Question about Microsoft Internet Explorer 8
When i try to run anything i get a message (where i used to get the "click here to install active x) that says internet explorer is running w add ons disabled. when i manage my add ons they all say enabled. im so frustrated. any suggestions? i have already rebooted my computer several times.
    Scholar:
  • 106 Answers
Download and install firefox from firefox.com . It is free. When you install it, do not import you IE settings. After installing firefox. You will need to install flashplayer free from www.macromedia.com will take you to the adobe link for the free flash player download.
Also, update your java, free from www.java.com
You will not get anymore errors now when visiting sites.
Posted on Jun 24, 2009
Will Not Download
What browser are you using?
May 10, 2013 | Acer Computers & Internet
Tip
Internet Explorer 8 takes longer than expected to start.
Symptom:
When launching Internet Explorer, you may notice that Internet Explorer takes longer than expected to start.
Cause:
This issue can be caused if there are damaged or incompatibilities with installed Internet Explorer add-ons. This behavior may be more visible in Internet Explorer 8 due to changes in the way that Internet Explorer 8 handles the internet zones list.
This issue can also be caused if using Spybot and the Spybot immunization feature is enabled.
Resolution:
To resolve this issue, troubleshoot the Add-ons to determine which Add-on may be causing the issue and then disable or uninstall the Add-on and then contact the manufacturer of the Add-on for support with that Add-on.
To do this, follow the steps listed below starting with Step 1.
Note: If you currently have Spybot installed with the immunization feature enabled, you will need to disable that feature until that issue is resolved. If you’re not sure how to disable the immunization feature, contact the vendor for more help.
Step 1: Run Internet Explorer 8 in "No Add-ons" mode to determine if the issue is Add-On related.
loadTOCNode(2, 'resolution'); Internet Explorer 8 add-ons, such as ActiveX controls and browser toolbars, are used by some Web sites to provide an enhanced browsing experience. An error may occur if an add-on is damaged or if an add-on conflicts with Internet Explorer 8.
To determine whether the error is caused by an add-on, run Internet Explorer 8 in "No Add-ons" mode. To do this, follow these steps:
  1. Click Start, and then type Internet Explorer in the Start Search box.
  2. Click Internet Explorer (No Add-ons). Internet Explorer 8 opens without add-ons, toolbars, or plug-ins.
  3. Test Internet Explorer to verify that it works correctly. If issues still occur, try Step 3.
If no errors occur, the problem is caused by one of the add-ons that typically load together with Internet Explorer 8. In this case, continue to Step 2 to determine what Add-on is causing the issue.
Step 2: Use the Manage Add-ons tool to determine which add-on is causing the issue
loadTOCNode(2, 'resolution'); Use the Manage Add-ons tool in Internet Explorer 8 to individually disable each add-on to determine which add-on is causing errors. To do this, follow these steps:
  1. Open Internet Explorer 8.
  2. Click Tools, point to Manage Add-ons , and then click Enable or Disable Add-ons.
  3. In the Show box, select Add-ons that have been used by Internet Explorer to display all add-ons that are installed on the computer.
  4. For each item in this list, select the add-on, and then click Disable under Settings.
  5. When you have disabled all the items in this list, click OK.
  6. Exit and then restart Internet Explorer 8.
  7. If issues do not occur, repeat steps 1 through 3.
  8. Click Enable for a single add-on.
  9. Repeat steps 6 through 8 until you determine which add-on causes errors to occur.
After you have used this process to determine which add-on is causing errors, you can disable that add-on. Or, you can uninstall the software that installs the add-on. We also recommend that you contact the software vendor that provided the add-on for additional troubleshooting and support.
Step 3: Reset Internet Explorer 8 settings
loadTOCNode(2, 'resolution'); To determine whether a performance issue or an error message is caused by configuration settings, reset Internet Explorer 8 to its default configuration. This step will also disable any add-ons, plug-ins, or toolbars that are installed. Although this solution is quick, it also means that, if you want to use any of those add-ons in the future, they must be reinstalled.
