Hi u can use the same charger::: the batteries are a bit bigger ::: check if they will fit in you're battery compartment length mm 225. Width 135 mm
Height 216 ....
35 amp batteries size :::: length 195 mm. Width 130 mm height 159 mm.....cheers
I'm sorry to hear that the fitting instructions for your LiteFX vertical blinds are unclear. Here are some general instructions that may help you with the installation process:
First, you'll need to measure the width and height of the window where you want to install the blinds. Make sure to measure accurately to ensure a proper fit.
Next, mount the brackets on the top of the window frame or wall. The exact placement of the brackets will depend on the type of mounting hardware that comes with your blinds.
Once the brackets are in place, slide the headrail of the blinds into the brackets. Make sure the headrail is securely in place.
Attach the wand control to the headrail. This will allow you to easily open and close the blinds.
Finally, attach the vanes to the headrail. The exact method for attaching the vanes will depend on the type of LiteFX vertical blinds you have.
If you're still having difficulty with the installation process, I recommend contacting the manufacturer or retailer of your blinds for more specific instructions. They may also be able to provide you with additional resources, such as installation videos or diagrams, that can help you with the process.
Tires are typically measured tire width (sidewall)/tire ride height/wheel size. The differences of the two tire sizes you published are .4 of an inch difference in width/sidewall. And about .55 in over all diameter which would impact you revs per rotation. Depending on your wheel size.
Attached is a comparison of the two given the variable of 17" rim.
Stock Tire>Search TiresTire 1 - 255/70R17>Search TiresTire 2 - 265/70R17>Search Tires
Section Width:
Section Width:
10.03 in
255 mm
Section Width:
10.43 in
265 mm
Rim Diameter:
Rim Diameter:
17 in
431.8 mm
Rim Diameter:
17 in
431.8 mm
Rim Width Range:
Rim Width Range:
6.5 - 8.5 in
Rim Width Range:
7 - 9 in
Overall Diameter:
Overall Diameter:
31.05 in
788.67 mm
Overall Diameter:
31.60 in
802.64 mm
Sidewall Height:
Sidewall Height:
7.02 in
178.30 mm
Sidewall Height:
7.30 in
185.42 mm
Radius:
Radius:
15.52 in
394.20 mm
Radius:
15.80 in
401.32 mm
Circumference:
Circumference:
97.54 in
2477.5 mm
Circumference:
99.27 in
2521.4 mm
Revs per Mile:
Revs per Mile:
669.8
Revs per Mile:
658.2* Source http://www.1010tires.com/TireSizeCalculator.asp?action=submit
I added the above link so you can research further or change any variables you need to know. However, the most important thing to understand is the impact of your speedometer. Different sizes will have different impacts. For example going to a bigger tire will show a slower speed on your spedo that your traveling.
mcdevito75 here, Ebay is your best bet for the Leather band for your Cartier watch, but! you:ll need to know the MM size of the band. Measure the width of the band just as it hooks onto your watch, use a ruler, most rulers have both the MM scale and American, if your ruler has only the American mmeasurement use the online Standard to MM calculator for the MM size from the American or standard measurement. Carefully measure the width of the band just as it hooks onto the watch, count the segments in the ruler either each MM or each 16 th of an inch, convert to MM then look on ebay for the strap.
From the computer, open the document to be printed within an application program.
Click on [File] on the toolbar, and then click [Print]. The Print window will be displayed.
Click on the [Properties] button, or the [Printing Preferences] button. The Properties or Printing Preferences window will be displayed.
Click on the [Paper / Quality] tab.
NOTE: Most applications will automatically provide the page size information to the driver. If not, steps 8 - 10 describe how to create a custom page size.
Select the required paper size from the Document Size pull down menu, if available.
If the required custom paper size is not available click on the [My Customer Sizes…] button.
To create a new custom paper size setting click on the [New] button.
In the Name field enter the name to be given to the custom paper size. For example 127 mm x 394 mm (5 in. x 10 in.)
In the Width field enter the width of the custom paper size.
NOTE: The width should always be the short edge of the paper. For example, if the custom size is 127 mm by 394 mm (5 inches by 10 inches), the width must be set to 127 mm (5 inches) regardless of the orientation of the document or the feed method on the printer.
In the Height field enter the height of the custom paper size.
NOTE: The height should always be the long edge of the paper. For example, if the custom size is 127 mm by 394 mm (5 inches by 10 inches), the height must be set to 394 mm (10 inches) regardless of the orientation of the document or the feed method on the printer.
Click on [Save]
Click on [Close].
Select the required paper size from the Document Size pull down menu.
Click on [OK] twice to print
From a Mac OSx:
Click on [File] on the application toolbar, and then click on [Page Setup]. The Page Setup window will be displayed.
From the Printer Description pull-down menu, select the correct PPD file for your printer.
Select the custom paper size for your document from the Paper Size pull-down menu.
If the required custom paper size is not available click on the [Manage Custom Sizes…]. The Custom Page Sizes window will be displayed
To create a new custom paper size setting click on the [+] button.
Double click on [Untitled] and enter the name to be given to the custom paper size.
At the Page Size field enter the width and height of the custom paper size.
