Question about Apple iTunes
Code 10 no cd/dvd drive found, unable to burn cd?
Downloaded new version itunes... cd/dvd-rw drive not working code 10 fix the upper and lower filters per fix...then error message for itunes registry for importing and burning on itunes missing...use driver fix and now the original code 10 back and itunes says no driver found for burning and my dvd drive not working!!! It's like a huge loop help!
    Guru:
  • 111 Answers
To solve this Code 10 error, follow these instructions: NOTE: After removing these registry keys and rebooting, it may be necessary to reinstall any CD or DVD recording applications.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • {4D36E965-E325-11CE-BFC1-08002BE10318}
4)This folder is the DVD/CD-ROM Drive Class Description in the registry.Look for any of the following names in the right hand column.
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the
Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives havereturned. You may also want to open Device Manager and verify that theyellow exclamation and error code on the CD or DVD drive is gone.
Posted on Apr 01, 2010
How to make cd driver work on a compaq evo n150
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
You might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
If this does not fix the problem it might be a registry problem
"you only need to do the following"
if you cant see your disk drive in windows explorer
Click on Start, Run, and type regedit and press Enter
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
After deleting the keys, close the registry editor
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Hope this helps.
Nov 25, 2012 | Compaq Evo n150 CD-RW & DVD-R Combo Drive
PIONEER DVD-RW DVR-112D driver is not installing. Says Available target is not found
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps you
Apr 08, 2012 | Pioneer DVR-112D DVD RW Dual Layer Burner
Pioneer dvd-rw dvrkd08rs ata device version 6.0.6002.18005
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
hope this helps you
Oct 25, 2011 | Pioneer DVR-107D DVD±RW Burner
Around track 8 in its recording process it breaks up the audio signal so when we duplicate it kick out a error then kicks out the CD's
this could be caued by a few possibilities you might not have select to burn an audio copy or the burning software does not support the burning of audio copies although if it burns a few before being interrupted it probably will support audio burning
http://download.cnet.com/burn4free-cd-and-dvd/3000-2646_4-10217894.html
Burn4Free CD and DVD is a burning solution that's compatible with more than 3,000 DVD, Blu-ray and CD burners. Burn data and audio from different file types (WAV, WMA, MP3, OGG, FLAC, WavPack, and CDA). Burn and save ISO files, open and save your project to disk, verify content, print compilations, copy DVD, copy BLU RAY and import your audio compilation from M3U and ASX playlists. The drives supported include dual-layer DVD, CD-R, CD-RW, DVD-R, DVD+R, DVD-RW, DVD+RW, and DVD-RAM, BD-R, BD-RE (SCSI, IDE, EIDE, and USB 1.0 and 2.0).
the other possible reason might be the cd/dvd burner is not getting continuos power during the burn process
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
Jul 06, 2011 | MicroBoards CopyWriter Live (CWL6200)...
My optiarc dvd rw drive isn't recognizing blank new dvd's to burn videos on
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
May 09, 2011 | AGPtek Sony Optiarc AD-7560A CD DVD RW...
Tried uninsatlling and re-installing but dvd drive says unable to find driver code 10
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this dvd-rw burner then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jan 15, 2011 | Sony NEC Optiarc AD-7200S DVD-RW Burner
Philips DVD+RW SDVD8820 does not recognise burned CD or DVDs
it could be upper and lower filters in registry and system files, use a removal tool called filtercheck 4.6 in CDR-zone.com (goto the forums and search for filtercheck)
after you downoad, run it, click yes to all filters found to remove. close program.
reinstall your preferred burning app (1 prog installed at a time and test burn)
this is to replace the filter entry that was corrupt
Nov 09, 2008 | Computers & Internet
CD burning
probably the upper/lower filters fix. Check your device manager and see if the cdrom is reporting error codes. If it's reporting one, you have to do this:
remove the upper/lower filters from the registry(google it) and then reinstall your burning software.
May 01, 2008 | Verbatim (95092) 20 Pack 52x CD-R Storage...
Error (Code 10) with LG GSA-H42N
the upper or lower filters have issues. u have sonic cdr software that is partially damaged. this should fix it http://www.cdr-zone.com/forum/about4719.html&highlight=filtercheck the removal tool. say yes to all and reboot.
Feb 03, 2008 | LG GSA-H42N 18x DVD RW DL IDE Drive...
Dvd not working
Ok this type of thing is very common ... however often we chase our tails looking for a software fix when often it's the DVD/CD itself.. so to find out either way weather the device is FUNCTIONAL, download "CopytoDVD" here www.snapfiles.com/get/copy2dvd.html This has it's own ASPI recording layer... and if your DVD is FUNCTIONAL... then it WILL burn ya DVD... however if the DVD is, as I suspect, .. kaput! then it will NOT burn a DVD.. that's basically how we would "Test" Functionality. So if it works then ya all good.. else ya gonna haveta get a new DVD.
Aug 31, 2007 | Toshiba TS-L532L DVD±RW Dual Layer...
Apple iTunes Logo
330 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
