I cannot get my computer to recognize my dvi monitor
All I have is dvi no on board and the card is only dual dvi. any idea on how to get the boot screen up?
  • caseypwnsnub Jun 24, 2009
    thanks for trying didnt do anything though :/
    Scholar:
  • 106 Answers
Try just using the bottom DVI slot on the card. You do not need both DVIs plugged in, to get a boot screen.
Posted on Jun 24, 2009
  • Morgan Freeman
    Morgan Freeman Jun 25, 2009
    What is the card model (9800 nvidia-is my guess), and what monitor are you using? Do you still have your old card? If you have your old card still, and you didn't install your new cards drivers from the CD that came with it, you need to put in your old card, and install the new cards drivers. Then, you can install your new card and it should boot.
2nd monitor does not work with DVI to VGA converter cable. My video card has VGA and DVi ouputs.
The problem could be in the adapter to the video card. There are different types of DVI connections. If the adapter does not have the proper set of pins then the card will not recognize that a monitor is connected at that port. Monitors themselves have no bearing on whether a single or dual monitor set up will work or not. Digital Visual Interface Follow this link, it may help you determine if the adapter you are using is correct for the graphics card.
Apr 22, 2014 | Acer ET.CV3WP.E05 LCD Monitor - V193WEJb...
Cannot Display From Monitor
How long have you waited for it to boot? I know some servers take forever before they send a signal to the monitor. However, if you're get the monitor test screen or "no signal" screen, this usually is a sign that the monitor is not getting any signal from the server, indicating a bad cable or loose connection or the like (though not always if it's still booting). Have you looked in the server cabinet to make sure nothing is broke on the on-board connection or something? Is the DVI port you mentioned on the external PCI card? What does it plug into? I'm guessing you've checked for any installed video cards. Is there another port on the front or anything under a panel?
Nov 27, 2013 | Sun Fire V40z Server
My acer veriton desk top is not booting up and giving a beep continues beep also moniter is not displyaing omething
This is likely a result of the computer not recognizing the monitor. During the POST test during startup,the computer will check for a video output. It can range from the video card failing to just not having the monitor plugged in. I would check you connections, perhaps try a different monitor, even a television that has either HDMI, DVI, or VGA input. If that does not fix it, it is likely your graphics card or on board graphics from the motherboard. Is there anything new since the last time the computer worked? How old is your PC?
Jul 10, 2012 | Computers & Internet
I have HP Pro3000MT, and it has vga and dvi port. I want to use dual monitor for this pc. the monitor are HP LCD and it only has vga input. first i use vga port, secondly i use this dvi cable to connect to...
you need a dvi to vga adapter not a dvi to vga plug and you must also go into your graphics card setup catalyst control center if its ATI Nvidia Display manager for Nvidia if you boot the computer with it pluged in and you can see the boot screen on bolth displays then its an os thing just right click and select the display manager the activate all display's through the managers
Apr 01, 2011 | HP SmartBuy Pro 3000 MT Pent Dual Core...
Need help with a new video card I install in my dell precition 360 don have video
Hello there,
This is the supported Graphics Cards the computer you have can use
Graphics Support . . . . . . . . . . . . . . . . . . . . . . nVIDIA® Quadro 4 280 NVS 64MB DDR, AGP 8X, available in single or dual VGA and single or dual DVI
nVIDIA QuadroFX 500, 128MB DDR, AGP 8X, dual monitor (VGA and DVI or two VGA)
ATIæ Fire GLô X1, AGP 8X, 128MB, dual monitor (VGA and/or DVI)
3Dlabsæ Wildcat4ù 7110, AGP 8X, 256MB DDR, Dual monitor (VGA and/or DVI)(Desktop chassis only)
let me know the Model of the Video Card you are trying to install and we can start fixing the problem
Thank you don't forget to Rate
Jan 25, 2011 | Dell Computers & Internet
I have this monitor hooked to my PC ATI 7500 graphics card with a DVI cable. When the PC initially boots up, the monitor display is blank - it does not display the boot-up messages until the MS Windows...
This is normal. Your monitor has a VGA hook in for regular definition. What it is doing, the monitor always by default looks for the VGA hook first. On my desktop it does the same thing until it finds a signal on the DVI.
Dec 29, 2009 | Samsung SyncMaster 940MW 19" LCD Monitor
Can I add another monitor with (dvi) output to this computer?
You will need a graphics card that supports dual DVI modes.
Dec 20, 2008 | Sony VAIO PCV-RS710G PC Desktop
"No signal detected" when LCD connected with DVI-D Cable
Thank you for providing your configuration details.
You have failed to specify wheather or not your LCD Display is under Warrenty.
Perhaps these simple trouble shooting procedures will get the job done.
1. use the DVI to VGA adaptor that came with your card
Plug in a regular CRT monitor to the Primary Display Output Port using the DVI to VGA adaptor
( either port can be designated as the primary by you )
I like to use the Port nearest to the motherboard as the Primary
2. plug in the your LCD monitor on Secondary Display port using your DVI cable
At this point you should be able to see your desktop on the Primary CRT Display
3. Go to the display properties and use the Nvidia Dual Display Setup Wizard
set both desktops to CLONED at a resolution of 1024x768 and set the refresh to 60Hz
which is default for most LCD displays , some have higher refresh rates , consult your user manuel
If the display resolution and refresh are set incorrectly for your CRT or LCD you will see
Signal Out of Range ( if the display has the ability to display that error message )
At this stage both displays should be showing a Windows Desktop
If you now see your desktop on both displays , you can now put the LCD on the Primary Port
No Signal Detected ( this means the display device is not receiving a signal )
If your LCD display is still displaying the error message
"No Signal Detected" after performing the trouble shooting proceedures
You may need to read the user manuel about how to enable DVI signal input.
If you are certan you have done everything correctly but still see only "No Signal Detected"
Your LCD Display may need replacement
Loch Hime :-)
Sep 14, 2008 | BenQ FP71E 17" LCD Monitor
Mag monitor doesn't display bios post
I have no experience with the DVI links because such technology is still unavailable here in Argentina. We have DVI video cards but finding a suitable DVI monitor is another (long) story.
I think that your card (that has 2 DVI ports) is initializing one port first (the primary one) and then, when windows starts, it initializes the other and outputs video from both ports.
Try connecting the monitor in the other DVI port.
If your card has a VGA output, the VGA gets initialized first.
May 06, 2008 | Computers & Internet
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
