Question about Olympus WS-100 Digital Voice Recorder
USB port How the heck do you remove the battery compartment to get to the USB port? I have been pulling on it trying to remove it and it just will not come off. Is there a trick or what am I doing wrong? I don't want to break it.
  • 91 Answers
You have to first turn off the device, elsewhere you wouldn't be able to remove the battery compartment.
After that, pull it hard and it will get off.
Posted on Nov 24, 2007
How do I repair the USB PORT on a ACER ICONIA B1.
Step 1 - Back Case
  • To start, gently separate one corner of the case using the black spudger.
Step 2
  • Once you have successfully pried the spudger in between the front case and back case, continue do so around the entire tablet until the back case is completely disconnected.
Step 3 - Battery
  • Remove the 5mm screws that are securing the battery to the rest of the tablet.
    • Use the Phillips #00 Screwdriver to remove the 5mm screws.
Step 4
  • Use the sharper end of the spudger to disconnect the battery from the mother board.
    • The battery connector will slide off.
Step 5 - USB Port
  • After setting aside the battery, remove the two 5mm screws holding the metal plate over the USB port.
Step 6
  • Find and remove the silver 5mm screw holding down the metal cover opposite the USB port.
Step 7
  • Disconnect the blue cable by gently lifting the flap.
  • Remove the indicated 2mm screw holding the speaker in place.
Step 8
  • Pull up the metal panel just enough to allow access, then remove the USB port.
Oct 29, 2014 | Acer Iconia B1 7-Inch Tablet Black Dual...
Find the cmoss battery d505
Unplug the Dell Latitude D505 laptop from AC power. Turn over the so that the base of the computer faces upward. Locate the battery panel on the bottom of the computer and then press the latch on the battery panel in the direction of the arrow on the latch. Lift the battery from the battery compartment.
Press on the latch located toward the front of the computer inside the battery compartment. Pull the cover that is released out and down and remove the cover from the battery compartment.
Grasp the small battery in the slot uncovered when the cover was removed and pull the battery away from the slot to detach the battery from the laptop
Dec 12, 2011 | Dell Latitude D505 Notebook
How do I repair the USB port on my Dell S17-162B?
Well Mr.Brown,
It's not much difficult but i suggest you to send it to DELL support if it lies in warranty.
any way here i am providing complete step by step procedure to do it.
1) First open the screws of main compartment which reveals backside(you can see the CPU FAN)
2)Then open the Screws of Hard disc portion backside
3) Open all surrounding screws which supports whole body
4) make sure one or two screws are at battery compartment open them also
5) Ultimately you have to open whole body of laptop which Reveals the Motherboard.
6) Now carefully disconnect the removable sockets and find your Faulty USB PORT on that Board.
7) Replace it with new USB PORT by re-solder it.
8) Then carefully connect all the components and sockets that you had open previously.
Then fix all the screws of backside.
I hope you understand above procedure to replace your USB PORT. Please give your rating which help to improve the service. Thanks a lot to giving me such opportunity to help you.
Dec 07, 2011 | Dell Computers & Internet
My Logitech LX3 optical mouse has stopped working completely. If there is a battery in it where the heck is it? I don't see anywhere on the mouse where a battery could fit in it. Please help! Francine
The LX3 is a wired USB mouse so it doesn't have a battery. So the next issue: is the mouse plugged in directly to the computer or into a USB hub? Try changing the port that you have the mouse connected. Check that the USB ports are active (not disabled for power savings or security) For Windows, the first is under the Advanced settings for the Screen Saver. The second is in the device manager. Try the mouse on another computer if possible. Try a different mouse on the computer. Check if other USB ports work with known working devices. For a Windows machine, you might try uninstalling the USB device and then reinstalling the drivers after a reboot. For laptops, try resetting the unit. On my HP laptop, I lost all USB devices at once for a part of the day. In that case, unplugging the AC charger and removing the battery was required to recover the USB ports.
If you have an older OS, make sure the drivers are installed. (This mouse is not compatible with Windows 95.) If you use a USB to PS/2 adapter, try a USB port and reboot the computer.
Wired mice frequently get damaged cables so I'd recommend replacing it. There was a 5 year warranty on the mouse when purchased new.
I hope this helps.
Mar 20, 2011 | Logitech LX3 Optical Mouse
How do i connect my wireless optical mouse model MWO03 to my eee laptop windows 7?
Follow these steps :
Check to see if your laptop supports wireless technology (Bluetooth, 802.11 or other). If it doesn't, you will need a wireless receiver. If it does, verify that your laptop is compatible with your wireless mouse, which could use either Bluetooth technology or a radio signal.
Unpack your mouse and open its battery compartment. The wireless mouse won't receive any power from the laptop, making batteries necessary.
Add new batteries to the compartment. Make sure that the + battery end is inserted into the + niche in the compartment.
Place the mouse where it is easy to use and least stressful on your fingers.
Place your wireless receiver appropriately if your laptop doesn't support wireless technology. The receiver should be kept at least 8 inches away from the laptop or any other object that would cause any interference.
Place the wireless receiver anywhere from 8 inches to 6 feet from the mouse.
Insert the driver CD into your laptop and follow the instructions to install the software for running the mouse.
