hello chad
Seem to be circuit issue.
You can check charger with volt meter to check its working ok.
Drain all resistors of power by removing battery and charger and holding down power button for 10 seconds.
There is a power button board that can be bad.
I like to break things down by just powering the laptop with memory and keyboard, power button board only. this will require removing motherboard power button board so it will only be the parts to POST.
Minimal Post .
It can be an array of things from the systems casing shorting it out to other hardware.
You need a charger with this features:
90W Laptop AC Adapter / Charger for HP Pavilion DV5-1125NR / DV5-1127CL Replacement
Diameter : 5.0 mm x 7.4 mm
Input Volt Type : AC
Input Volt: 110-220V (Worldwide Use)
Output Ampere : 4.74A
Output Power : 90 Watt
Output Volt : 19V
You can buy one at: http://www.buy.com/prod/90w-laptop-ac-adapter-charger-for-hp-pavilion-dv5-1125nr-dv5-1127cl/q/loc/101/215845345.html for $19.89 including shipping. If this was helpful, please rate me. Thank you
From the link you gave its seen that its comparatively lower than the other series..Brand: HP Laptop BatteryBattery Info: Li-ion, 4400 mAh, 11.10V, Black, 310.00(g), 205.15 x 59.20 x 37.50 mmRating: Capacity Voltage Price($)4400 mAh
11.10V
C $ 57.79 8800 mAh
11.10V
C $ 79.69 Availability: In stock Notes for charging Hp Pavilion dv1000 Series battery :
You must fully drain the Hp Pavilion dv1000 Series battery until the laptop goes into hibernation for your first use it.
Store it in a cool and dry area. Do not expose battery to water or other moist/ wet substances.
Do not forget to take away your Hp pavilion dv1000 battery from the laptop if you will not use it for a long time.
Know that after that plug in your charger and allow it charge for 12 hours or depending on what the technician has told you. 12 hours is the max and you can use it while charging .
Charge new Hp Pavilion dv1000 Series battery for three times at first. After that it will take less than 2 hours to fully charge your Hp Pavilion dv1000 Series battery.
It is normal for HP laptop battery to become warm during charging and discharging.
Learn that this is recommended so that the Hp Pavilion dv1000 Series will heat up for the time allowing ions to reawaken.
Go to the control panel > Power Options, click on the hibernation tab and uncheck it. Click on apply and ok. Hibernation can damage older HP systems such as the DV1000 that is running XP, make sure it is turned off and also go through the power settings and change the setting for closing the lid on the laptop. Change the setting to "Do Nothing". This will keep your system from getting corrupt.
No Power at all sounds like the Internal DC Power Jack that is soldered onto the motherboard is bad. Send it to these guys www.generalsystemsconsulting.com
All lights come on HP Pavilion dv1000 but will not boot. looked at motherboard and by power connector there is a blown part the number on the board shows PD27. I need to know what thhe part is or a schematic showing