  2. Click Tools, and then click Internet Options.
  3. Click the Advanced tab.
  4. Under Reset Internet Explorer Settings, click Reset.
The information in this article applies to:
  • Windows Internet Explorer 8
Keywords: MS Article ID 969938
on Mar 29, 2010 | Computers & Internet
Tip
For All XP user Don't Use IE 7.0 & higher version
Applicable for all window XP (all edition, all PCs and Laptops)
If you are getting trouble after the updates of internet explorer..
Then I would suggest you to Roll Back it to the original Internet Explorer (i.e Internet Explorer version 6.0)
Which come up with Installation of Win Xp with Service Pack 2.
Bad Effect due to IE 7.0 or higher version:
Screen hang up, internet freezes abruptly, prominent windows crashes anytime.
So to stop these problems, better to run with lower and safe version of IE:
To remove Internet Explorer 7 from your PC use the following methods
Method 1: Use "Add or Remove Programs" to uninstall Internet Explorer 7
Step 1: Use "Add or Remove Programs" to uninstall Internet Explorer 7
a. Click Start, and then click Run.
b In the Open box, type appwiz.cpl, and then click OK.
c. In the list of programs, click Windows Internet Explorer 7, and then click Remove.
d. Follow the wizard instructions to uninstall Internet Explorer 7. Also remove if any updates under this entry found.
If you cannot uninstall Internet Explorer 7 by using this method, try Method 2.
Method 2: Use Spuninst.exe to uninstall Internet Explorer 7
Run Spuninst.exe to uninstall Internet Explorer 7
b. In the Open box, type %windir%\ie7\spuninst\spuninst.exe, and then click OK.
c. Follow the wizard instructions to uninstall Internet Explorer 7.
After you uninstall Internet Explorer 7, double-click the Internet Explorer icon to verify that Internet Explorer 6 is restored.
This will bring up you to run Internet explorer as it come up with the installation kit, which is safe and reliable.
Have Nice Surfing!!
Ellin
on Oct 14, 2008 | Microsoft Windows XP Home Edition
I need a fix for internet exployer
Microsoft's Internet Explorer 8 (IE8) browser includes "add-on" applications that can be downloaded and installed from Microsoft, or third-party providers, into Internet Explorer.
Occasionally, add-ons may conflict with other add-ons or software on the computer, causing errors.
These can also occur when IE settings conflict with newly installed add-ons.
Resolve add-on related error conditions quickly in IE8 by resetting Internet Explorer to Microsoft defaults.
Click the "Start" button. Click "Run" or "Search," and type "inetcpl.cpl in the "Run" or "Search" box, and press the "Enter" key.
Select the "Advanced" tab in the "Internet Options" window, then click the "Reset" button.
Click the "Reset" button again to confirm that you wish to reset Internet Explorer to Microsoft defaults.
Select the "Close" button, once the display indicates that the reset process has been completed.
Click the red "X" in the upper-right corner of Internet Explorer to close the browser.
Open Internet Explorer and the errors should be resolved.
also
Experience problems with Internet Explorer 7 right off the bat, and it may be due to installation problems.
Make sure you reboot twice after installing the new browser.
Download any updates for IE7.
Check the Microsoft website for recommended updates if you don't have automatic updates turned on for your computer.
Check your add-ons, those "extras" like ActiveX controls for your browser, if you still experience problems.
After accessing "manage add-ons" through the "Tools" menu in your browser window, disable all add-ons, and try browsing.
If you can successfully browse without errors on the page, then one of your add-ons may be the culprit. Enable add-ons one at a time and try browsing.
Once you find the problem, delete it or update the add-on to work with Internet Explorer 7.
Contact Microsoft if a website denies permission for entering when it shouldn't.
It could be a problem with document. domain property or the protocols of the URLs not matching.
Update and run the most recent version of JavaScript. JavaScript is a scripting language used on many websites.
Adjust security settings in the browser if you still experience page error messages.
Select the "Tools" menu and access "Internet Options." Under the "Security" tab, choose "Custom Level" to pull up the security settings window and review for possible problems.