Connect your receiver to the laptop by plugging in the mouse's USB connector to the USB port of the laptop. If you do not have a free USB port, simply use an external USB hub for more ports.
Nov 07, 2010 | Computers & Internet
Toshiba Satellite A505 usb ports fell off inside. how are they held on? how to fix?
This info is about replacing a Harddrive in a Satellite A505, but I wanted to show you what is entailed in order to access the USB ports in order to repair, or replace them.
Page 2, Step 18. (You can enlarge the photos by clicking on them)
ALL power removed from the laptop! AC adapter (Charger), and Battery. Buy and wear an ESD wrist strap, connect the alligator clip to a good ground source. Average cost is around $3 to $8.
Use a multi-compartment container for the various screws, mark each compartment for where the screws came out of. DO NOT mix them up.
Oct 23, 2010 | Computers & Internet
Cannot get mouse to work
If the underside of the mouse has an on/off switch, make sure to set the switch to the "On" position.
Restart the computer. This can resolve the problem, at least temporarily, so that other troubleshooting steps can be applied.
Move the mouse or keyboard closer to the receiver
The receiver is the hardware that receives the wireless signals from the keyboard and mouse and communicates the data to the computer. Most receivers connect to a USB port, either directly or by a cable, but a few types of receivers connect to the PS/2 ports.
. Make sure that the keyboard and the mouse are within 100 centimeters (39 inches) of the receiver. If the receiver is attached to a cord, position it so that it is on the same level surface, close to the mouse and keyboard.
4. Replace the batteries with a fresh set of alkaline batteries and make sure they are correctly installed. If the mouse or keyboard is not working, then replace the batteries, even if the mouse/keyboard software indicate the batteries still have a charge.
Remove the battery cover to access the batteries. For keyboards, the battery access cover is found on the underside of the keyboard. When replacing the batteries look for the positive symbol (a plus sign +) imprinted near the battery compartment or battery cover. Make sure the positive end of the battery is oriented to the positive side of the compartment.
If you have a USB receiver, unplug the USB receiver, wait 10 seconds, and then insert it into another USB port - preferably into a USB port that is closer to the mouse and keyboard. For example, if the USB receiver was plugged into a USB port on the back of the computer, unplug it and plug it into a front USB port.
Resync the wireless keyboard and mouse connections.
Resync the keyboard and mouse connections for receivers with a connect button .
Resynchronizing the keyboard and/or mouse causes the devices to reconnect to the receiver using new identification numbers.
NOTE: The following connection sequence must be completed within 60 seconds. If the sequence is not done in 60 seconds, start over.
Sep 10, 2010 | HP Wireless Optical Mouse
Battery wont recharge-
Below are some things to check for when charging your Sansa player:
USB Cable Make sure that the USB cable is properly plugged in and use the original cable that came with your player. Make sure the computer isn't entering hibernation or sleep mode while the device is connected. The computer must be ON in order to charge your player. USB Port 2.0 Make sure the player is connected to a USB 2.0 port (1.1 occasionally causes charging problems). USB Port location Try plugging into different USB ports (i.e. USB port in the back of the computer); occasionally the front USB ports have limited power to charge up the device. Battery Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery. Latest firmware Depending on what Sansa player you have, make sure it's up to date with the latest firmware. AC charger (optional) AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port. These accessories are available on our online store.
To Remove the Battery... 1. Remove the back on the e200 by removing the 4 screws. 2. Lift off the back by using a finger nail or a small flat head screw driver. It will not take a lot of force to remove. NOTE: When replacing the e200 battery be sure that the contacts on the battery line up with the contacts on the player. 3. The battery has three gold contacts on one end of the battery, which is near the words SanDisk Sansa. Be sure these contacts match up with the three gold contacts on the back of the player. 4. Lightly push the lined up battery up against the contacts of the player until the bottom end of the battery can be pushed into place. 5. Replace the lid to the back of the player and then plug the player into the computer using the Sansa cable. 6. Once the player has connected to the computer and is ready to be used or says "Connected", unplug the device.
NOTE: If the device goes directly to a black screen after unplugging it, then the battery has been replaced incorrectly. Take the back off the player once again and flip the battery around and the e200 device should work properly.
May 31, 2010 | SanDisk Sansa e250 MP3 Player
I have a Sansa c200 that will not turn on, although the light ring is on. When I plug it into the usb port on my computer it does not recognize it either. Thanks!
First try and reset the player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
If that does not do it, re-seat the battery: Here is how to get to the battery, 1. Press the battery compartment in while sliding to the right. 2. Remove old battery. 3. Insert new battery or reset the old battery. 4. Close the battery compartment. Then try and see if it will come on with out the battery hooked to your computer. 1. Remove the battery. 2. Connect the player to the PC to verify if it turns on. 3. Re-seat the battery to ensure proper connection. 4. Verify if the player turns on.
Jan 30, 2010 | SanDisk Sansa c200 MP3 Player
Can't charge battery
Try another cable. Some don't work
In these otherwise good machines, the battery may come loose. Then they won't charge no matter what.
Feb 02, 2007 | Truly MP313X 1 GB MP3 Player
Olympus WS-100 Digital Voice Recorder Logo
81 people viewed this question
Top Olympus Audio Players & Recorders Experts
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
