Question about Goodman CLQ36AR49 Air Conditioner
I have a goodman furnace and ac unit the fan and heat work but every time i turn the ac on it blows the low voltage fuse ive replaced all low voltage wires to outside unit and thermostat i also replaced the board in the furnace and transformer
  • 26 Answers
Look at the contactor on the condensing unit, remove the low voltage wires to the contactor and turn on the system. If the low voltage fuse doesn't blow, replace the contactor.
Posted on Jul 07, 2009
    Problem Solver:
  • 14 Answers
Try changing the capacitor. i dont recommend doing it yourself, but if you think you can, go ahead. if that doesnt work then have the compressor tested and the fan motor tested too. good luck!!!!!!!!!!
Posted on Jul 15, 2009
  • 867 Answers
Sounds like the compressor is siezed
Posted on Jun 24, 2009
I have a Coleman mach 3 ac unit. ive replaced everything except the compressor. the fan will come on but when i put it on ac it blows the fuse in the thermostat.
Fuse in the tstat?? First inspect the low voltage wire outside for imperfections, such as bare wires. Unhook the low voltage wires to condenser outside and cap with existing wire nuts. Then replace fuse and turn system on with cooling. If fuse still good then you have a short in the contactor coil in the condenser. Need new contactor. If fuse only blows when a call for cooling it's in the wire for low voltage or the contactor itself.
May 21, 2017 | Coleman Heating & Cooling
Goodman furnace GMT115-5B Turn fan to on on
Bypass the tstat first but that's where I'd be leaning.
Aug 14, 2017 | Goodman GMS90703BXA Heater
Fan won't blow on ac, but works on furnace
The fans heat speed is low speed and the cool speed is high speed. High speed is controlled by the fan relay normally open switch, the low speed is controlled by the temperature delay or time delay.
see diagram
Jun 05, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
Heat worked couple days ago. but today turned on the air and it worked but sometime it shut down and now furnace and air will not come on. check fuses in house and all are good. but have fuses outside did...
It is unlikely that you have a transformer at your outdoor unit. If your furnace has an electronic control board, look for a low voltage fuse that may be blown. The low voltage fuses used now usually resemble a car fuse.
May 01, 2010 | Goodman GMS90703BXA Heater
Heater keeps going off on its on also fan not
Please provide more info. When it goes off does it come back on by itself or do you have to flip a breaker? Is the furnace gas or electric? If it is not moving enough air across your heat exchanger in a gas furnace or across electric heating elements this will trip a safety switch that will stop heating but not fan. Low air speed is most likely from inexperienced or improper duct design/ installation. Duct sizing is very important to move enough air. Don't believe me try breathing thru a straw. If your unit is a gas furnace it has a flashing code that will tell you what is wrong codes listed inside unit door. Could be lots of things. Reply with more info.
Dec 04, 2009 | Goodman Heating & Cooling
I have a goodman furnace and ac unit heat and fan work but soon as i flip the ac on it blows the 5amp fuse at the furnace
their is a control short some place check the control wiring . dog or rodents chewing threw it or shorted controls or thermostat id get service. Tom
Jun 24, 2009 | Goodman CLQ36AR49 Air Conditioner
Goodman furnace
double check your wiring. R terminal on the furnace will provide 24 volts to the t-stat. W terminal in the t-stat will send 24 volts back to the furnace W terminal to turn on the heat. G terminal in the t-stat will send power to the G terminal in the furnace when the t-stat is switched to fan on. Y terminal in the t-stat will send power to the Y terminal in the furnace which in turn will send 24 volts to the A/C outside. The C terminal in the furnace should be connected to the c terminal in the A/C outside as well as to the T-stat. Check the fuse again
Jun 02, 2009 | Goodman GMS90703BXA Heater
3 amp fuse blows on a carrier 58mcb furnace board
Hi!!! Does your ac unit work fine?If not check your low voltage problem..You have a low voltage problem check the wire going out to your condensor make sure that they are not touching..Good luck..Check low voltage wires..short in progress..
Jan 04, 2009 | Carrier 52CQ-312-4 Comfort Series Heat...
Goodman Furnace/AC unit not working 3a fuse blows even after replacement. once thermostat is turned on and clicks to start ac unit the fuse blows
3 amp is standard.the fuse is blowing to protect the transformer.It is telling you that there is a short in the low voltage wiring.Goodman also had an issue with the coil shorting on the contactor.To prevent damage.....i'd call a pro.It should be a fairly simple repair.
Jul 03, 2008 | Goodman CLQ36AR49 Air Conditioner
Goodman GMS90703BXA Heater/AC - 3 Amps Fuse blows
This fuse is used on the low voltage side of the furnace. All 24 volt controls operate thru it. You may have a short in your thermostst, thermostat wire or even a bad transformer. After replacing the fuse, inspect the wiring in the cabinet as well as the wire heading toward the thermostat for damage. If you find none, check the thermostat for loose wires or contacts. If all else fails, jump out R and W with a small jumper temporarly at the furnace and see if the unit runs. You will have to tape the door switch closed to run it with the panel off. Remember, this will keep the furnace running 100% of the time until you disconnect the jumpers. Not a solution, just a test! If it runs flawless, you have a bad thermostat or wire. Diagnosing a transformer is for a technician.
Aug 12, 2007 | Goodman GMS90703BXA Heater
Goodman CLQ36AR49 Air Conditioner Logo
474 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
