Question about GE Profile WPRE6100G Top Load Washer
GE PROFILE WPGT9350 WASHER WON'T DRAIN
For a couple of weeks it has been saying it is not properly draining but I just ran it through the spin cycle and it was okay. now it won't drain at all.
IT JUST FIGURES I had extended warranty that ran out last fall (it is a little over 5 years old) and GE told me the price of a pump (if indeed that is what I need will be about $180 with shipping and tax. But they won't say how much the labor will be and I don't won't to be $80 for a trip charge if its going to cost too much to fix and I can't get it done.
Seems to me like they could say and I feel it is deceitful to not at least have an estimate of the labor charge.
  • 641 Answers
SOURCE: Ge Profile Harmony Washer doesn't drain properly.
It sound like you have a blocked pump. Remove the pump from the machine and check where do you have this clogged, inside the pump or in one of the pipes connected to it. Good luck!
Posted on Aug 16, 2007
fanny
  • 146 Answers
SOURCE: HELP, GE profile harmony washer wont drain properly
If you remove the tub to pump hose from the pump and try to turn the pump impeller by hand, it should turn freely. If it does not turn freely, then the motor could be seized and you will need to replace the pump.
Posted on Nov 09, 2007
mikedurland
  • 481 Answers
SOURCE: Drain pump/motor not draining.
actually it sounds like there was or is something in the water pump (like a string or metal underwire from a bra). before replacing the water pump i would look inside it and check for foreign objects.
  1. unplug the machine, but leave other hoses connected
  2. use a butter knife or putty knife to open the front panel; at the top seam between the top panel and the front panel is 2 metal clips (about where the edges of the lid are). push these strait in to release the front panel.
  3. once the front panel is off then you should see the water pump on the right side. it has 2 large black hoses and 2 wires attached to it.
  4. take off the water pump (two 3/8 bolts) and look inside it.
some pictures borrowed from fixitnow.com, allpar.com, applianceaid.com and repairclinic.com
  • if you need to buy a new pump, then they are around $50 at repairclinic.com
  • or shop around; GE Washer Pump part # WH23X10013
  • here is a cheap one on ebay:
http://cgi.ebay.com/GE-WH23X10013-Washing-Machine-Washer-Water-Pump-Motor_W0QQitemZ170239837032QQihZ007QQcategoryZ20714QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
let me know if you get stuck
Mike
Posted on Jul 30, 2008
cbrown801
  • 3 Answers
SOURCE: washer wil not spin or drain out after cycle completed
sounds like drain is plugged. this is a fairly easy fix,and you actually get paid to do it. unscrew the bottom panel of your washer should be 3 screws on the very bottom then you will see a white plug that is about 2 1/2" unscrew it (make sure you have a bowl under it water will leak ) and pull it out. this is where you get paid you will find all kinds of change and junk just clean it out reinstall and your clothes will be a lot drier after the spin cycle
Posted on Mar 30, 2009
SOURCE: GE Profile Washer leaking underneath during spin cycle
its your outer tub it has a hole in it
Posted on May 13, 2009
GE Profile Washer WPSR3120W2WW agitates but won't drain/spin
Your drain line is more than likely plugged with a sock or something of that nature.
Aug 11, 2009 | Washing Machines
Agitator problem
Check to see if any thing is under the agitator. If not then maybe the bearings going out or other part of machine . Besure the cap is tighten so agatator don't come off. Check for ware on agatator top to the tighting nut.
Jun 02, 2009 | GE WPGT9360E Profile Harmony 4.0 cu. ft....
I have a GE Profile Harmony Washing Machine WPGT9350. The problem I am having is one I believe somehow related to balance resulting in a noise of the inner drum rubbing/banging against the outer drum. This...
GO TO www.repairclinic.com ENTER MODEL NUMBER, SCROLL ALL THE WAY DOWN AND CLICK THE RED 100 NOW LOOK FOR PART1089518 THIS IS THE BALANCE ASSEMBLY. IT IS SUPPOSE TO HAVE WATER IN IT. CLICK THE PIC AND LOOK AT ADDITIONAL. THE PROBLEM YOU ARE HAVING IS EITHER THE SUSPENSION ASSEMBLY OR SPRINGS BUT NO YOU SHOULD NOT HAVE DRILLED THOSE HOLES. YOU MAY CALL REPAIRCLINIC AT 800-269-2609
May 01, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
GE Profile top load washer purchased 2003 water comes out from under washer when spin and drain cycle on. this not mentioned in trouble shooting area. think it is water pump or whatelse can it be?
It has to be in the water exit path somewhere - is there a pump sump inspection? Is there a hose split? Likely the drain hose, or where it connects to the machine. Has the pump split open? Can you remove the machine cover and inspect it while it is doing a cycle so you can see where the water is coming from?
Apr 26, 2009 | Washing Machines
Washer wil not spin or drain out after cycle completed
Mar 21, 2009 | GE Energy Star WCVH6260F Front Load Washer
Ge WASE4220A0ww will not drain or spin
hI!!! You seem to have a bad transmission or a bad motor they are all expensive to repair..Good luck..
Jan 03, 2009 | GE Profile WPRE6100G Top Load Washer
Aug 16, 2007 | GE WPGT9360EPL Top Load Washer
GE Profile WPRE6100G Top Load Washer Logo
176 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
