Question about Panasonic DMR-EH50 DVD Recorder
Looking for the region codes!
I have been looking everywhere for the code that could make my Panasonic DMR-EH50 multiregion, but with no luck!
I have only found one so far, but it didnĀ“t work..Help, plz...
*Snowy
I want to make my panasonic dmr-eh50 to multi dvd region player. How to get the dvd multi region code?
Posted on Jul 24, 2009
Changing region code to play all dvd's
You can find a work around from this website
http://www.dvdchips.co.uk/
Solderless upgrade for R2 Panasonic DMR-E75.
This custom manufactured version of our Chipped Remote will convert Panasonic DVD recorders to Multiregion without removing the cover. A disc will also be supplied and MUST BE USED BEFORE THE REMOTE !
newcustomremote.jpg This remote and disc will upgrade one recorder only. Orders will be taken via Credit or Debit Card at the price of £20.00 including shipping, please read our Remote Recycling Policy HERE.
Please read the instructions below before ordering, you may need to download acrobat reader to view them. Instructions for the disc will be supplied with it. THE DISC MUST BE USED BEFORE THE REMOTE !
Mar 26, 2008 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Panasonic DVD VHS combo DMR-EZ48V will not play region 1 dvd
This is happening because your DVD is NOT all region, you need to change the Code.
en.wikipedia.org/wiki/DVD_region_code -
www.dvdexploder.com/ -
www.dvdexploder.com/multihacks.htm
www.allformp3.com/dvd-copy.../dvd-region-code- free.htm -
www.dvd.reviewer.co.uk/info/multiregion/ -
Ok check those links out they will help you sort it.
Apr 01, 2010 | Panasonic DMR-ES40VS DVD Recorder/VCR
Unlock region code on DVD player
http://www.dvdexploder.com/multihacks
go here and have a look
Apr 30, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Trying to make DVR work after 2-17-09
I have been able to record down converted HDTV shows on my Panasonic DMR-EH50 recorder directly to the unit's hard drive and/or directly to a blank DVD-R disc.
I do not know of any DTV converter box that can provide the proper codes to the Panasonic DMR-EH50 to allow recording and scheduling of shows using the unit's built in TV Guide menuing functions (the program recording codes are essentially VCR Plus codes in the USA and VCR Video codes in the UK, and this technology was previously owned by TV Guide/Gemstar but was purchased by Macrovision within the past couple of years.)
When the DMR-EH50 is hooked up to standard RG-59/U coaxial TV cable, the cable company provides the specific VCR Plus recording codes, as well as auto setting the time and date information required for the TV Guide recording schedule menus. The VCR Plus recording codes are sent via the cable company through the coaxial cable to the end consumer's recording device. Since Gemstar's VCR-Plus patents are now owned by Macrovision, I am not sure of how this works (or will work) for non-cable/non-satellite customers or if such codes will be made available by Macrovision to record shows when one receives HDTV signals (or down converted DTV signals) from an over-the-air antenna.
Though the DMR-EH50 recorder can only record at Standard Definition (SD) broadcast resolutions, I connect the DMR-EH50 to my High Definition TV using the three progressive scan YPBPR output cables and switch my HD-TV into the YPBPR mode when I want to watch shows from the DMR-EH50.
YPBPR are the analog video signals carried by three color coded component video cables. The green cable carries the Y signal; the blue cable carries the PB signal; and the red cable carries the PR signal. The added benefit of using the YPBPR hookup is that you can 'up convert' a standard DVD disc (non HD Blu-Ray disc) in progressive scan mode to somethin akin to 720p resolution using the DM-EH50 (or any other progressive scan DVD player) to get a better quality image on your HD-TV.
Visually speaking, the same appears to hold true for playback of programs recorded on the DMR-EH50's hard drive even though down converted via the DTV converter box, and when played back on an HD-TV using the YPBPR progressive scan cabling hookup.
I also been able to successfully record programs from the DTV converter box to the DMR-EH50 recorder in both 16:9 wide screen and 4:3 normal aspect ratios, but again only in Standard Definition quality.
For NTSC and PAL formats, the correct aspect ratios for any particular TV (the rectangular height and width of your output resolution for a TV screen) can usually be setup correctly for most any DTV converter box by going carefully through the menus on the converter box. Though the converted DTV often will yield 'better looking TV' than cable, it's certainly not high definition however, as the purpose of any DTV converter box is * not * to yield a High Definition digital TV signal but a lower quality Standard Definition signal for viewing on older SD-TVs.
We must remember that what is happening here is that (by NTSC USA standards), we are transcoding (i.e., down converting) an over the air 1920 x 1080p (progressive scan) High Definition digital broadcast signal, captured by your over the air antenna, back to a Standard Definition 720 x 480 resolution analog broadcast signal (the 720 x 480 resolution is a 4:3 aspect ratio.)
Hope this helps a little -
Greg Loveria
Conklin, NY USA
Jan 03, 2009 | Panasonic DMR-EH50 DVD Recorder
Multi Region Unlock code
There is more than one model of PS2, and more than one PS2 DVD player module. For some models or modules, only a Messiah 2 or Magic 2 chip installation will make them region free.
However, many can be made region free, for free.
Try this Tip for the steps:
Playstation2 Region Free Fix
I hope that helps.
Aug 20, 2008 | Sony PlayStation 2 (PS2) Console
Looking for the regional code for a Panasonic DMR-EZ47V DVD/VCR combo in Australia and a Panasonic DMR-ES30V DVD/VCR combo. Can you please tell me how you put the code in. Thanks
Region codes are preset in the DVD unit. DVDs are encoded with a region code and are only playable if the DVD player is programmed with the same code as the DVD itself. If you want to play Australian DVDs, you will want to use code 4. There are 9 codes. Check below to find out what region each code is for:
http://en.wikipedia.org/wiki/DVD_region_code
You usually may only change a region code 3 times before it becomes permanent. You need to enter the menu-setup options in your DVD player and you'll want to look for "region code".
May 03, 2008 | Televison & Video
Zone Free Code for Panasonic DMR E85H
A special remote is used to change the region code. However, to my knowing, it is not availble for the normal consumer.
Mar 25, 2008 | Panasonic DMR-EH50 DVD Recorder
Panasonic DMR-EH50. Dubbing NTSC VCR tapes to HDD
That's normal with different region signals. Only a multiregion recorder/player combo will transfer properly
Jan 03, 2008 | Panasonic DMR-EH50 DVD Recorder
Panasonic DMR-EH50 DVD Recorder Logo
402 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
