Question about Acer Aspire 3680 Laptop
My laptop will not turn on or charge - Acer Aspire 3680 Laptop
  • 22 Answers
A number of things could have happened. The simplest is that the charger itself is not connecting to the computer. If the LED is displayed on the charger, it could also be a connection in the cable that is disrupted (or even a loose connection on the motherboard of the laptop).
==Troubleshooting
Some things you should look for on the laptop when its plugged in. If the power supply doesn't light up, then get a new one as mentioned below. If it doesn't have a light or it does light up, then you need to see if the laptop is recieving power. The laptop should have a light that turns on when it is plugged in. If thats the case then when you press the power button, if nothing happends, you might have a BIOS or Motherboard issue (in which case, you're essentially screwed - read below for clarification).
Now if the laptop makes some sound, then you either have a video card issue, or maybe your OS is fried. Either situation can be tested pretty quickly. If you do have some video display, but lets say its only for a second, hook the computer up to an external monitor using a VGA cable. If you recieve no video in either situation, yet hear fans, then you might have a fried video card. If its a nVidia 6, 7, or 8 series card, you need to call your laptop company - regardless if its out of warrenty - and tell them you have a GPU issue which afflicts the nVidia GeForce (insert your model type) series cards. If they cannot help, ask to speek to a supervisor, as don't A number of things could have happened. The simplest is that the charger itself is not connecting to the computer. If the LED is displayed on the charger, it could also be a connection in the cable that is disrupted (or even a loose connection on the motherboard of the laptop).
== Power supply replacement
Go to Sams Club (or WalMart) & look for the Targus universal power supply for laptops. It should be around 30-35 and works very well. You can take it back if that doen't solve the problem - so keep your receipts with the packaging. You might actually try bringing the laptop there and having them try it on your computer to make sure that it is compatable (at least do it under that guise, becasue it is compatable).
==BIOS/Motherboard
Now if it is a BIOS issue, where you downloaded software updates & maybe you don't pay attention to them, or whatever, but the BIOS were flashed & the flash was (in some manner) corrupted, then I'm sorry to tell you but you're laptop is essentially screwed.
This is the other end of the spectrum - either you spend 35 and it works, or you have a $700 paper weight. take sh*t over the phone from someone reading a script (Step 12, if a customer wants something, explain to them that there is nothing that you can do....)
You might actually get to someone who speaks English, but either way - you need to hold your ground until they are willing to replace it.
Posted on Jun 24, 2009
How to Save my Laptop Battery?
Charge battery fully (with laptop off) then unplug AC power. Do not continuously have power plugged in. This will ruin your battery. Remove battery when not in use for long periods. To refresh battery charge fully then run laptop till it turns off. Turn on again and wait for it to turn off. When laptop wont turn on, charge battery fully again and repeat process about 3 times. This should extend an old battery's run time.
Oct 18, 2016 | Computers & Internet
I have a new LB1 battery for my 2006 15 in.macbook pro it will not charge the test button on the battery shows it is full charge but will not turn on laptop or charge
The laptop is the problem and not the battery, check the battery contacts for corrosion or consult a specialist on how to fix your laptop.
Dec 10, 2014 | Computers & Internet
Laptop turns off and wont charge battery
Does it turn on while it's plugged in?
3 most common things that go wrong with laptop charging.
1- bad battery - replace
2- bad charger - replace
3- bad charging port - replace
Feb 26, 2014 | Samsung NP355E5C-A01US Laptop
Batter wont stay charge
Most laptop batteries have a life expectancy of two years or 400 to 450 charge and discharge cycles. After this time, the battery may lose the ability to charge or to hold a charge for substantial periods of time. When this happens, it's likely the battery needs replacement. However, troubleshooting can narrow the problem and ensure you are not wasting money on a battery replacement.
Check Power Adapter Turn the laptop off. Remove any power cords or power sources. Separate the battery from the bottom of the laptop. Slide or press the locking mechanism to unlock the battery. Slide the battery out of the battery compartment. Plug the power adapter into an electrical outlet. Insert the opposite end of the adapter into the charging outlet on the side of a laptop. Power on the laptop. If the laptop does not turn on, the power adapter is not correctly working. If the power adapter is not working, the battery can not charge. Replace the power adapter. If the laptop powers on, the power adapter is properly working. Clean Battery Contacts Turn the computer off. Remove any power cords or sources. Take the battery out of the battery compartment. Dip a cotton swab in isopropyl alcohol. Rub the dampened swab on the battery compartment and battery contacts. Dust and buildup can prevent battery contacts from properly charging. Slide the battery back into the battery compartment. b> Charge and Test Battery Plug the power adapter into the laptop. Charge the battery for six hours. Remove the power adapter. Turn the laptop on. If the laptop turns on and stays on for at least 30 minutes, the battery is holding a charge. If the laptop doesn't turn on or the battery doesn't power the laptop for at least 30 minutes, the battery should be replaced.
Battery Won't Charge Or Short Power Life In Notebook
http://www.daileyint.com/hmdpc/battery.htm
Laptop Battery Depot http://www.laptopbatterydepot.com/problems.asp - clean
Feb 24, 2013 | Computers & Internet
DELL laptop isnt charging but power cord will keep it on why?
Jenni:
Your battery has died. You'll have to buy another one.
Nov 24, 2012 | Dell Latitude D630 Notebook
Please post the step by step process of turning on my laptop acer 5570z.. (powerswitch problem) thanks in advance and more power
Hi
Have you plugged in your power cord to the electric socket so that you can charge the battery
using the laptop with the power cord in while it is charging
so if there is not charge in the laptop at all maybe plug in and turn on socket switch
and leave to charge for an hour or so
then try to start laptop again
hope you can sort it
good luck
Apr 10, 2011 | Acer Aspire 5500 5570-2609 Laptop
My laptop in turn on but not charging and i turn off charging
sounds like you have replaced the laptop charger for the laptop to a universal charger and not an original.
May 27, 2010 | Toshiba Satellite Pro L300 Notebook
The screen on my laptop will not turn on, when i turn on my laptop the buttons light up but the screen wont come on.
your laptop is completely out of charge juice , charge it. if it is fully charged and still wont work, you need a new computer battery.
Jun 29, 2009 | HP Pavilion dv6000z Notebook
Startup/charge issue
Sad motherboard sorry,
replace and start again
Jul 21, 2008 | HP Pavilion dv6000z Notebook
3680 charging issue
ok " new batteries would be a cool Idea, but did ya know you can set your laptop for desk top mode and laptop mode, desktop uses more power , laptop conserves power .
go to control panel look for power management.
Jan 22, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 3680 Laptop Logo
287 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