Hope this helps
Nov 13, 2012 | Microsoft Internet Explorer 8
When i try to open it. it will flash in and out and something will come up explorer unhandled exception..report file..save file..cancel
This sounds like a problem with an add on for Internet Explorer. If you have installed any toolbars, such as Google Toolbar, Ask.com Toolbar, or even the Bing toolbar, they should be removed.
To confirm that this is the problem, you should try this: Click on Start, All Programs, Accessories, System Tools, and click Internet Explorer no add-ons.
If you can browse without getting this message you it is one of the addons that you have installed. Usually addons for Internet Explorer are listed in the Add/Remove Programs list found in the control panel.
Another possibility is a virus or some other form of malware.
You can try running Spybot S&D (download)
and/or try running and installing a free anti virus program, if you do not have a program already.
One I recommend and use personally is Comodo Internet Suite
May 13, 2011 | Computers & Internet
I get this massage when i start use msn games ActiveX Objects Missing 2 Messenger games require ActiveX objects in order to play. Please verify that you have the ability to install ActiveX objects...
That usually indicates some settings in your Internet Options have been changed in your security settings, and it is blocking the installation of Active X add ins for your Browser.
With your Internet Explorer open, click on TOOLS > Internet Options.
Click on the Tab Security.
The Icon for Internet should be highlighted.
Look for a button " Restore Defaults" and click on it. Then click on the Apply Button.
Then click on the Tab General and Click on the Delete button in the center of the screen.
Delete the Cookies and Temporary Internet Files
Close Internet Explorer, and reopen it.
Try your games again and see if it prompts you to install the Active X add ins it needs to run the games.
If you need to reply, use the "add a comment" link.
Thank you.
Apr 20, 2011 | Computers & Internet
I can't see the messages I send and messages I receive on the chat box using yahoo messenger
hello
Solution 1
Open internet explorer
To enable scripting:
Click the "Tools" menu on your Internet Explorer toolbar and select "Internet Options."
Click the "Security" tab.
Click the Internet (globe) icon and click the "Custom Level" button.
Scroll down to "Scripting."
Enable the following:
* Active scripting
* Allow paste operations via script
* Scripting of Java applets are all enabled
Click the OK button at the bottom of the window.
Solution 2
1. On your keyboard, hold down the Windows key and press the R key. This opens the "Run" command.
2. Type in appwiz.cpl and click OK. This opens "Add or Remove Programs."
3. Select Java and then click the Uninstall button. There may be multiple installed versions, so be sure to remove all of them.
4. Next, download and install the latest version of Java Runtime Environment
5. To ensure the update is effective please Clear the Yahoo! Messenger Cache
6. Restart Messenger to determine if the issue is resolved.
thanks
Mar 08, 2011 | Yahoo Messenger
Every single time I go on facebook and sometimes on other sites;I get an error that says out of memory on line: 140. Anyone have any ideas of what that is all about? I've tried changing my comp...
Method 1: Clear cached data in Internet Explorer
To determine whether a performance issue or an error message is caused by corruption in the temporary Internet files or in other cached information that is used by Internet Explorer, you must clear cached data. To do this, follow these steps:
Internet Explorer 7
1. Open Internet Explorer 7.
2. Click Tools, and then click Delete Browsing History.
3. In Delete Browsing History, click Delete All.
4. Click to select the Also delete files and settings stored by add-ons check box, and then click OK.
Run Internet Explorer in "No Add-Ons" mode
Internet Explorer add-ons, such as ActiveX controls and browser toolbars, are used by some Web sites to provide an enhanced browsing experience. An error may occur if an add-on is damaged or if an add-on conflicts with Internet Explorer. To determine whether the error is caused by an add-on, run Internet Explorer in "No Add-Ons" mode. To do this, follow these steps:
2. Click Internet Explorer (No Add-Ons). Internet Explorer opens without add-ons, toolbars, or plug-ins.
Oct 13, 2009 | Computers & Internet
White screen suddenly appears Blank Page Windows
Try these steps first. I assume you are using IE 7. If these steps do not work try reinstalling your IE. Let me know if you need anything else. Good Luck.
