Question about Compaq Armada 100S Notebook
Compaq Armada 110 - No screen image
When it is first turned on the 'Compaq' logo comes on but then the screen image goes dark. Occasionally the Windows logo flutters on and off briefly but otherwise all is dark - is there a setting or function to reset the contrast/resolution or is it dead? Thanks
    Problem Solver:
  • 5 Answers
WELL I WOULD LIK TO SUGGEST U TO PLEASE RE-INSTALL YOUR GRAPHIC CARD'S DRIVER AND HAVE A LOOK.
Posted on Nov 05, 2007
How to Enter BIOS for a Compaq Armada 1592DT
As SOON as you press the Power On button, start tapping on the F10 key. Tap in 2 second intervals.
You may hear beeps as you perform this. Ignore them. They are
Stuck Key Error beeps.
You should not wait until the Compaq logo comes up, then press the F10 key. This is because the window of opportunity goes by F-A-S-T.
If I may ask. Why are you entering the BIOS Setup utility?
Post back in a Comment.
Regards,
joecoolvette
Jun 16, 2012 | Compaq Armada 1592DT (255246-001)...
Compaq armada 110 user manual
Hi Misa,
Here's the user guide in pdf.If you're using Windows XP here's the user guide,and for Windows 7 here it is.
Hope this helps.Thanks!
Please rate this answer.
Dec 11, 2011 | Compaq Armada 110 Notebook
My Compaq Presario v2000 will turn on but the screen is just black what do I need to do to fix it?
Can you see any image on the screen in a dark room, using a flashlight sometimes helps. An image will be most visible right after you turn the laptop on, when the logo appears. If you can see the image but it is dark you need a new probably backlight inverter which is a relatively easy and cheap repair - I usually charge less than $50. JC Hunter
Nov 13, 2009 | HP Compaq Presario V2000 Notebook
Compaq armada 110
Verify that you have the required 18.5VDC coming into the laptop by the AC/DC converter. take a multimeter and put the black lead on the outside of the connector and the red on the inside..you should have between 18.5-19VDC
Nov 26, 2008 | Compaq Armada 110 Notebook
Compaq armada 1500c 400/s/4000/d/m/1
try pressing f8 continually at system startup to enter safe mode. From there you can enter safe mode and reinstall your display adapter driver.. Please rate this answer
Sep 09, 2008 | Compaq Armada 1500C Notebook
Armada e500 won't boot
yes u should and u could remove hd to see if bios screen comes out cheak and tak eout 1 ram try anther before u say bad mobo proably tho best bet sell it on ebay used for repair ok
Jan 19, 2008 | Compaq Armada E500 Notebook
OK this is whats wrong
So, you get no icons? Have you tried to do aright-click on the desktop and select 'recover desktop' or something of that nature?
Jan 13, 2008 | Compaq Armada E500 Notebook
Start up problem
it is struggling to find the boot.ini, you can try pressing F8 when it's booting up and then you should get into safe mode, when in select last known good configuration and then press enter for a reboot.
If you still cannot get into windows you will need to perform a system repair, borrow a friends XP disc, but use the key code normally on the underneath of notebooks of your own system if you have one, then set your cdrom as first boot device in the bios (F2 or Del on boot up) and then insert the disc, then press enter to boot from cdrom and press R for repair when prompted.
Oct 15, 2007 | Compaq Armada M700 Motherboard
Compaq Armada 100S Notebook Logo
99 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
