Question about Compaq CV 7500 17" CRT Monitor
Monitor Problem Can you show me the exact picture and where it is located the IC Vertical of BOKA MO-17NF?Thanks
Re: Monitor Problem
After u open the monitor at the back of the cord which have a heat sink that the ic vertical # lm2469ta
Posted on Mar 03, 2008
0 characters
3 Points
When i am switching on my pc the picture shrinks and shows a green line.imy warranty period has expired.i want to know if it is a general problem and can it be repaired or it has to be replaced?
it is possible that the monitor has a power crunch as a lower voltage gives out a shrinking picture. also it is possible that the deflection circuit or the vertical circuit, the vertical driver IC or section is faulty.
You can remove power and check for dry soldering, measure the power supply to confirm.
Aug 09, 2011 | Lenovo E75 CRT Monitor
My compaq monitor just start blinking and now only haft past of the screen is visible. the rest just went black with on bright shining line on the middle of the screen
Your monitor have problem with vertical deflection section. Can caused by the faulty vertical driver IC and faulty electrolytic capacitor it the vertical section or dry soldering in the pins of the vertical driver IC. When vertical section fails horizontal lines come on the screen. For testing the same you have to open the monitor and remove the main board. you can easily find out the vertical ic. just follow the four wire running from the deflection yoke ( coil on the crt neck) of which two will go to the horizontal section (normally red and blue wire) and two will go to the vertical section ( Normally yellow and green wire). Follow the yellow and green wire which will be connected to one of the socket in the main board. Follow the circuit track in the main board which will lead you to the vertical deflection section. There you can see one ic is fitted on a aluminium heat sink.Take a close watch in soldering of its leads. Dry soldiering can happen in its leads because its a component which will got to a temperature about 75 degree above at its normal working condition. if found any dry-soldering or not just resolder all the pins of that ic. then check the monitor. If problem remains then you have to relapse the ic.While replacing the ic try to relapse all the capacitors in that section. It will prevent from any further damage to the new vertical ic. if you need any more assistance feel free to contact me through fixya
Jun 09, 2011 | Compaq P 1220 22" CRT Monitor
No video output no responce from the on\off button
Resolder entire the video section first where the crt socket is located, look the vertical IC & System control IC for loose pins for solder. Check the ABL for open resistor and fault video ic located at CRT socket.
Sep 30, 2010 | LG Flatron Ez T710B 17" CRT Monitor
When watching movies on my computer, I am getting a weird line through the middle of the screen at times, also, when things are moving on screen faster, more lines seem to show. I guess they don't really...
i think your vertical IC ( if vertical lines are shown) / horizontal IC ( if horizontal lines are shown) of your monitor has damaged. you may contact a mechanic and change the corresponding IC
Sep 16, 2010 | CTL 261UW 26Inch Wide Screen LCD Monitor...
Resistors R504 and R507 are burned, values are unknown.This is a Boka color monitor.I need the values of the resistors.
What is the serial number of your monitor!!
And which parts that's burned, can you tell me the exact locations...
Oct 16, 2009 | Computer Monitors
HCL 17" monitor display problem
Hi there ,
It seems that you have a vertical section problem ,It might be possible some capacitor might have gone wrong
Jan 24, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
X2gen 19" monitor
open the monitor there is a vertical ic which has small alluminium heat sink ckeck 12v supply to ic if present then remove ic & check 12v at same point if present then replace ic if absent then check 12v regulator ic if faulty replace it
Jul 20, 2008 | X2Gen MG19MY 19" LCD Monitor
Vertical Wavy lines moving upward in my monitor
i think you have a faulty Fly Back Transformer { FBT / EHT }.
Mar 09, 2008 | Gateway FPD2275W LCD Monitor
Boka monitor problem
Below are images of the vertical IC of a Boka MO-15NF. The first shows its general location which is almost at the center of the board.  The second is a close-up.  Hope this be of help. Good luck and kind regards.
Oct 26, 2007 | Gateway FPD2275W LCD Monitor
No picture
this problem accure due to vertical o/p ic is failiur so plz checked it from any hardware engineer or if you changed it. you are welcome. i't mostly 9 pin ic on heat sink. it's mostly located at the horizantal _ vertical coil's wire( 4 wire attached with pcb) are placed.
Aug 30, 2007 | Samsung 21" FLAT CRT COLOR MONITOR
Compaq CV 7500 17" CRT Monitor Logo
63 people viewed this question
Top Compaq Computer Monitors Experts
Brian Sullivan
Brian Sullivan
William Miller
William Miller
Ricky Ostrom
Ricky Ostrom
Are you a Compaq Computer Monitor Expert? Answer questions, earn points and help others