Method 1: Clear cached data in Internet Explorer 7 loadTOCNode(2, 'moreinformation'); To determine whether a performance issue or an error message is caused by corruption in the temporary Internet files or in other cached information that is used by Internet Explorer 7, you must clear cached data. To do this, follow these steps:
A progress bar is displayed to indicate that the browsing history is being cleared. After this process is complete, test Internet Explorer to verify that it works correctly. If issues still occur, try Method 2.
Method 2: Reset security settings for Internet Explorer 7 loadTOCNode(2, 'moreinformation'); If you configure security settings to be too restrictive, you may prevent Internet Explorer 7 from displaying certain Web sites. To determine whether an issue is caused by overly restrictive security settings, revert to default security settings. To do this, follow these steps:
  3. Click the Security tab.
  4. Click Reset all zones to default level, and then click OK.
After you do this, test Internet Explorer to verify that it works correctly. If issues still occur, try Method 3.
Note If this method does not resolve the issue, you can restore Internet Explorer 7 to its previous security level.
Method 3: Run Internet Explorer 7 in "No Add-Ons" mode loadTOCNode(2, 'moreinformation'); Internet Explorer 7 add-ons, such as ActiveX controls and browser toolbars, are used by some Web sites to provide an enhanced browsing experience. An error may occur if an add-on is damaged or if an add-on conflicts with Internet Explorer 7. To determine whether the error is caused by an add-on, run Internet Explorer 7 in "No Add-Ons" mode. To do this, follow these steps:
  2. Click Internet Explorer (No Add-Ons). Internet Explorer 7 opens without add-ons, toolbars, or plug-ins.
  3. Test Internet Explorer to verify that it works correctly. If issues still occur, try Method 4.
If no errors occur, the problem is caused by one of the add-ons that typically load together with Internet Explorer 7. In this case, use one of the following options.
Option 1: Reset Internet Explorer 7 loadTOCNode(3, 'moreinformation'); Reset Internet Explorer 7 to its default configuration. This step will also disable any add-ons, plug-ins, or toolbars that are installed. Although this solution is quick, it also means that, if you want to use any of those add-ons in the future, they must be reinstalled. To reset Internet Explorer 7 settings, use Method 4.
Option 2: Use the Manage Add-ons tool to determine which add-on is causing the issue loadTOCNode(3, 'moreinformation'); Use the Manage Add-ons tool in Internet Explorer 7 to individually disable each add-on to determine which add-on is causing errors. To do this, follow these steps:
  2. Click Tools, point to Manage Add-ons, and then click Enable or Disable Add-ons.
  6. Exit and then restart Internet Explorer 7.
Mar 13, 2009 | HP Pavilion dv4000 Notebook
How do i uninstall microsoft active x control on my pc?
Internet Explorer 3.0, 3.01, and 3.02 loadTOCNode(2, 'moreinformation'); 1. Click Start, point to Settings, click Control Panel, double-click Add/Remove Programs, and then click the Install/Uninstall tab. 2. If the ActiveX control you want to remove appears in the list of installed programs, click the ActiveX control, click Add/Remove, and then follow the instructions on the screen. If the ActiveX control does not appear in the list of installed programs, continue with the next step. 3. Click Start, click Run, type the following line in the Open box, and then click OK: regsvr32 drive:\windows\occache\filename.ocx /uNOTE: drive is the drive letter on which the Windows folder is located, windows is the name of the folder in which Windows is installed, and filename.ocx is the ActiveX control you want to remove.
NOTE: If you do not know the file name of the ActiveX control (.ocx) you want to remove, you may be able to determine the file name by viewing the Hypertext Markup Language (HTML) source of a Web page that installs or uses the ActiveX control. To view the HTML source of a Web page, right-click an empty area of the Web page, and then click View Source. 4. In Windows Explorer or Windows NT Explorer, click the .ocx file in the Windows\Occache folder, and then click Delete on the File menu.Occache is the name of the folder where ActiveX controls are installed in all versions of Internet Explorer 3.x. The Regsvr32.exe file is installed by Internet Explorer and can be used to register and remove registry entries for ActiveX controls.
