Question about Gable (53315) Wall Mount Fan
Last year my gable fan seemed to work fine. I
Last year my gable fan seemed to work fine. I have an optional switch for it that I turn off durning the winter. Two weeks ago I turned the switch on and nothing happened....no fan. I checked the breaker and it is fine. Any ideas or do I just need to get a new fan???
  • 221 Answers
As it's protected by circuit breaker it also might be fused, so check for fuses.
Next just dig to the wiring and measure the resistance betveen Live and Neutral using simple multimeter. If there's no reading then there might be a small fuse (or thermofuse) attached to the windings, make sure this one is fine, if yes then motor windings are burned and you'll need new fan, otherwise just replace the fuse.
Good luck
Posted on Jun 24, 2009
I can't turn off my ceiling fan. Remote batteries are new. Fan not connected to a switch
need to disconnect the power source to fan then test the transponder / relay in fan possible faulty and will probably need to be replaced
May 06, 2018 | Hunter Dryers
Whirlpool SC8720EDB cooktop stove independent vent switch is not starting downdraft exhaust fan, but the exhaust fan works fine when left side burners were turned on
Can you get to the switch terminals and try jumping them out with a piece of insulated wire? That would tell you if the switch is defective (my suspicion). Please be careful not to touch any live terminals - only the wire insulation you use for the jumper.
Aug 02, 2017 | Whirlpool Cooktops
I have a 10-year old Carrier Gas pack Model #48GS024060301. Turned on the heat for the first time this season and the unit did not turn on. I was able to turn on the house circulation fan and since it...
If the induction motor ain't going I would look for a blown 3 amp (purple) fuse on the control board. If that was good I would check if any of the roll out switches were tripped. If a rollout switch was tripped check or air restrictions somewhere.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 17, 2010 | Heating & Cooling
Whirlpool MH3184XP Microwave Turns On, Heats, but sounds like fans not working. 4 years old, fans worked fine until they seem not as loud anymore. The magnetron is working fine as it heats (did the 1 cup...
Suggest you pull the plug out, remove outer cover and place a cup of water into the micro. Set power to minimum then switch on and take note if the fan works or not. If not, switch off immediately and have it replaced(magnatron will burn out if left to run without fan.)
Sep 18, 2010 | Whirlpool MH3184XP Microwave Oven
My panasonic fan has been working fine for the last 4 years. now, it seems to have trouble starting up... when i flip the switch on, it seems to start and re-start itself, turning itself on for 2 - 3...
Sounds like it could be a loose or intermittent wire either in the fan itself or in the wall switch. I would start with the wall switch to see if the main power line into the switch for both the fan and light is loose. Turn the circuit breaker off for that circuit, remove the wall plate to the switch and pull the switch out of the box to examine the wires. It could also be a loose wire in the switch box that would be part of a wire splice. Tighten the wire nuts. If that does not fix the problem, a look inside the power box of the fan might be necessary to examine the wire connections there.
Sep 12, 2010 | Panasonic WhisperFit-Lite Low Profile...
Fan and light suddenly wont work.
May be the receiver Call Hampton Bay @ 18005533199 have your UPC number ready
Oct 27, 2009 | Hunter Dryers
"high" vs "low" dual control
could be problem with either switch of fan. try continuity across both legs of the switch then try continuity across the fan windings.
May 25, 2007 | Fedders X Chassis A3X05F2B Air Conditioner
Gable (53315) Wall Mount Fan Logo
109 people viewed this question
Top Gable Dryers Experts
Marvin
Marvin
Are you a Gable Dryer Expert? Answer questions, earn points and help others
