Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Have whirlpool gold and it isn't making any ice
It isn't making any ice. the water isn't coming in. i have water in the other part to fill up a glass though.
  • brianbomkamp Jun 25, 2009
    no the line isn't froze, i unplug it for 24 hours and still no water.
  • 351 Answers
Is the line froze? try jumping it with direct 110 volts and see if you get water
Posted on Jun 24, 2009
  • Mark Nichols Jun 25, 2009
    jump the water valve 110 direct and see if you get water
G16farxxqo7 ref wont make ice where is water valve
So you want it to make ice water. And it comes out not frozen.
Is the water cold? if it is cold then it is making ice water ok.
Ice water is never frozen, only ice is frozen.
Dec 21, 2013 | managemylife.com
Ice maker freezing up
The water line to your unit may need to be replaced. Check how fast water comes out of the dispenser. If it's trickling out or takes 30 seconds to fill the glass, you have poor water pressure to the unit and it's causing the fill tube to freeze.
Nov 27, 2013 | Refrigerators
My ice maker doesn't make enough ice cubes
Is the ice maker itself filling normally, meaning where the cubes are made gets enough water to cover the complete area or just a few slots? If not then check the fill tube where the water comes into the ice maker to make sure no ice has formed blocking the water from coming in.
Now if ice production in general has slowed, going from every 45 minutes or so to like every 6 hours, then your machine more than likely isn't getting cold enough. The ice maker requires the temperature be at least 10 degrees F or below for it to function properly.
Jun 16, 2012 | Kenmore Side by Side Refrigerator
Samsung RS265TD Ice maker does not fill with water. After I press test button and the ice maker cycles I manually fill the tray with water and it will eject on next cycle etc. Good water supply on thru...
Hello
Either the fill solinoid is bad or the inlet tube at the ice maker is frozen.
Try running a hair dryer to remove any ice that may be blocking the water from coming into the ice maker tray.
Jul 28, 2011 | Samsung RS265TD
Just had a new part # 241734301 installed, because the old one broke during a move. It appears to work fine although the water continues to dribble for a while after filling a glass. Also, the water will...
It seems as though the water hoses are reversed, Ice maker line and water dispenser line are probably switched, this would explain why the water comes out the door intermittently. It's probably trying to dump water into the ice tray but its coming out the door.
May 22, 2011 | Frigidaire FSC23F7D Side by Side...
Water dispenser is not working
Does it make ice? If it makes Ice, then you have water to unit. If No Ice and No Water, check water supply. Otherwise, you could have a bad water valve. Remove valve and the line coming off of valve to water reservoir try to dispense water and if valve is good you should have water coming from valve. (have a bucket or bowl handy to catch water).
Mar 28, 2010 | GE Refrigerators
No ice or water from in-door dispenser
When you first hook water up to the refrigerator you have to fill a tank in the fridge. Open the water supply behind the ref. turn the control on the front of the ref to water and hold a glass under the spout as if you are filling a glass . You may have to wait 3-4 minutes forthe tank and lines to fill with water before you get any to come out into the glass. The water my be discolored at first so run a few glass full through before drinking . hope this helps
Bobalix
Apr 16, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water comes out to slow to fill a glass of water
is the ice maker making ice good check in side water valve check if mesh clean
Mar 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ge refrige freezer ,water to ice maker.
HI.YOU NEED TO CHECK THAT THE WATER VALVE IS WORKING OK THERE ARE TWO SEPARATE VALVES FOR THE FRIDGE
GOOD LUCK MOHAMED
PLEASE RATE THIS
Oct 19, 2008 | GE Monogram ZDI15C Automatic Icemaker
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
147 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
