Question about Kenmore 24032\24036 Top Load Washer
Machine agitates but doesnt spin or pump out water
Kenmore washer 80 series 110 model 110. 92581210. It fills the tub but when it clicks to spin out you can only hear the timer working. What is the problem and part # i will need. Love my washer, just want to fix it.
  • 351 Answers
You will need lid switch 285671.. whirlpoolpartssurplus.com
Posted on Jun 24, 2009
Kenmore 80 series, model 110-2781690, won't spin or agitate. loud clicking from lower portion of machine. fills & drains ok. transmission failure?
hi,
Unfortunately, it sounds like a transmission/gearcase problem, mainly because you stated the motor would run, but would not agitate or spin.
With the motor removed from the gearcase, try to turn the coupler on the gearcase side one way for many turns, and see if your agitator moves back and forth, then turn the coupler on the gearcase the other way many turns to see if the tub starts to move
thank you,
vijay
Sep 29, 2009 | Kenmore Washing Machines
Kenmore 80 series will agitate but not spin or let water out.
Hi, I know washer had a party, he just need a dancing partner, joking, that's a common problem, when machine is not properly level, you should used spirit level, to level machine, after leveling machine, place both hands on machine, and try to rock it from left to right, forward and backward, and it should not have any play, if there's play adjust legs to compensate, water has to be pumped out first before machine spins, rhere's something wrong with water pump, maybe some fabric stuck in pump impeller, or maybe wires disconnected from water pump, remove back of machine and check connection to water pump, check for kink hoses, visual check, if wire were remove, connect to water pump, you're smart. good luck.
Aug 08, 2009 | Kenmore 24032\24036 Top Load Washer
Washer wont spin or take out the water
Hi 1st remove cabinet by removing 2 screws securing the console to the cabinet top.pry clips at corners and remove .you should now be able to pull cabinet towards you and separate it from chasis .motor /pump at center front bottom.plastic plug on right, wiggle that plug with washer in spin probably bad connection in plug.red/black wire Hope this helps please rate my solution. :)
Jun 26, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washing machine 80 Series 110 20802 990 Will not agitate or spin"
You need to replace the Kenmore Washer Lid Switch. I had the same problem so being lazy I would just push down on the washer's lid and it would push the lid switch further down. making the water drain. after a while I just replaced the lid switch.
Apr 22, 2009 | Washing Machines
GOES TO SPIN CYCLE THEN STOPS SUDDENLY AND REFILLS WATER IN TUB
Are you sure you don't have a second rinse button that is selected.
Jan 11, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series
Okay...I'm a little confused on your symptoms. You initially said it fills, but doesn't agitate or spin, but drains.
Then, you finished with the washer filling, no agitate or spin, but now doesn't drain.
Which one is it?
The symptoms you describe are usually associated with the following:
1. Fills, may or may not agitate, won't spin or drain - lid switch.
2. Fills, may or may not agitate, won't spin, but still drains - motor coupling.
3. Fills, may or may not agitate, won't spin or spins slow - gear case.
4. Fills, agitates, spins, but does not drain – water pump.
NOTE: These are the more common failure items with these symptoms.
Double check the lid switch by opening and closing the lid. You should hear a clicking noise to indicate the switch is working. The switch is located under the top panel along the wash tub rim on the right-hand side. If not, check to make sure the lid strike (small plastic piece on the lid itself) is in place. This activates the lid switch when the lid is closed. Also, check the mounting screws along the rim (there are two of them) to see if they are tight.
If the motor coupling were bad, the washer would still drain, but there would be a rattling sound as the washer tries to spin or agitate.
If you need replacement parts, go to searspartsdirect.com and type in your model number in the "Search by Model Number" window. The lid switch can be found under the "Top and Cabinet" heading as item number 11 (part #3949238). Instructions on how to replace are located at the following link:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
If you wish to replace the motor coupling, the part can be found under the “Brake/Clutch/Gearcase/Motor/Pump” heading as item number 13 (part #285753A). If you need instructions on how to replace, just follow this link:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
Now, there’s a couple of ways to drain the washer. If it’s a simple lid switch problem, you don’t need to drain the washer to replace the switch. With a broken switch repaired, the washer will run and drain by itself. However, if you wish to drain the tub you can use a shop vac to pull a vacuum on the drain hose. This may take a few times depending on the size of the shop vac. These wash tubs typically have about a 35 gallon capacity. If you do not own a shop vac, you can by-pass the lid switch by jumpering the two BLACK wires at the lid switch connector that is connected to the console. CAUTION: Make sure you UNPLUG the washer before jumpering, then plug back in.
I hope this information is helpful to you. If I’m wrong about the symptoms, please post back and update me on what the washer is or is not doing, so I can assist you further.
May 15, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
852 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
