Ball bearing & spring replace
SOURCE: 1997 Toyota land cruiser prado Rz compass bearing, temperature setting, etc.
I've been resetting pajero's compasses but try to get to an area where you can do 360 degrees turns (empty car parks, ) press the reset button and make 2 complete 360 turns slowly and normally this should set the compass bearing.
Let us know how you get on. Cheers.
SOURCE: How to replace front wheel bearing on a 1999
removal of the spindle, and has to be pressed off and on.
SOURCE: does the wheel bearings ever need replaced on a
YOU NEED ARBOR PRESS TO REMOVE INNER RACE FROM THE HUB.YOU NEED SEAL REMOVER TOOL SST 09308-00010 YOU NEED SNAP RING PLIERS YOU NEED BEARING DRIVER DRIVE BEARING FROM THE STEERING KNUCKLE.THE CHEAPER ROUTE IS TO BUY WHEEL BEARING AT A AUTO PARTS STORE THAT IT TO A SHOP THAT DOES BRAKES AND FRONT AND REAR SUSPENSION WORK.BUY THE TOOLS GOING COST.
SOURCE: need to torque cylinder head on a toyota land
Refer to the diagram and torque bolts in sequence as shown in 3 passes. Bolt thread should be lightly oiled. Bolt holes clean of dirt.
1st pass : 39 N.m. (29ft lb)
Make a mark on the bolt with white-out/chalk or similar in the forward facing edge of the bolt.(see diagram)
2nd pass : turn bolt through 90 degrees
3rd pass : turn bolt through a further 90 degrees.
Using a mark on the bolt makes it easier to keep track of where in the sequence you are.