Internet Explorer 4.x or Later (All Platforms) loadTOCNode(2, 'moreinformation'); Internet Explorer 4.x or later, include the Occache.dll file, which is used to enumerate, update, and safely uninstall ActiveX controls using a "shell folder." 1. Click Start, point to Settings, click Control Panel, double-click Add/Remove Programs, and then click the Install/Uninstall tab. 2. If the ActiveX control you want to remove appears in the list of installed programs, click the ActiveX control, click Add/Remove, and then follow the instructions on the screen. If the ActiveX control does not appear in the list of installed programs, continue with the next step. 3. In Windows Explorer or Windows NT Explorer, double-click the Windows\Downloaded Program Files folder or the Winnt\Downloaded Program Files folder, right-click the ActiveX control you want to remove, and then click Remove. 4. When you are prompted to remove the ActiveX control, click Yes.IMPORTANT: The following ActiveX controls should not be removed if you are running Internet Explorer 4.0: • DirectAnimation Java Classes • Internet Explorer Classes for Java • Microsoft XML Parser for Java • Win32 ClassesInternet Explorer 5.0 or later does not require these components in the Downloaded Program Files files.
Error Messages Removing ActiveX Controls loadTOCNode(2, 'moreinformation'); When you attempt to remove an ActiveX control using an Occache shell folder, you may receive one of the following messages: • Share Violation These program files are currently being used by one or more programs. Please close some programs, and try again. You may need to restart Windows. • Component Removal About to remove a Windows system DLL: (<path\filename>). Okay to delete?Share Violation:
This message occurs if the ActiveX control you are trying to remove is currently loaded in memory by Internet Explorer or the Active Desktop component.
To resolve this error message, follow these steps: 1. Close all open Internet Explorer windows. 2. Disable the Active Desktop. To do so, right-click an empty area on the desktop, point to Active Desktop, and then click View As Web Page to clear the check mark. 3. Remove the ActiveX control by following the steps in the "Internet Explorer 4.0 or Later" section earlier in this article.
NOTE: You may need to restart Windows before you remove the ActiveX Control.Component Removal:
This message occurs only in versions of Internet Explorer 4 prior to 4.01 Service Pack 1 (SP1) when the ActiveX control you are removing installed files into a folder other than a registered Occache folder (for example, Windows\System or Winnt\System32). Occache cannot always determine if those files are shared by their programs.
If you are certain the file or files displayed in the message are not being used by Windows or another program, click Yes. Otherwise, click No.
NOTE: In Internet Explorer 4.01 SP1 and later, Occache does not remove (or prompt you to remove) dependent files outside of a registered Occache folder.
Support for Multiple Occache Folders loadTOCNode(2, 'moreinformation'); Internet Explorer 4.0 and later supports multiple Occache folders. The list of Occache folders is located in the following registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\ActiveX CacheBy default, Internet Explorer 4.0 and later uses the Windows\Downloaded Program Files or Winnt\Downloaded Program Files folder. If you upgraded from Internet Explorer 3.x, both an Occache and Downloaded Program Files folder may exist. In this case, all new ActiveX controls are installed in the Downloaded Program Files folder, but previously installed ActiveX controls still work in the Occache folder. When you open the Occache or Downloaded Program Files folder in Windows Explorer, Windows NT Explorer, or My Computer, all ActiveX controls are displayed regardless of the folder in which the ActiveX control's files are located. In this case, the following string values appear in the registry key: "0"="C:\\WINDOWS\\OCCACHE" "1"="C:\\WINDOWS\\Downloaded Program Files" For additional information about ActiveX controls, please see the following article in the Microsoft Knowledge Base: 154544 (http://support.microsoft.com/kb/154544/EN-US/) Description of ActiveX Technologies For information about how Internet Explorer downloads ActiveX controls if a conflict occurs (for example, if the file already exists), please see the following article in the Microsoft Knowledge Base:
HOPE THIS HELPS
Good Luck
Feb 07, 2008 | Intel Motherboard
Open Questions:
Webpage error details User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; .NET4.0C; nsapshr 10.0.3) Timestamp: Mon, 7 Jul 2014 20:45:22 UTC Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js
Jul 07, 2014 | Microsoft Internet Explorer 8
See all Microsoft Internet Explorer 8 Questions
Microsoft Internet Explorer 8 Logo
74 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
