Question about HP (D7580-60003) Motherboard
Most times no ping...every now and then a boot. ideas?
  • 92 Answers
RAM or Ethernet module...
Try to disable Ethernet on Bios, and see if it still reboot...
Meanwhile use another Ethernet Adapter on one of your PCI slots...
Regards
Posted on Jun 24, 2009
Just bought a Sportster 883 2002. There's a rattle in the engine as I get higher up in rpms. Also the exhaust pops as I accelerate. Any idea as to what could be the deal. Carb maybe?
Ahhhh..the Sporty has a rattle...or is it a ping? If your popping through the exhaust, the timing could be off and running rich (Check Spark Plug for dark sooty layer) If your engine is pinging could be advanced timing... pre-ignition happens on acceleration or under a load...loose valves will make noise all the time
Do you have the CV Keihin still? Or are you running an aftermarket carburetor ? Like an S&S?
May 06, 2016 | Cars & Trucks
Unable to access some websites
Sounds like DNS settings on the XP machine are wrong.
Aug 31, 2014 | Microsoft Windows XP Home Edition
Ping problem
You might have some viruses and malware.
Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below.
Download, Install and Run Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
When Installing choose the non-pro version.
Download, Unzip, Install and Run TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Download, Install and Run Super Anti-Spyware:
http://majorgeeks.com/SUPERAntiSpyware_d5116.html
If you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:
http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.html
Make sure to select ALL of the "threat categories" when you install or configure Avira.
You should be in pretty good shape if you run and install all of these programs.
Sep 03, 2012 | Computers & Internet
My router is on but it seems so slow. i keep getting randomly disconnected, the connection is terrible and even when i turn it off for 30 seconds and on again it stills acts up, any ideas?
ping your router with a packet length strength. To do the ping test, go to Start-Run and type CMD and hit enter. Then, in the Command Prompt Window type in the following
ping 192.168.0.1 -l 30000 9
I suppose the 192.168.0.1 will be the default gateway of your router. To check which is the default gateway of your router you can double click the connection icon on your PC, and click the Support tab. You'll see the degault gateway IP third on the list.
Now, if it pings back all three times with times below 100ms then ok. If it doesnt then reduce the ping length to 20000, if again you have losses then reduce it again to 10000. If the ping loses packets and response is slow you'll probably need a new power cord.
If the pinging is ok at 30k then you'll probably need to change the LAN cable that leads from your internet connection onto the wifi router.
To verify this, run this command
ping google.com -l 10000 and see if you have any losses. If you do have losses, then do a ping like this
ping google.com -l 32000 if you again have losses in the ping then you'll need to change your LAN cable because the 32kb packet is almost a standard size of packets and it should have no problems to get through the router, unless the LAN cable is bad.
Hope this helps. Please vote a Thumbs Up if you found this useful and informative.
Jan 18, 2011 | NetGear WGR614 Wireless Router
Hello. I have a unique problem. I have a Windows Vista home premium system that can ping to my gateway and other systems on the local network but can not ping beyond my gateway and can not browse the...
If you can PING your gateway, then there was no need for the 'WINSOCK FIX'.
Access the web-server "inside" the router, and look at the table of DHCP clients -- confirm that your computer's "wired" and "wireless" connections are listed, and that they have been assigned IP-addresses.
The router should have its own 'PING' interface, so try PING-ing to 'ns.watson.ibm.com' -- you should get output like:
Pinging ns.watson.ibm.com [129.34.20.80] with 32 bytes of data:
Reply from 129.34.20.80: bytes=32 time=126ms TTL=241
Reply from 129.34.20.80: bytes=32 time=103ms TTL=241
Reply from 129.34.20.80: bytes=32 time=91ms TTL=241
Reply from 129.34.20.80: bytes=32 time=93ms TTL=241
if your router has an Internet connection.
Oct 23, 2010 | HP Computers & Internet
Pinging noise comming from exaust
The 1100 Custom requires the valves to be adjusted every 3000 miles.
It is best to use high octane gas also. Regular or shall I say CHEAP gas will over time cause the pinging or spark knock.
Pinging could also be something worse if it does not go away with valve adjustment and better gas. Get it checked right away.
Kinda miss my ole 1100 custom but the Yamaha Raider I have now does not require valve adjustments every 3,000 miles. And fast.... oh dear lord. :)
Hope this helps!
Jun 29, 2009 | 2001 Yamaha V Star Custom
Pinging explorer v8 1999 4*2
it's called spark knocking get timing checked or try a tune up and better gas
Dec 08, 2008 | 1999 Ford F150 Regular Cab
HP (D7580-60003) Motherboard Logo
26 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
