I suspect it is a ground issue it is hard to say. But I have lots of question. Is gauge wire large enough? Power source? Wires and coax laying across or parallel? If it has been peeked turn mic gain down and see if it helps. If you are using it with a external speak, key it away from speaker. Good luck give your radio man as much info as possible a good one will not want discouraged customer.
SOURCE: how do you tune and peak a cobra 29 ltd classic
i would highly suggest you take it to a cb shop to get a cb tuned and peaked. before you do that though, make sure you have a good antenna system. a good antenna will have a much greater effect on your cb than tuning and peaking. as far as output, who knows? it all depends on the skill of the person doing the tuning. be warned that any output over 4 watts is illegal and you could recieve hefty fines if caught with an illegal radio.
