Computers & Internet Logo
A
Anonymous Posted on May 27, 2014
I know my combination but my battery is dead on Amsec dl4000 safe. How do I open?
Have an Amsec Dl4000 safe. The battery for the keypad died so I have no way to open. Please help
David Payne
Level 3:
Top Expert:
  • Amsec Master 14,162 Answers
  • Posted on Apr 25, 2016
David Payne
Amsec Master
Level 3:
Top Expert:
Answers
14162
Questions
0
Helped
2996207
Points
455836
1helpful
How do I lock an Amsec DL4000 safe when the door bolts won't move?
Question edited for clarity.
Question moved to home Security - Safes.
You can't. You have to open the safe with the Emergency Key, the combination Dial or in your case with the Electronic Keypad.
STEP 2 - CHANGING THE USER CODE
1-Open the safe by following step 1.
2-Press the Green set up button (Located on the
back cover or the hinge side of the back door
cover), the LCD display will turn Blue.
3-Enter your new user code (1-8 digits).
4-Press the # key.
5-The LCD display will turn Blue and show IN.
6-The LCD display will briefly show your new code.
7-Your new user code is now set to open the safe
NOTE: It is highly recommended to leave the
safe door open and practice your new code
several times before closing the door.
Manual
https://www.manualslib.com/manual/1800698/Amsec-Dl4000.html#manual
Do you have manual for AMSEC SF6030 gun safe
If you are looking for a manual for your keypad on your safe first you have to identify which lock it is. Amsec produces a few locks and there are numerous others it can be. You can call Amsec or get on there site . Or post a pic.
Opening my amsec c5 floor safe after losing combination dial
You can just buy a new dial.
https://www.safeandlockstore.com/products/Amsec-Star-Floor-Safe-Removable-Dial-B002000-.html
2helpful
Why can't safe be locked?
With mine, Is handle slightly loose and hanging down? Try lifting handle to move dial.
MY BATTERIES OF AMSEC DL4000, DIGITAL IS OFF, ANY WAY OF OPENING
Order the amsec power override box that plugs into the small headphone jack looking hole under the keypad
I hav a amsec dl4000 safe and forgot the passcode and hav no idea where the 2 keys r. the batteries work tho, is there anyway for me to open it??
I knew someone who had a locking mailbox like that with keys when pass is forgotten or battery runs down, they could open with key. He registered it as directions said to do so you could order new keys, the old mailbox was also lockable and since owner died he had to throw it away as couldn't prove he wasn't thief. Maybe something there helps.
I have a sentry safe model so500 & the batteries are dead, so I can't open it. I know the combination, I just can't open it! HELP!!! thank you, Lesley
Locksmiths agree on How to install sentury safe batteries
slide open the battery cover located just below the keypad.
Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated.
reconnect the connector and put back the battery holder. Slide the cover back in place.
49helpful
5answers
Sentry safe S3877 have key and know combination but battery dead
Use paperclip to push in pin size hole below keyboard and then slide panel to right. Battery box is right there. Replace batteries and then was already to accept code.
228helpful
10answers
Forgot pin code to unlock my hardline digital safe
I have pin code but batteries went flat while I was on holiday, how do I unlock my Hardline digital safe? I do not have override key
Top Amsec Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Amsec Computer and Internet Expert? Answer questions, earn points and help others
