Question about Hunter 90021 Century Table Fan
I have a hunter Table Fan 90021 that only runs on high. How can I fix the motor so that it will run on all three settings?
I have had the fan for several years, so it isn't under warranty. The other speeds slowly started failing about 2 years ago, now it only works on the high setting.
  • 2,824 Answers
Probably needs a three speed new switch.you should get one at an electrical shop.
Posted on Jul 03, 2016
5 Suggested Answers
SOURCE:
SOURCE: Hunter 3 speed ceiling fan now turns slowly
Probably a bad capacitor. What model is it? If it completely wireless (in other words: no pull chains for light or fan) the capacitor is located on the receiver for the fan (in the canopy or the lower switch housing). Unless you are handy with a soldering iron, it is easier to purchase a replacement receiver.
Posted on Jun 18, 2009
SOURCE: hunter speed control problem
I have the exact same problem. Called Hunter's tech support and they confirmed the capacitor must be bad. This is the black box that has 4 wires going to the switch. They are sending me a new one for under $12. I haven't received it yet, but the wires from it going to the switch can be removed from the switch by shoving a paper clip along side the wire, this'll release the spring clip holding the wire in. Not sure, but I may have to cut and wire nut any wires that go elsewhere.
I recommend you call them too and as long as you have the 5 digit model number (usually on top of fan) they should be able to get you what you need.
P.S. it is highly unlikely that it is in the switch. I tried replacing it with one from Home Depot and I actually got Low-Off-High, which is worse. The Hunter tech support guy said you can't use after market switches with their fans.
Posted on Jun 19, 2009
  • 52 Answers
SOURCE: I have a hunter ceiling fan its about 20 years
there is a small black box in with the wireing on the fan unit ...this box controlls the fan through your remote ...it is esentially a switch this unit is likely the cause ...remove and replace .....
Posted on Jul 26, 2009
  • 69 Answers
SOURCE: fan only runs very slowly and makes a humming
Check all of your electrical connections, and ensure voltage is 120V to ground. If you have a dimmer switch replace with either a fan control switch or a simple on/off switch.
Posted on Sep 23, 2009
Chrysler sebring 2008 transmission control module
Hi. Have it checked by a professional. It sounds like either the clutch packs are burned-out, the torque converter is shot, or the kick-down or downshift is not working properly. Only when a vehicle has reached a specific speed will overdrive kick-in or the transmission will be allowed to operate in overdrive mode. Chrysler Sebring, Dynasty, New Yorker, and many other models were made using a fully electronic transmission that tended to fail very early in normal use. Many failed during the warranty period and Chrysler refused to replace them under warranty, sticking customers with a bill of $3800-8000 for misuse or abuse of their vehicles, prompting one of several lawsuits filed against them since 1991 starting with the defective ABS systems. Most of these electronic transmissions could not be repaired properly by the dealerships, forcing them to return them directly to their manufacturing facilities to rebuild them, only to fail yet again within the first 2 years of normal service.
Mar 18, 2014 | Vehicle Parts & Accessories
Hunter fan remote bypass
This fan uses a "ballast" to run the fan. The ballast (part #272) probably contains wiring for multiple speeds. Here is a manual that discusses the wiring- http://www.hunterfan.com/SupportDocuments/OwnersManuals/42700.pdf.
To use a wall mounted fan dimmer, you need to identify the high speed wires and connect them to the dimmer switch. This method will bypass the other speed windings and is not as power efficient.
Jan 31, 2014 | Hunter 21617 Palermo Brushed Nickel...
Open clean
Send it back to Hunter!!! Should be under warranty.
Oct 18, 2013 | Hunter 90021 Century Table Fan
I have a GE Monogram ZIBI240 Bar Refrigerator with Icemaker. This unit is brand new out of the box. We purchased it 5 years ago and it was never installed (for reasons I won't go into). Installed i
is the compressor running if so it is out freoin or compressor is bad or want start may be relay compressor should start after the fan starts
Dec 12, 2011 | GE Refrigerators
Re: Hunter Fan Model 27185 - 060 The above fan was purchased circia 5/1/2000 and does not now function properly (actually it has not been fully working for 4-5 years. It is installed in a 19' ceiing...
You either have a wiring problem possibly a ground rocked loose or the motor is going out.but if you press 1 while its running and it dies sounds like motor and nothing wrong with remote
Apr 26, 2017 | Hunter Heating & Cooling
It is brand new model type 2A Palatine and on high does not spin as fast as other hunter fans we have in our home
I know this is not a fix but in reading alot of posts on the net, apparently the new model fans have weaker motors in them. I have run into the same problem with a new fan that we bought this week. This one is 62" and it does not cool near as good as the one that we took down, which was a 52". I am researching if we can change out the motor to a faster amp motor. Good Luck.
Jun 26, 2011 | Hunter (25417) Ceiling Fan
Hi , I have inherented a Hunter Table Fan 90023
Howdy,
It's highly possible the Capacitor has failed. The motor in this fan is Permanent Split Capacitor.
Do the blades spin freely? If you bump them around, do they coast, or stop suddenly? If they coast freely then that would point towards the capacitor. I believe Hunter has a 5 year warranty( it may be 1 year) on these fans, so it may still be under warranty and they may send you a new unit. Their phone# is 1-901-745-9222.
If it is the Capacitor, it is possible to replace it and to find out if it is the capacitor, remove the rear motor cover (should be one screw on the rear of the motor cover) there will be a small box, most likely black, or yellow with some writing on it, if it looks swollen up or melted, this is obviously the problem. However, depending on the failure mode, it may not have any visible indication that it has failed. If it has failed and you wish to repair the fan, Hunter should be able to send you a Capacitor and all you need to do is clip the wires on the old Capacitor and connect the new capacitor to those wires. Just make sure the wires are secured, it's very simple, you can do it yourself.
Dec 21, 2010 | Hunter 90021 Century Table Fan
Hunter 90021 Century Table Fan Logo
491 people viewed this question
Top Hunter Dryers Experts
Joe Paxton
Level 1 Expert
Paul Bade
Craig Butler
Craig Butler
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
