCW80 7.2MP Digital Camera with 3x Optical Zoom and Super Steady Shot
When i turn the camera on it says, turn off and on again
Wont work
  • 999 Answers
Clean the battery contacts with a pencil eraser.
Eric
Posted on Jun 24, 2009
Elf name error
hi.you only need to remove your mmc and turn on your camera again and its ok,then format your mmc and insert back to cam.and its ok again
Apr 06, 2012 | Samsung PL120 Digital Camera
Samsung pl50 camera - lense wont go back in and wont turn on
The problem with mine was that the lens motor was somehow stuck. I gently pulled the lens out as I turned the camera on. It went back to normal afterward. Hope this helps
Feb 01, 2010 | Samsung PL 70 SL720 Digital Camera
When i turn on the camera the lens wont pop open even when the battery is fully charged.... i was taking pictures and it working fine turn the camera off and on again then the lens wont open anymore? i can...
The problem is
1- some dirt somehow got on the outside of the lense. After it was retracted fully in, it prevents the camera from opening again. When you turn it on, if it opens a little bit, try to pull it out NOT too hard and let go a few times. If it opened, clear the outside of the lense. Your camera should be back to normal.
2- If you droped the camera, you probably damaged or dislocated a mechanical part of the lense. You may have to take out the lense by unscrewing it and inspect it for damged parts or disconnected cable. Make sure clean the lense and test it by moving it in and out a few times, before puting it back on the camera.
Good luck!!!!!!!
Jun 10, 2009 | Sony Cyber-shot DSC-N2 Digital Camera
Camera freezes up and no funtions will work, not even on/off
i am having the same problem. it said file error so i turned off my camera and now it wont turn on at all. It charges and turns on but it wont turn on to take pictures?
May 29, 2009 | Vivitar ViviCam-X30 Digital Camera
Error 99! Wont' take picture, the message states
Go to the www.canon.com website and find out what Error 99 means. ted10
Apr 18, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
"turn off and on again"
a few weeks ago i dropped my camera in the sea and i thought, ****. i was in the same boat, so i opened the shutter myself and turned on the camera and it works and takes pictures but the shutter wont close again so if you can make sure you have no dirt in your lense and you can manually open the shutter yourself it may work and if it stops turning on all together keep charging it and once it goes green turn the switch off and on again until it always turns green then it should work again.
Jun 22, 2008 | Samsung NV3 Digital Camera
Camera won't retrack
August - this sounds like the same problem I had with my Finepix510. Turns out the new unopened package of batteries I put in weren't fresh enough and weren't working. When I got truly fresh batteries, everything started working just fine again.
Hope that turns out to be true for you.
Dec 28, 2007 | Fuji FinePix E510 Digital Camera
Digital camera
I had the same problem. After I "tore" the camera apart, I put rubbing alcohol all around the lense where it goes in and out. I then used a high quality synthetic oil that is for Grandfather clocks and other mechanical clocks to oil it again. I then ran the lense in and out (by turning it on and off) quite a few times to help work the oil down into the gears. My camera seems to be working fine now.
Dec 20, 2007 | Samsung Digimax D53 Digital Camera
Digital camera samsung 301
The camera has died Get onto Samsung Tehnical Support for their solution
Jul 14, 2007 | Samsung Digimax 301 Digital Camera
Sony Cybershot DSCW80 7.2MP Digital Camera with 3x Optical Zoom and Super Steady Shot  Logo
163 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
