Kenwood ka 9100 amp
Well the first problem i have found is that it wont turn on. im not sure of where to start looking to see whats no right
  • tly9 Dec 10, 2007
    I have the similar problem with my Pyramid amp. The main Fuse was checked OK. When power on, the Relay on the PCB just shuts off the circuit after a second. However the cooling Fan still runs OK. Removing 2 output wires from big Transformer to PCB. The impedance between 2 input pins to the PCB is about several Kohms so the PCB is not shorted. The impedance at 2 output wires of the Transformer is less than 1 ohm or about 0.5 ohm without load and the voltage across those 2 wires is about 15V so it is not shorted either but I wonder why its impedance is that very low. When connecting them to the PCB, the final impedance across would also go down to less than 1 ohm. This would send a big Amp current to the PCB, I think. Maybe the problem is on the Transformer. Does anyone know how to fix the Transformer? I am going to try to open it up to check inside for any burning or damage component.
  • 54 Answers
Open case and look for fuses in the back check and replace if blown.
make shure power plug is good.check with a volt meter on the input side of the main power transformer.
good luck
big red
Posted on Nov 13, 2007
The Kenwood KA-9100 power switch is two sided. Hook an ohms meter to the end of the power cord and see if you see any change when you flip the switch. If nothing it is probably shot. Check the ohms meter against the unused contacts on the switch, you should see a change when you flip the switch. If you determine the switch is the problem clip off the wires and the capacitor and solder to the other side of the switch. You should be able to do this from the bottom if you take the bottom cover off. I just had Classic Audio repair fix mine that way. My switch was making a sizzling noise. Sometimes it did work.
www.repairaudio.com
3401 Adams Ave
San Diego, CA 92116-2490
(619) 282-9101
Posted on Oct 15, 2009
I have one other question on which Transformer Vendor is used on the Pyramid PA1000X Amplifier. I want to find out if there is a schematic for troubleshooting or to just order a new Transformer. Please help. Thanks.
Posted on Dec 10, 2007
What is the wattage output of the kenwood ka 728 integrated amp?
Specifications Power output: 130 watts per channel into 8? (stereo)
Frequency response: 20Hz to 20kHz
Total harmonic distortion: 0.007%
Input sensitivity: 0.2mV (MC), 2.5mV (MM), 150mV (line)
Signal to noise ratio: 69dB (MC), 87dB (MM), 107dB (line)
Output: 150mV (line)
Dimensions: 340 x 109 x 369mm
Weight: 9.2kg
Year: 1984
Kenwood KA 828 Manual Stereo Integrated Amplifier HiFi Engine
Nov 15, 2016 | Kenwood Audio Players & Recorders
Kenwood KA-76 amp. Left channel distorts and unit overheats then shuts down when volume is turned up. Headphones are not affected.
what happens if you reconnect left and right speakers? Are these problems of the unit or of the speakers/wires?
May 10, 2015 | Kenwood Audio Players & Recorders
Dead Kenwood Home stereo Amp. KA-2002
Some says it is only dead when it is buried.
Open it up and check, ( Be sure it is unplugged)
Only if you feel you can DIY or have a tech do it for you.
Oct 06, 2012 | Kenwood Vintage Model Ka-6006 Stereo...
Kenwood KA-3020 Amp acting poorly
Hate to say it but its probably time for a new amp as 20yrs of service you have gotten your money out of it....
Mar 17, 2012 | Car Audio & Video
How to connect a kenwood ka- 9100 to a pioneer vsx-d608
You don't say, what role the Kenwood is supposed to play but I'll assume you want to slave the Kenwood (and its speakers) to the Pioneer.
The VSX-D608 doesn't have multi-channel pre-outs so you wouldn't have local control of the volume at the Pioneer.
http://www.auctiva.com/hostedimages/showimage.aspx?gid=108365&ppid=1122&image=404270323&images=404269872,404269931,404269984,404270049,404270137,404270323&formats=0,0,0,0,0,0&format=0
The KA could be a subwoofer amp as the Pioneer has a pre-out for that.
Outs to Ins. "Power In" on the KA would be for an external volume-controlled source. Otherwise, use one of its non-Phono inputs.
http://tubehacker.com/sale_item.php?item_id=31
May 29, 2011 | Kenwood Audio Players & Recorders
KENWOOD KA-99 INTEGRATED AMPLIFIER MANUAL
Hi...
Does it look like this?
http://www.hifiengine.com/manuals/kenwood/ka-9x.shtml
Mar 27, 2010 | Kenwood Audio Players & Recorders
Need an owners manual for a kenwood amp
HI...
try www.hifiengine.com ...those are free
or Rick at www.stereomanuals.com
Please rate my help if you can.
Thanks
Feb 21, 2009 | Audio Players & Recorders
Subwoofers not bumpin, amp is still on
Check to make sure there is a good input to the amp. Next check each sub to another source to make sure they are good. Look for any reset on the amp.
Apr 26, 2008 | Kicker CVR12 Car Subwoofer
756 people viewed this question
 Grubhead
Grubhead
